m2ts videos have no audio
The videos look great but they don't have any audio. Am I missing a codec or is there a transcoding configuration problem? Any suggestions?
Complete name : F:\media\video\20100917\20100818_151142.m2ts
Format : BDAV
Format/Info : Blu-ray Video
File size : 63.4 MiB
Duration : 33s 461ms
Overall bit rate : 15.9 Mbps
Maximum Overall bit rate : 18.0 Mbps
Menu ID : 1 (0x1)
Format : AVC
Format profile : High@L4
Format settings, CABAC : Yes
Format settings, ReFrames : 4 frames
Format settings, GOP : M=3, N=15
Codec ID : 27
Duration : 33s 467ms
Bit rate mode : Variable
Bit rate : 14.9 Mbps
Maximum bit rate : 16.8 Mbps
Width : 1 920 pixels
Height : 1 080 pixels
Display aspect ratio : 16:9
Frame rate : 29.970 (30000/1001) fps
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Interlaced
Scan type, store method : Separated fields
Scan order : Top Field First
Bits/(Pixel*Frame) : 0.239
Stream size : 59.4 MiB (94%)
Menu ID : 1 (0x1)
Format : AC-3
Format/Info : Audio Coding 3
Codec ID : 129
Duration : 33s 536ms
Bit rate mode : Constant
Bit rate : 384 Kbps
Channel(s) : 6 channels
Sampling rate : 48.0 KHz
Frame rate : 31.250 fps (1536 spf)
Compression mode : Lossy
Delay relative to video : -66ms
Stream size : 1.54 MiB (2%)
Text
Menu ID : 1 (0x1)
Format : PGS
Codec ID : 144
Duration : 32s 969ms
Users browsing this forum: Baidu [Spider] and 23 guests
