apache reverse proxy - flash player not working
tata-greis
Post Tue Dec 01, 2015 10:07 am
Hi all!
I´m trying to get mediabrowser working with an apache2 (2.4) reverse proxy.
My setup is as follows:
ProxyRequests     off
ProxyPreserveHost off
ProxyPass /mediabrowser/ http://localhost:23424/mediabrowser/
ProxyPass /cds/ http://localhost:23424/cds/
<Location /mediabrowser/>
   SSLRequireSSL
   Order allow,deny
   allow from all
   ProxyPass http://localhost:23424/mediabrowser/
   ProxyPassReverse http://localhost:23424/mediabrowser/
</Location>
<Location /cds/>
   SSLRequireSSL
   Order allow,deny
   allow from all
   ProxyPass http://localhost:23424/cds/
   ProxyPassReverse http://localhost:23424/cds/
</Location>
When I bypass the reverse proxy (connecting to localhost:23424), everything runs as expected in all browsers I tested.
Using the reverse proxy, HTML, JavaScript and whatever stuff display fine, but the flash player (flowplayer) does not display, at least in most scenarios (see below).
Firefox 42 & Crome 46 - access via https apache reverse proxy
    login to mediabrowser works
    menus and viewing pictures are working
    videos and music just display a black box for the flash player
IE 11 from my notebook - access via https apache reverse proxy
    videos and music display the flash player fully operational
IE 11 from my desktop - access via https apache reverse proxy
I was not able to find out a difference in the two IE setups. All installations use the most up to date flash player.
Analyzing the apache logs and using HTTPHeaders in firefox showed the following:
Firefox via https and apache reverse proxy (flash player not working)
https://www.external.ip/mediabrowser/assets/flowplayer-3.2.16.swf
GET /mediabrowser/assets/flowplayer-3.2.16.swf HTTP/1.1
Host: www.external.ip
User-Agent: Mozilla/5.0 (Windows NT 6.1; WOW64; rv:42.0) Gecko/20100101 Firefox/42.0
Accept: text/html,application/xhtml+xml,application/xml;q=0.9,*/*;q=0.8
Accept-Language: de-DE,en-US;q=0.7,en;q=0.3
Accept-Encoding: gzip, deflate
DNT: 1
Referer: https://www.external.ip/mediabrowser/
Cookie: sessionLang=en; UserPref=pm_power_unit%3Dbtus; irc=last%3Dirc
X-ClickOnceSupport: (.NET CLR 2.0.50727; .NET CLR 3.5.30729; .NET CLR 3.0.30729; .NET4.0C; .NET4.0E)
Connection: keep-alive
HTTP/1.1 200 OK
Date: Mon, 23 Nov 2015 14:24:58 GMT
Server: Restlet-Framework/2.2
Content-Length: 133023
Content-Type: application/octet-stream
Cache-Control: private, max-age=36000
Vary: Accept-Charset,Accept-Encoding,Accept-Language,Accept
x-content-type-options: nosniff
X-Frame-Options: sameorigin
Keep-Alive: timeout=15, max=72
Connection: Keep-Alive
Firefox directly accessing via localhost:23424 (flash player working)
http://nas2:23424/mediabrowser/assets/flowplayer-3.2.16.swf
Host: nas2:23424
DNT: 1
Referer: http://nas2:23424/mediabrowser/
Cookie: statuslist=true; scroll=0:0;
HTTP/1.1 200 OK
Date: Mon, 30 Nov 2015 15:19:02 GMT
Vary: Accept-Charset, Accept-Encoding, Accept-Language, Accept
http://nas2:23424/mediabrowser/assets/flowplayer.controls-3.2.15.swf
GET /mediabrowser/assets/flowplayer.controls-3.2.15.swf HTTP/1.1
Host: nas2:23424
DNT: 1
Referer: http://nas2:23424/mediabrowser/assets/flowplayer-3.2.16.swf
HTTP/1.1 200 OK
Content-Length: 38353
http://nas2:23424/mediabrowser/assets/flowplayer.menu-3.2.12.swf
GET /mediabrowser/assets/flowplayer.menu-3.2.12.swf HTTP/1.1
Host: nas2:23424
DNT: 1
HTTP/1.1 200 OK
Content-Length: 23646
Date: Mon, 30 Nov 2015 15:19:03 GMT
http://nas2:23424/mediabrowser/assets/flowplayer.serviiostreaming-1.0.10.swf
GET /mediabrowser/assets/flowplayer.serviiostreaming-1.0.10.swf HTTP/1.1
Host: nas2:23424
DNT: 1
HTTP/1.1 200 OK
Content-Length: 3600
http://nas2:23424/mediabrowser/assets/flowplayer.bitrateselect-3.2.13.swf
GET /mediabrowser/assets/flowplayer.bitrateselect-3.2.13.swf HTTP/1.1
Host: nas2:23424
DNT: 1
HTTP/1.1 200 OK
Content-Length: 33357
I´d guess that flowplayer-3.2.16.swf is loading additional swf files to become a fully working player. This doesn´t work over the proxy approach. As I´m not a flash guy, futher debugging is not possible for me.
I also checked, that SSL / https is not causing the issue. Even if I setup my proxy with plain http, the same problem occurs.
Does anybody have a working setup with Serviio 1.5.2 via an apache reverse proxy that allows to use the flash player?
TIA & best regards,
Christian
Post Wed Dec 02, 2015 10:55 pm
Re: apache reverse proxy - flash player not working
is the downloaded .swf file exactly the same, byte-by-byte, when downloaded directly and over the proxy? maybe it get's damaged somehow
tata-greis
Post Thu Dec 03, 2015 11:51 am
I checked both swf files, the md5 hash is identical (28988b912da5ef1d171ded2e22c41338).
Post Fri Dec 04, 2015 8:08 pm
Also check if there are any JavaScript errors in the browser's developer console.
tata-greis
Post Sat Dec 05, 2015 11:19 am
Only one warning:
12:13:51.100 Synchrone XMLHttpRequests am Haupt-Thread sollte nicht mehr verwendet werden, weil es nachteilige Effekte für das Erlebnis der Endbenutzer hat. Für weitere Hilfe siehe http://xhr.spec.whatwg.org/1 MediaBrowser-1.5.1-4.js:9:0
In English: Syncronous XMLHttpRequests in the main thread should no longer be used due to negative effects on the end user experience.
BUT, this warning also occures when I access the mediabrowser directly (and the flowplayer works as exptected), so I doubt that it may be the reason for the proxying issue.
tata-greis
Post Wed Dec 09, 2015 7:08 am
Hey guys, this has more than 120 views now. Are there any users out there who use Serviio behind an Apache proxy? I´d be very keen if I face a general problem or if it is an issue with my specific setup.
Does it work for you or do you face similar issues?
@zip: Many thanks for your support. I really appreciate it! If I can help with futher logs etc. pls let me know.
Users browsing this forum: Baidu [Spider], Google [Bot] and 95 guests
