Which profile should I use on samsung UN32J5500 to see subs
eniobueno
Post Sun Jul 19, 2015 2:18 am
I use serviio 1.4.1.2 on ubuntu 14.04.
Recently I bought a Samsung (UN32J5500) and all works fine, less the subtitles.
I tried all samsung profiles available to me (A, B, C/D and E/F series). I tried Generic DLNA profile too.
If I copy the files to usb pendrive, subs works ok.
There are other conf or profile to try?
Thanks to all.
andresv
Post Fri Nov 27, 2015 3:31 am
Re: Which profile should I use on samsung UN32J5500 to see s
Hi, any solution to this problem?
Thanks in advance,
Agv
flaksy
Post Sat Nov 28, 2015 2:58 pm
J series is not fully supported yet. With H profile Serviio is able to stream mkv's with internal subs and show internal subs. External files are not working atm. It has all been reported and serviio developer is working on it. So stay tuned ...
All is discussed here: viewtopic.php?f=10&t=19198&p=105142#p105142
