Https stream
serpico
Post Sun Dec 06, 2015 5:06 pm
Https stream
Hello forum, I was playing RT News on my TV but suddenly it stopped working, so I went to their website to check if the stream URL has changed.
I don't remember if it was already HTTPS before. The current URL does work on VLC.
https://rt-a.akamaihd.net/ch_01@325605/720p.m3u8
Does serviio support HTTPS?
Post Mon Dec 07, 2015 5:25 pm
Re: Https stream
Yes, but not with the ffmpeg version distributed by zip which lacks the necessary libraries. My ticket #828 to add this has not been addressed even though it is as simple as using the latest build as distributed by zeranoe as I do. http://ffmpeg.zeranoe.com/builds/
However the link you posted for RT has changed. Yours returns a 404 "Not found". And the correct link as URL snooper will show still uses http.
Users browsing this forum: Google [Bot] and 105 guests
