Mediabrowser Profile Selection
Post Mon Dec 14, 2015 4:41 am
Zip, how does one select a different application-profile?
Currently Mediabrowser on the PC issues GET...profile=flv_player, whereas on both the IPAD and Android it issues GET...profile=ios.
I would like to have a different profile used for Android, but using detection of <User-Agent>.*Android.*</User-Agent> is being ignored.
I would expect the default profile=ios to be used by the GET only if there is no application-profile with a matching User-Agent.
If this is not possible, where in the code can I find the logic that decides to use what profile= to set so I can alter it to profile=Android for Android devices?
Post Mon Dec 14, 2015 7:16 pm
Re: Mediabrowser Profile Selection
It's inside the javaScript code, based on User-Agent. You won't be able to change that easily, as the code is minified.
Post Tue Dec 15, 2015 2:03 pm
zip wrote:It's inside the javaScript code, based on User-Agent. You won't be able to change that easily, as the code is minified.
Easiest mod I ever made! Unzip jar,extract js, edit, delete ||ifAndroid(), add ifAndroid()?"android":, save js, zip into jar. Voila!!
MediaBrowser-1.5.1-4.js
Modified to add android profile
(407.22 KiB) Downloaded 814 times
