1.5.2 Library Autorefresh wont work anymore
spacemutron
Post Wed Dec 02, 2015 6:23 am
Hi!
On 1.5.1 (Pro) all works fine for me. Later after the Update it seems to work too. Now, some Months later it's broken. I've to start the refresh everytime manually. I waited over the Night to be sure thats really broken. Nothing happend. My System runs on Windows 10...
I hope you'll have a hint for me.
bb space
edy819
Post Sat Dec 05, 2015 11:02 am
Re: 1.5.2 Library Autorefresh wont work anymore
Hi!
I have the same problem too. I have 1.5.2 on Windows 7. Someteimes it refreshes the directories after a few hours but mostly have to do it manualy.
In previouse versions there where options in consol how often to make a folder rescan, and you could take a look at what it is actually scanning. It was very useful but wanished from new version :(
It is really annoing.
Thanks for any help!
Post Sat Dec 05, 2015 9:41 pm
More information needed:
Citronel
Post Wed Jan 06, 2016 8:55 am
I have the same problem, library not updates and big problem is that is not updated even I try to manual force update.
All library are on local HDD 2T >5000 folders.
Serviio v1.5.2
OS win 8.1 x64
Post Wed Jan 06, 2016 9:57 pm
Check a detailed log when you are doing a forced refresh. Does that show anything (eg does it get to a certain point before failing?)
