Toshiba 32RV753B
hansol123
Post Tue Mar 01, 2011 12:57 pm
Toshiba 32RV753B
I have just purchased a Toshiba 32RV753B television and found that the picture was reduced in size when streaming programmes recorded from BBC HD recorded using NPVR and edited in Videoredo. I installed Serviio after a recommendation and first of all tested using a WDlive streamer all worked ok. I then connected the tv to my network and tried to play the same recording using the generic and then the Regaza profile in both instances the file was displayed as 0 bytes and would not play.
Can anybody assist with a profile that works for this TV.
Thanks for your assistance.
Post Tue Mar 01, 2011 1:17 pm
Re: Toshiba 32RV753B
Could you provide detailed logging and ffmpeg -i of your file ? (see my signature for link)
hansol123
Post Sun Mar 06, 2011 5:31 pm
Please find log attached.
SD TS files play ok the problem is with HD TS files recorded from BBC HD .
Thanks for your help.
serviio - log.rar
(25.22 KiB) Downloaded 889 times
hansol123
Post Sun Mar 13, 2011 8:40 am
Can anybody help.
As stated above works fine with SD TS files but fails to recognise HD TS files recorded from BBCHD and edited in Videoredo..
Post Sun Mar 13, 2011 9:11 am
wow there give the guys a chance to look at the log and they maybe able to help. They will post once they have looked into your issue for you.
Post Sun Mar 13, 2011 4:10 pm
post results of ffmpeg -i for the file:
viewtopic.php?f=5&t=1123
hansol123
Post Sun Mar 13, 2011 6:23 pm
Microsoft Windows [Version 6.1.7601]
Copyright (c) 2009 Microsoft Corporation. All rights reserved.
C:\Users\Taylor>cd "\Program Files (x86)\Serviio\lib
C:\Program Files (x86)\Serviio\lib>ffmpeg.exe -i "E:\recordedtv\hattie.ts"
686-mingw32-
libavutil 50.36. 0 / 50.36. 0
libavcore 0.16. 0 / 0.16. 0
libavfilter 1.72. 0 / 1.72. 0
libswscale 0.12. 0 / 0.12. 0
E:\recordedtv\hattie.ts: No such file or directory
C:\Program Files (x86)\Serviio\lib>^V
hansol123
Post Sun Mar 13, 2011 6:31 pm
Sorry for the above 2nd attempt
C:\Program Files (x86)\Serviio\lib>ffmpeg.exe -i "E:\Recorded TV\hattie.ts"
686-mingw32-
[mpegts @ 010abc30] max_analyze_duration reached
Input #0, mpegts, from 'E:\Recorded TV\hattie.ts':
Duration: 01:24:58.92, start: 0.195033, bitrate: 5458 kb/s
Program 1
Stream #0.0[0x157c]: Video: h264, yuv420p, 1440x1080 [PAR 4:3 DAR 16:9], 30
fps, 25 tbr, 90k tbn, 50 tbc
Stream #0.1[0x157d](eng): Audio: ac3, 48000 Hz, stereo, s16, 192 kb/s
Stream #0.2[0x157f](eng): Subtitle: [6][0][0][0] / 0x0006
Stream #0.3[0x1580](eng): Subtitle: dvbsub
Post Sun Mar 13, 2011 7:23 pm
Can you see this file when yo're browsing on the TV and only get the error when attempting to play?
hansol123
Post Sun Mar 13, 2011 7:46 pm
Yes I can see the SD and HD files but the HD TS files do not have a size.
hansol123
Post Sat Mar 19, 2011 8:43 pm
Do you require further information ???
Return to Toshiba
