SOLVED: Unable to stream, something to do with NAS rights
Serviio_user2015
Post Wed Oct 28, 2015 6:38 pm
Here is my set up
W7 and W10 PCs.
Sony Blu-ray Disc™ / DVD Player BDP-S370/BX37
WD MyCloud
The folder on the WD that I want to stream (Movies) has Public Access
Both laptops have the shared folder in Serviio as \\HiNDERSMYCLOUD\Movies (not mapped)
The W7 PC has no issue. The user for W7 is UN1 (with a PW). The WD has UN1, different PW.
The W10 PC has UN2 (no PW) , using the FAQ, I set the service to work with the UN2 and no PW, and I set the Serviio service to have the W10 UN2. No errors reported.
The W10 PC does not scan the files. When I access the server from the Sony BR, it says “no playable files”
I read that Servii must have the same access as the pc.
“To access a NAS device the exact same set of credentials must be created on the NAS device. The Windows credentials must be a local user and not a domain user. The user must have "Run As Service" rights. The remote path must be entered as a UNC path in the Serviio Console (e.g. \\server\folder)), mapped drive letters will not work since the user running the Serviio service is not aware of your mapped drives.”
Here is what I did:
On both machines I removed all mapped drives.
On the WD I changed the root / admin user name from UN1/ to UN2
The Movies dir is public (no pw), I checked all folders to ensure that UN2 was listed, and that there was no entry for UN1
I checked to make sure that the WD log in was now UN2 and it worked
On the W10 machine, I checked / changed the Windows credentials for the WD from UN1 to UN2
On the W7 machine, I checked / changed the Windows credentials for the WD from UN1 to UN2
I re-mapped to some drives (some public, some PW).
The W7 pc still works, if I add a file to the Movies directory and force a refresh …and the files continue to play on the Sony BR
The W10 pc…..still does not, if I add a file or try to play from the Sony ….
Is there something else I need to do?
Last edited by Serviio_user2015 on Wed Oct 28, 2015 7:31 pm, edited 1 time in total.
Serviio_user2015
Post Wed Oct 28, 2015 7:30 pm
Re: Unable to stream, something to do with NAS rights
Well , 30 min after posting ..........but 24 hours after making the changes, it works :-)
Now on to how to FF / Rew the files .......
Post Wed Oct 28, 2015 11:18 pm
Re: SOLVED: Unable to stream, something to do with NAS right
If your files require transcoding, trick play (FF/RW) often does not work. Depends on the format being transcoded in to an the abilities of your streaming player.
Users browsing this forum: Baidu [Spider] and 33 guests
