.avi and some .mkv files problems
vibreaza
Post Wed Dec 16, 2015 1:05 pm
Hello guys,
My first post here, I just discovered serviio and it's awesome!
Now my problem, I have a Panasonic TX-48AS640 tv which with normal DLNA home server wouldn't read .srt subtitles, I managed to set it up with serviio, I can see the subtitles and play most of mkv files (there are some exceptions where the image would freeze, I will show an example below) with the Panasonic G/GT/DT (2011/2012) profile, but I can't play any .avi files.
It shows an exclamation mark and "file not supported" message. I tried all panasonic profiles and all show the exclamation mark.
The generic profile doesn't show the !, but still the "file not supported" is present.
I tried with enable transcoding on and off, to no avail.
Complete name                            : D:\Seriale\Stargate\Stargate SG-1 - [1x01] - Children of the Gods.avi
Format                                   : AVI
Format/Info                              : Audio Video Interleave
File size                                : 702 MiB
Duration                                 : 1h 36mn
Overall bit rate                         : 1 012 Kbps
Writing application                      : Nandub v0.22
Format                                   : MPEG-4 Visual
Codec ID                                 : DIV3
Codec ID/Hint                            : DivX 3 Low
Duration                                 : 1h 36mn
Bit rate                                 : 814 Kbps
Width                                    : 640 pixels
Height                                   : 360 pixels
Bits/(Pixel*Frame)                       : 0.147
Stream size                              : 565 MiB (80%)
Format profile                           : Dolby Digital
Codec ID                                 : 2000
Duration                                 : 1h 36mn
Bit rate                                 : 192 Kbps
Frame rate                               : 31.250 fps (1536 spf)
Stream size                              : 133 MiB (19%)
Alignment                                : Aligned on interleaves
Interleave, duration                     : 160 ms (3.84 video frames)
Interleave, preload duration             : 160 ms
Language                                 : Undefined
c:\Program Files\Serviio\lib>ffmpeg.exe -i "D:\Seriale\Stargate\Stargate SG-1 - [1x01] - Children of the Gods.avi
ffmpeg version 2.3.3 Copyright (c) 2000-2014 the FFmpeg developers
  built on Sep 10 2014 22:27:46 with gcc 4.8.2 (GCC)
  configuration: --arch=x86_64 --target-os=mingw32 --cross-prefix=/home/julian/f
fmpeg-windows-build-helpers/sandbox/mingw-w64-x86_64/bin/x86_64-w64-mingw32- --p
kg-config=pkg-config --enable-gpl --enable-libx264 --enable-avisynth --enable-li
bxvid --enable-libmp3lame --enable-version3 --enable-zlib --enable-librtmp --ena
ble-libvorbis --enable-libtheora --enable-libspeex --enable-libopenjpeg --enable
-gnutls --enable-libgsm --enable-libfreetype --enable-libopus --disable-w32threa
ds --enable-frei0r --enable-filter=frei0r --enable-libvo-aacenc --enable-bzlib -
-enable-libxavs --extra-cflags=-DPTW32_STATIC_LIB --enable-libopencore-amrnb --e
nable-libopencore-amrwb --enable-libvo-amrwbenc --enable-libschroedinger --enabl
e-libvpx --enable-libilbc --prefix=/home/julian/ffmpeg-windows-build-helpers/san
dbox/mingw-w64-x86_64/x86_64-w64-mingw32 --enable-static --disable-shared --enab
le-libsoxr --enable-fontconfig --enable-libass --enable-libutvideo --enable-libb
luray --enable-iconv --enable-libtwolame --extra-cflags=-DLIBTWOLAME_STATIC --en
able-libzvbi --enable-libcaca --enable-libmodplug --extra-libs=-lstdc++ --extra-
libs=-lpng --enable-libvidstab --enable-libx265 --extra-cflags= --extra-cflags=
--enable-runtime-cpudetect
  libavutil      52. 92.100 / 52. 92.100
  libavcodec     55. 69.100 / 55. 69.100
  libavformat    55. 48.100 / 55. 48.100
  libavdevice    55. 13.102 / 55. 13.102
  libavfilter     4. 11.100 /  4. 11.100
  libswscale      2.  6.100 /  2.  6.100
  libswresample   0. 19.100 /  0. 19.100
Input #0, avi, from 'D:\Seriale\Stargate\Stargate SG-1 - [1x01] - Children of the Gods.avi':
    encoder         : Nandub v0.22
  Duration: 01:36:57.02, start: 0.000000, bitrate: 1012 kb/s
    Stream #0:0: Video: msmpeg4v3 (DIV3 / 0x33564944), yuv420p, 640x360, 814 kb/
s, 23.98 fps, 23.98 tbr, 23.98 tbn, 23.98 tbc
    Stream #0:1: Audio: ac3 ([0] [0][0] / 0x2000), 48000 Hz, stereo, fltp, 192 k
b/s
Now, I show you an example of a mkv file that stutter and it's unplayable
Unique ID                                : 178678079266186027256768246530519603762 (0x866C2575A6323110934CA881D86C1A32)
Complete name                            : D:\Filme\Mission.Impossible.Rogue.Nation.2015.720p.BluRay.DD5.1.x264.RoSubbed-playHD.mkv
Format version                           : Version 4 / Version 2
File size                                : 8.39 GiB
Duration                                 : 2h 11mn
Overall bit rate                         : 9 126 Kbps
Encoded date                             : UTC 2015-11-05 20:09:55
Writing application                      : mkvmerge v8.0.0 ('Til The Day That I Die') 64bit
Writing library                          : libebml v1.3.1 + libmatroska v1.4.2
Format settings, ReFrames                : 12 frames
Duration                                 : 2h 11mn
Bit rate                                 : 8 484 Kbps
Height                                   : 536 pixels
Display aspect ratio                     : 2.40:1
Frame rate                               : 23.976 (24000/1001) fps
Bits/(Pixel*Frame)                       : 0.516
Stream size                              : 7.80 GiB (93%)
Writing library                          : x264 core 148 r2638 7599210
Encoding settings                        : cabac=1 / ref=12 / deblock=1:-3:-3 / analyse=0x3:0x133 / me=umh / subme=10 / psy=1 / psy_rd=1.00:0.00 / mixed_ref=1 / me_range=32 / chroma_me=1 / trellis=2 / 8x8dct=1 / cqm=0 / deadzone=21,11 / fast_pskip=0 / chroma_qp_offset=-2 / threads=17 / lookahead_threads=2 / sliced_threads=0 / nr=0 / decimate=0 / interlaced=0 / bluray_compat=0 / constrained_intra=0 / bframes=8 / b_pyramid=2 / b_adapt=2 / b_bias=0 / direct=3 / weightb=1 / open_gop=0 / weightp=2 / keyint=250 / keyint_min=23 / scenecut=40 / intra_refresh=0 / rc=crf / mbtree=0 / crf=16.4 / qcomp=0.60 / qpmin=0 / qpmax=69 / qpstep=4 / ip_ratio=1.30 / pb_ratio=1.20 / aq=3:0.80
Duration                                 : 2h 11mn
Bit rate                                 : 640 Kbps
Stream size                              : 602 MiB (7%)
Title                                    : English
Text
Format                                   : UTF-8
Codec ID                                 : S_TEXT/UTF8
Codec ID/Info                            : UTF-8 Plain Text
Duration                                 : 2h 3mn
Bit rate                                 : 52 bps
Count of elements                        : 1217
Stream size                              : 47.4 KiB (0%)
Title                                    : Romanian
Language                                 : Romanian
Forced                                   : Yes
Menu
00:00:00.000                             : en:00:00:00.000
00:09:53.092                             : en:00:09:53.092
00:20:45.703                             : en:00:20:45.703
00:25:32.072                             : en:00:25:32.072
00:32:00.669                             : en:00:32:00.669
00:40:03.443                             : en:00:40:03.443
00:49:35.556                             : en:00:49:35.556
01:01:01.157                             : en:01:01:01.157
01:09:51.687                             : en:01:09:51.687
01:20:20.858                             : en:01:20:20.858
01:29:29.322                             : en:01:29:29.322
01:38:32.824                             : en:01:38:32.824
01:48:19.410                             : en:01:48:19.410
01:57:13.944                             : en:01:57:13.944
02:03:02.709                             : en:02:03:02.709
c:\Program Files\Serviio\lib>ffmpeg.exe -i "D:\Filme\Mission.Impossible.Rogue.Nat
Input #0, matroska,webm, from 'D:\Filme\Mission.Impossible.Rogue.Nation.2015.720p
.BluRay.DD5.1.x264.RoSubbed-playHD.mkv':
    encoder         : libebml v1.3.1 + libmatroska v1.4.2
    creation_time   : 2015-11-05 20:09:55
  Duration: 02:11:33.79, start: 0.000000, bitrate: 9126 kb/s
    Chapter #0.0: start 0.000000, end 593.092000
      title           : 00:00:00.000
    Chapter #0.1: start 593.092000, end 1245.703000
      title           : 00:09:53.092
    Chapter #0.2: start 1245.703000, end 1532.072000
      title           : 00:20:45.703
    Chapter #0.3: start 1532.072000, end 1920.669000
      title           : 00:25:32.072
    Chapter #0.4: start 1920.669000, end 2403.443000
      title           : 00:32:00.669
    Chapter #0.5: start 2403.443000, end 2975.556000
      title           : 00:40:03.443
    Chapter #0.6: start 2975.556000, end 3661.157000
      title           : 00:49:35.556
    Chapter #0.7: start 3661.157000, end 4191.687000
      title           : 01:01:01.157
    Chapter #0.8: start 4191.687000, end 4820.858000
      title           : 01:09:51.687
    Chapter #0.9: start 4820.858000, end 5369.322000
      title           : 01:20:20.858
    Chapter #0.10: start 5369.322000, end 5912.824000
      title           : 01:29:29.322
    Chapter #0.11: start 5912.824000, end 6499.410000
      title           : 01:38:32.824
    Chapter #0.12: start 6499.410000, end 7033.944000
      title           : 01:48:19.410
    Chapter #0.13: start 7033.944000, end 7382.709000
      title           : 01:57:13.944
    Chapter #0.14: start 7382.709000, end 7893.792000
      title           : 02:03:02.709
    Stream #0:0(eng): Video: h264 (High), yuv420p, 1280x536, SAR 1:1 DAR 160:67,
 23.98 fps, 23.98 tbr, 1k tbn, 47.95 tbc (default)
      BPS             : 8484372
      BPS-eng         : 8484372
      DURATION        : 02:11:33.761000000
      DURATION-eng    : 02:11:33.761000000
      NUMBER_OF_FRAMES: 189261
      NUMBER_OF_FRAMES-eng: 189261
      NUMBER_OF_BYTES : 8371701482
      NUMBER_OF_BYTES-eng: 8371701482
      _STATISTICS_WRITING_APP: mkvmerge v8.0.0 ('Til The Day That I Die') 64bit
      _STATISTICS_WRITING_APP-eng: mkvmerge v8.0.0 ('Til The Day That I Die') 64
bit
      _STATISTICS_WRITING_DATE_UTC: 2015-11-05 20:09:55
      _STATISTICS_WRITING_DATE_UTC-eng: 2015-11-05 20:09:55
      _STATISTICS_TAGS: BPS DURATION NUMBER_OF_FRAMES NUMBER_OF_BYTES
      _STATISTICS_TAGS-eng: BPS DURATION NUMBER_OF_FRAMES NUMBER_OF_BYTES
    Stream #0:1(eng): Audio: ac3, 48000 Hz, 5.1(side), fltp, 640 kb/s (default)
      title           : English
      BPS             : 640000
      BPS-eng         : 640000
      DURATION        : 02:11:33.792000000
      DURATION-eng    : 02:11:33.792000000
      NUMBER_OF_FRAMES: 246681
      NUMBER_OF_FRAMES-eng: 246681
      NUMBER_OF_BYTES : 631503360
      NUMBER_OF_BYTES-eng: 631503360
bit
    Stream #0:2(rum): Subtitle: subrip (default) (forced)
      title           : Romanian
      BPS             : 52
      BPS-eng         : 52
      DURATION        : 02:03:38.856000000
      DURATION-eng    : 02:03:38.856000000
      NUMBER_OF_FRAMES: 1217
      NUMBER_OF_FRAMES-eng: 1217
      NUMBER_OF_BYTES : 48544
      NUMBER_OF_BYTES-eng: 48544
bit
And now one that plays perfectly:
Unique ID                                : 249039335780841037137209103102919289768 (0xBB5B3B3DC1633B56BCFAA2C05593ABA8)
Complete name                            : D:\Filme\The.Man.From.UNCLE.2015.1080p.BluRay.DD5.1.x264-HDMaNiAcS.mkv
File size                                : 12.6 GiB
Duration                                 : 1h 56mn
Overall bit rate                         : 15.5 Mbps
Movie name                               : The.Man.From.UNCLE.2015.1080p.BluRay.DD5.1.x264-HDMaNiAcS
Encoded date                             : UTC 2015-11-07 12:27:28
Writing application                      : mkvmerge v8.5.1 ('Where you lead I will follow') 64bit
Writing library                          : libebml v1.3.3 + libmatroska v1.4.4
Format settings, ReFrames                : 5 frames
Duration                                 : 1h 56mn
Bit rate                                 : 14.8 Mbps
Height                                   : 800 pixels
Bits/(Pixel*Frame)                       : 0.402
Stream size                              : 12.1 GiB (96%)
Writing library                          : x264 core 146 r2538 121396c
Encoding settings                        : cabac=1 / ref=5 / deblock=1:-3:-3 / analyse=0x3:0x133 / me=umh / subme=10 / psy=1 / psy_rd=1.00:0.00 / mixed_ref=1 / me_range=32 / chroma_me=1 / trellis=2 / 8x8dct=1 / cqm=0 / deadzone=21,11 / fast_pskip=0 / chroma_qp_offset=-2 / threads=36 / lookahead_threads=6 / sliced_threads=0 / nr=0 / decimate=0 / interlaced=0 / bluray_compat=0 / constrained_intra=0 / bframes=12 / b_pyramid=2 / b_adapt=2 / b_bias=0 / direct=3 / weightb=1 / open_gop=0 / weightp=2 / keyint=240 / keyint_min=23 / scenecut=40 / intra_refresh=0 / rc_lookahead=100 / rc=crf / mbtree=0 / crf=15.5 / qcomp=0.60 / qpmin=0 / qpmax=69 / qpstep=4 / vbv_maxrate=62500 / vbv_bufsize=78125 / crf_max=0.0 / nal_hrd=none / filler=0 / ip_ratio=1.40 / pb_ratio=1.30 / aq=1:0.80
Duration                                 : 1h 56mn
Bit rate                                 : 640 Kbps
Stream size                              : 533 MiB (4%)
Text #1
Format                                   : UTF-8
Duration                                 : 1h 53mn
Bit rate                                 : 50 bps
Count of elements                        : 1331
Stream size                              : 41.7 KiB (0%)
Text #2
Format                                   : UTF-8
Duration                                 : 1h 55mn
Bit rate                                 : 43 bps
Count of elements                        : 1269
Stream size                              : 36.6 KiB (0%)
Language                                 : French
Text #3
Format                                   : UTF-8
Duration                                 : 1h 56mn
Bit rate                                 : 49 bps
Count of elements                        : 1293
Stream size                              : 41.9 KiB (0%)
Language                                 : Spanish
Text #4
Format                                   : UTF-8
Duration                                 : 1h 56mn
Bit rate                                 : 47 bps
Count of elements                        : 1247
Stream size                              : 40.3 KiB (0%)
Language                                 : Portuguese
Menu
00:00:00.000                             : en:Chapter 1
00:15:19.085                             : en:Chapter 2
00:23:11.682                             : en:Chapter 3
00:32:09.302                             : en:Chapter 4
00:40:36.059                             : en:Chapter 5
00:49:07.570                             : en:Chapter 6
00:59:23.560                             : en:Chapter 7
01:08:52.837                             : en:Chapter 8
01:20:28.115                             : en:Chapter 9
01:29:47.674                             : en:Chapter 10
01:43:21.362                             : en:Chapter 11
01:49:23.432                             : en:Chapter 12
c:\Program Files\Serviio\lib>ffmpeg.exe -i "D:\Filme\The.Man.From.UNCLE.2015.1080p.BluRay.DD5.1.x26
4-HDMaNiAcS.mkv
Input #0, matroska,webm, from 'D:\Filme\The.Man.From.UNCLE.2015.1080p.BluRay.DD5.1.x264-HDMaNiAcS.m
kv':
    title           : The.Man.From.UNCLE.2015.1080p.BluRay.DD5.1.x264-HDMaNiAcS
    encoder         : libebml v1.3.3 + libmatroska v1.4.4
    creation_time   : 2015-11-07 12:27:28
  Duration: 01:56:29.76, start: 0.000000, bitrate: 15461 kb/s
    Chapter #0.0: start 0.000000, end 919.085000
      title           : Chapter 1
    Chapter #0.1: start 919.085000, end 1391.682000
      title           : Chapter 2
    Chapter #0.2: start 1391.682000, end 1929.302000
      title           : Chapter 3
    Chapter #0.3: start 1929.302000, end 2436.059000
      title           : Chapter 4
    Chapter #0.4: start 2436.059000, end 2947.570000
      title           : Chapter 5
    Chapter #0.5: start 2947.570000, end 3563.560000
      title           : Chapter 6
    Chapter #0.6: start 3563.560000, end 4132.837000
      title           : Chapter 7
    Chapter #0.7: start 4132.837000, end 4828.115000
      title           : Chapter 8
    Chapter #0.8: start 4828.115000, end 5387.674000
      title           : Chapter 9
    Chapter #0.9: start 5387.674000, end 6201.362000
      title           : Chapter 10
    Chapter #0.10: start 6201.362000, end 6563.432000
      title           : Chapter 11
    Chapter #0.11: start 6563.432000, end 6989.760000
      title           : Chapter 12
    Stream #0:0: Video: h264 (High), yuv420p, 1920x800 [SAR 1:1 DAR 12:5], 23.98
      BPS             : 14819617
      BPS-eng         : 14819617
      DURATION        : 01:56:29.733000000
      DURATION-eng    : 01:56:29.733000000
      NUMBER_OF_FRAMES: 167586
      NUMBER_OF_FRAMES-eng: 167586
      NUMBER_OF_BYTES : 12948146185
      NUMBER_OF_BYTES-eng: 12948146185
      _STATISTICS_WRITING_APP: mkvmerge v8.5.1 ('Where you lead I will follow')
64bit
      _STATISTICS_WRITING_APP-eng: mkvmerge v8.5.1 ('Where you lead I will follo
w') 64bit
      _STATISTICS_WRITING_DATE_UTC: 2015-11-07 12:27:28
      _STATISTICS_WRITING_DATE_UTC-eng: 2015-11-07 12:27:28
      BPS             : 640000
      BPS-eng         : 640000
      DURATION        : 01:56:29.760000000
      DURATION-eng    : 01:56:29.760000000
      NUMBER_OF_FRAMES: 218430
      NUMBER_OF_FRAMES-eng: 218430
      NUMBER_OF_BYTES : 559180800
      NUMBER_OF_BYTES-eng: 559180800
64bit
w') 64bit
    Stream #0:2(eng): Subtitle: subrip (default)
      BPS             : 50
      BPS-eng         : 50
      DURATION        : 01:53:41.690000000
      DURATION-eng    : 01:53:41.690000000
      NUMBER_OF_FRAMES: 1331
      NUMBER_OF_FRAMES-eng: 1331
      NUMBER_OF_BYTES : 42672
      NUMBER_OF_BYTES-eng: 42672
64bit
w') 64bit
    Stream #0:3(fre): Subtitle: subrip
      BPS             : 43
      BPS-eng         : 43
      DURATION        : 01:55:40.225000000
      DURATION-eng    : 01:55:40.225000000
      NUMBER_OF_FRAMES: 1269
      NUMBER_OF_FRAMES-eng: 1269
      NUMBER_OF_BYTES : 37436
      NUMBER_OF_BYTES-eng: 37436
64bit
w') 64bit
    Stream #0:4(spa): Subtitle: subrip
      BPS             : 49
      BPS-eng         : 49
      DURATION        : 01:56:01.455000000
      DURATION-eng    : 01:56:01.455000000
      NUMBER_OF_FRAMES: 1293
      NUMBER_OF_FRAMES-eng: 1293
      NUMBER_OF_BYTES : 42855
      NUMBER_OF_BYTES-eng: 42855
64bit
w') 64bit
    Stream #0:5(por): Subtitle: subrip
      BPS             : 47
      BPS-eng         : 47
      NUMBER_OF_FRAMES: 1247
      NUMBER_OF_FRAMES-eng: 1247
      NUMBER_OF_BYTES : 41237
      NUMBER_OF_BYTES-eng: 41237
64bit
w') 64bit
Can I modify something in the profile to make this work? Any help would be greatly appreciated!
If you need any other details please let me know.
Thank you very much! :mrgreen:
LE: I tried the Panasonic Viera E/S/ST/VT (2011) renderer profile which transcodes the avi's, now I can play it, but with this profile there's no way I can see the subtitles. Avi files problem partially solved. Any tip on how to enable subtitles from .srt? Like import the subtitles settings from Vieira G/GT/DT (2011/2012) to Viera E/S/ST/VT (2011)? Which lines of code?
Sorry for bothering you with this, but maybe we can create a profile for these types of tvs?
Here is the field Sink from DeviceSpy:
http-get:*:image/jpeg:DLNA.ORG_PN=JPEG_SM;DLNA.ORG_FLAGS=8c900000000000000000000000000000,http-get:*:image/jpeg:DLNA.ORG_PN=JPEG_MED;DLNA.ORG_FLAGS=8c900000000000000000000000000000,http-get:*:image/jpeg:DLNA.ORG_PN=JPEG_LRG;DLNA.ORG_FLAGS=8c900000000000000000000000000000,http-get:*:image/jpeg:DLNA.ORG_PN=JPEG_TN;DLNA.ORG_FLAGS=8c900000000000000000000000000000,http-get:*:image/jpeg:DLNA.ORG_PN=JPEG_SM_ICO;DLNA.ORG_FLAGS=8c900000000000000000000000000000,http-get:*:image/jpeg:DLNA.ORG_PN=JPEG_LRG_ICO;DLNA.ORG_FLAGS=8c900000000000000000000000000000,http-get:*:video/mpeg:DLNA.ORG_PN=MPEG_PS_PAL;DLNA.ORG_FLAGS=8d100000000000000000000000000000,http-get:*:video/mpeg:DLNA.ORG_PN=MPEG_PS_PAL_XAC3;DLNA.ORG_FLAGS=8d100000000000000000000000000000,http-get:*:application/x-dtcp1;CONTENTFORMAT="video/mpeg":DLNA.ORG_PN=DTCP_MPEG_PS_PAL;DLNA.ORG_FLAGS=8d118000000000000000000000000000,http-get:*:application/x-dtcp1;CONTENTFORMAT="video/mpeg":DLNA.ORG_PN=DTCP_MPEG_PS_PAL_XAC3;DLNA.ORG_FLAGS=8d118000000000000000000000000000,http-get:*:video/mpeg:DLNA.ORG_PN=MPEG_PS_NTSC;DLNA.ORG_FLAGS=8d100000000000000000000000000000,http-get:*:video/mpeg:DLNA.ORG_PN=MPEG_PS_NTSC_XAC3;DLNA.ORG_FLAGS=8d100000000000000000000000000000,http-get:*:application/x-dtcp1;CONTENTFORMAT="video/mpeg":DLNA.ORG_PN=DTCP_MPEG_PS_NTSC;DLNA.ORG_FLAGS=8d118000000000000000000000000000,http-get:*:application/x-dtcp1;CONTENTFORMAT="video/mpeg":DLNA.ORG_PN=DTCP_MPEG_PS_NTSC_XAC3;DLNA.ORG_FLAGS=8d118000000000000000000000000000,http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=MPEG_TS_SD_EU_T;DLNA.ORG_FLAGS=8d100000000000000000000000000000,http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=MPEG_TS_SD_EU;DLNA.ORG_FLAGS=8d100000000000000000000000000000,http-get:*:video/mpeg:DLNA.ORG_PN=MPEG_TS_SD_EU_ISO;DLNA.ORG_FLAGS=8d100000000000000000000000000000,http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=MPEG_TS_SD_EU_AC3_T;DLNA.ORG_FLAGS=8d100000000000000000000000000000,http-get:*:video/mpeg:DLNA.ORG_PN=MPEG_TS_SD_EU_AC3_ISO;DLNA.ORG_FLAGS=8d100000000000000000000000000000,http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=AVC_TS_HD_50_AC3_T;DLNA.ORG_FLAGS=8d100000000000000000000000000000,http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=AVC_TS_HD_50_AC3;DLNA.ORG_FLAGS=8d100000000000000000000000000000,http-get:*:video/mpeg:DLNA.ORG_PN=AVC_TS_HD_50_AC3_ISO;DLNA.ORG_FLAGS=8d100000000000000000000000000000,http-get:*:application/x-dtcp1;CONTENTFORMAT="video/vnd.dlna.mpeg-tts":DLNA.ORG_PN=DTCP_MPEG_TS_SD_EU_T;DLNA.ORG_FLAGS=8d118000000000000000000000000000,http-get:*:application/x-dtcp1;CONTENTFORMAT="video/vnd.dlna.mpeg-tts":DLNA.ORG_PN=DTCP_MPEG_TS_SD_EU;DLNA.ORG_FLAGS=8d118000000000000000000000000000,http-get:*:application/x-dtcp1;CONTENTFORMAT="video/mpeg":DLNA.ORG_PN=DTCP_MPEG_TS_SD_EU_ISO;DLNA.ORG_FLAGS=8d118000000000000000000000000000,http-get:*:application/x-dtcp1;CONTENTFORMAT="video/vnd.dlna.mpeg-tts":DLNA.ORG_PN=DTCP_MPEG_TS_SD_EU_AC3_T;DLNA.ORG_FLAGS=8d118000000000000000000000000000,http-get:*:application/x-dtcp1;CONTENTFORMAT="video/mpeg":DLNA.ORG_PN=DTCP_MPEG_TS_SD_EU_AC3_ISO;DLNA.ORG_FLAGS=8d118000000000000000000000000000,http-get:*:application/x-dtcp1;CONTENTFORMAT="video/vnd.dlna.mpeg-tts":DLNA.ORG_PN=DTCP_AVC_TS_HD_50_AC3_T;DLNA.ORG_FLAGS=8d118000000000000000000000000000,http-get:*:application/x-dtcp1;CONTENTFORMAT="video/vnd.dlna.mpeg-tts":DLNA.ORG_PN=DTCP_AVC_TS_HD_50_AC3;DLNA.ORG_FLAGS=8d118000000000000000000000000000,http-get:*:application/x-dtcp1;CONTENTFORMAT="video/mpeg":DLNA.ORG_PN=DTCP_AVC_TS_HD_50_AC3_ISO;DLNA.ORG_FLAGS=8d118000000000000000000000000000,http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=MPEG_TS_JP_T;DLNA.ORG_FLAGS=8d100000000000000000000000000000,http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=MPEG_TS_SD_JP_MPEG1_L2_T;DLNA.ORG_FLAGS=8d100000000000000000000000000000,http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=AVC_TS_JP_AAC_T;DLNA.ORG_FLAGS=8d100000000000000000000000000000,http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=MPEG_TS_SD_NA_T;DLNA.ORG_FLAGS=8d100000000000000000000000000000,http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=MPEG_TS_SD_NA;DLNA.ORG_FLAGS=8d100000000000000000000000000000,http-get:*:video/mpeg:DLNA.ORG_PN=MPEG_TS_SD_NA_ISO;DLNA.ORG_FLAGS=8d100000000000000000000000000000,http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=MPEG_TS_HD_NA_T;DLNA.ORG_FLAGS=8d100000000000000000000000000000,http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=MPEG_TS_HD_NA;DLNA.ORG_FLAGS=8d100000000000000000000000000000,http-get:*:video/mpeg:DLNA.ORG_PN=MPEG_TS_HD_NA_ISO;DLNA.ORG_FLAGS=8d100000000000000000000000000000,http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=MPEG_TS_SD_60_AC3_T;DLNA.ORG_FLAGS=8d100000000000000000000000000000,http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=AVC_TS_HD_60_AC3_X_T;DLNA.ORG_FLAGS=8d100000000000000000000000000000,http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=AVC_TS_HD_60_AC3_T;DLNA.ORG_FLAGS=8d100000000000000000000000000000,http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=AVC_TS_HD_60_AC3;DLNA.ORG_FLAGS=8d100000000000000000000000000000,http-get:*:video/mpeg:DLNA.ORG_PN=AVC_TS_HD_60_AC3_ISO;DLNA.ORG_FLAGS=8d100000000000000000000000000000,http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=AVC_TS_HD_24_AC3_T;DLNA.ORG_FLAGS=8d100000000000000000000000000000,http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=AVC_TS_HD_24_AC3;DLNA.ORG_FLAGS=8d100000000000000000000000000000,http-get:*:video/mpeg:DLNA.ORG_PN=AVC_TS_HD_24_AC3_ISO;DLNA.ORG_FLAGS=8d100000000000000000000000000000,http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=AVC_TS_MP_HD_AAC_LTP_T;DLNA.ORG_FLAGS=8d100000000000000000000000000000,http-get:*:application/x-dtcp1;CONTENTFORMAT="video/vnd.dlna.mpeg-tts":DLNA.ORG_PN=DTCP_MPEG_TS_JP_T;ARIB.OR.JP_PN=MPEG_TTS_CP;DLNA.ORG_FLAGS=8d118000000000000000000000000000,http-get:*:application/x-dtcp1;CONTENTFORMAT="video/vnd.dlna.mpeg-tts":DLNA.ORG_PN=DTCP_MPEG_TS_SD_JP_MPEG1_L2_T;DLNA.ORG_FLAGS=8d118000000000000000000000000000,http-get:*:application/x-dtcp1;CONTENTFORMAT="video/vnd.dlna.mpeg-tts":DLNA.ORG_PN=DTCP_AVC_TS_JP_AAC_T;DLNA.ORG_FLAGS=8d118000000000000000000000000000,http-get:*:application/x-dtcp1;CONTENTFORMAT="video/vnd.dlna.mpeg-tts":DLNA.ORG_PN=DTCP_MPEG_TS_SD_NA_T;DLNA.ORG_FLAGS=8d118000000000000000000000000000,http-get:*:application/x-dtcp1;CONTENTFORMAT="video/vnd.dlna.mpeg-tts":DLNA.ORG_PN=DTCP_MPEG_TS_SD_NA;DLNA.ORG_FLAGS=8d118000000000000000000000000000,http-get:*:application/x-dtcp1;CONTENTFORMAT="video/mpeg":DLNA.ORG_PN=DTCP_MPEG_TS_SD_NA_ISO;DLNA.ORG_FLAGS=8d118000000000000000000000000000,http-get:*:application/x-dtcp1;CONTENTFORMAT="video/vnd.dlna.mpeg-tts":DLNA.ORG_PN=DTCP_MPEG_TS_HD_NA_T;DLNA.ORG_FLAGS=8d118000000000000000000000000000,http-get:*:application/x-dtcp1;CONTENTFORMAT="video/vnd.dlna.mpeg-tts":DLNA.ORG_PN=DTCP_MPEG_TS_HD_NA;DLNA.ORG_FLAGS=8d118000000000000000000000000000,http-get:*:application/x-dtcp1;CONTENTFORMAT="video/mpeg":DLNA.ORG_PN=DTCP_MPEG_TS_HD_NA_ISO;DLNA.ORG_FLAGS=8d118000000000000000000000000000,http-get:*:application/x-dtcp1;CONTENTFORMAT="video/vnd.dlna.mpeg-tts":DLNA.ORG_PN=DTCP_MPEG_TS_SD_60_AC3_T;DLNA.ORG_FLAGS=8d118000000000000000000000000000,http-get:*:application/x-dtcp1;CONTENTFORMAT="video/vnd.dlna.mpeg-tts":DLNA.ORG_PN=DTCP_AVC_TS_HD_60_AC3_X_T;DLNA.ORG_FLAGS=8d118000000000000000000000000000,http-get:*:application/x-dtcp1;CONTENTFORMAT="video/vnd.dlna.mpeg-tts":DLNA.ORG_PN=DTCP_AVC_TS_HD_60_AC3_T;DLNA.ORG_FLAGS=8d118000000000000000000000000000,http-get:*:application/x-dtcp1;CONTENTFORMAT="video/vnd.dlna.mpeg-tts":DLNA.ORG_PN=DTCP_AVC_TS_HD_60_AC3;DLNA.ORG_FLAGS=8d118000000000000000000000000000,http-get:*:application/x-dtcp1;CONTENTFORMAT="video/mpeg":DLNA.ORG_PN=DTCP_AVC_TS_HD_60_AC3_ISO;DLNA.ORG_FLAGS=8d118000000000000000000000000000,http-get:*:application/x-dtcp1;CONTENTFORMAT="video/vnd.dlna.mpeg-tts":DLNA.ORG_PN=DTCP_AVC_TS_HD_24_AC3_T;DLNA.ORG_FLAGS=8d118000000000000000000000000000,http-get:*:application/x-dtcp1;CONTENTFORMAT="video/vnd.dlna.mpeg-tts":DLNA.ORG_PN=DTCP_AVC_TS_HD_24_AC3;DLNA.ORG_FLAGS=8d118000000000000000000000000000,http-get:*:application/x-dtcp1;CONTENTFORMAT="video/mpeg":DLNA.ORG_PN=DTCP_AVC_TS_HD_24_AC3_ISO;DLNA.ORG_FLAGS=8d118000000000000000000000000000,http-get:*:application/x-dtcp1;CONTENTFORMAT="video/vnd.dlna.mpeg-tts":DLNA.ORG_PN=DTCP_AVC_TS_MP_HD_AAC_LTP_T;DLNA.ORG_FLAGS=8d118000000000000000000000000000,http-get:*:audio/mpeg:DLNA.ORG_PN=MP3,http-get:*:audio/L16:DLNA.ORG_PN=LPCM,http-get:*:image/jpeg:PANASONIC.COM_PN=MPO_3D,http-get:*:image/jpeg:*,http-get:*:video/avi:*,http-get:*:video/x-msvideo:*,http-get:*:video/divx:*,http-get:*:video/x-matroska:*,http-get:*:video/mpeg:*,http-get:*:video/vnd.dlna.mpeg-tts:*,http-get:*:application/x-dtcp1;CONTENTFORMAT="video/mpeg":*,http-get:*:application/x-dtcp1;CONTENTFORMAT="video/vnd.dlna.mpeg-tts":*,http-get:*:video/mp4:*,http-get:*:video/x-flv:*,http-get:*:video/flv:*,http-get:*:video/x-ms-wmv:*,http-get:*:video/x-ms-asf:*,http-get:*:video/3gpp:*,http-get:*:video/3gpp2:*,http-get:*:audio/mpeg:*,http-get:*:audio/mp4:*,http-get:*:audio/x-m4a:*,http-get:*:audio/x-ms-wma:*,http-get:*:audio/x-ms-asf:*,http-get:*:audio/wav:*,http-get:*:audio/wave:*,http-get:*:audio/x-wav:*,http-get:*:audio/flac:*,http-get:*:audio/x-flac:*,http-get:*:audio/aac:*,http-get:*:audio/x-aac:*,http-get:*:audio/vnd.dlna.adts:*,http-get:*:audio/L16:*
Post Wed Dec 16, 2015 5:05 pm
Re: .avi and some .mkv files problems
Use the <Profile id="viera2013" name="Panasonic Viera (2013)" extendsProfileId="1"> then post what does not work.
Also looks like your worked/not worked are switched. The "worked" is far more complex than the "not worked" and it should be the one with any stuttering.
vibreaza
Post Wed Dec 16, 2015 6:33 pm
Hello jhb50 and thanks for your reply,
I already tried the profile Vieira 2013 profile before, it doesn't work.
The only one which works is Panasonic G/GT/DT (2011/2012) profile for most of the mkv's with transcoding off, and Panasonic Viera E/S/ST/VT (2011) for avi's with transcoding on, but the latter there are no subtitles.
Any other suggestions?
Also, I checked the worked/not worked, they are in the right order. What gives?
Post Wed Dec 16, 2015 8:17 pm
So use the 2013 as I said and play the 3 files and post the debug log for that as I said.
vibreaza
Post Wed Dec 16, 2015 9:37 pm
Sorry jhb50, I misread your request.
Attached is the debug log with the 2013 profile and transcoding enabled.
I played
-1 avi, it worked but no options for the .srt subtitles (Stargate SG-1 - [1x01] - Children of the Gods.avi)
-1 mkv, stuttering, unplayable, but with options for subtitles (Mission.Impossible.Rogue.Nation.2015.720p.BluRay.DD5.1.x264.RoSubbed-playHD.mkv)
-1 mkv which was read as MPEG2-TS - here the image was smaller, and couldn't load subtitles also. (A.Clockwork.Orange.1971.720p.BluRay.DTS.x264-CtrlHD.mkv)
-1 mkv working fine (The.Man.From.UNCLE.2015.1080p.BluRay.DD5.1.x264-HDMaNiAcS.mkv)
log.txt
(260.72 KiB) Downloaded 1069 times
vibreaza
Post Thu Dec 17, 2015 12:53 pm
Hello again,
As my TV is a 2014 model (Pana 48AS640) and there are no profiles on serviio for 2014 models, I installed mezzmo to try to see what profiles they use. I used their Panasonic 2014 profile and the avi files now have external subtitles options (they dont show as MPEG2-TS, they are displayed as VIDEO).
Can someone help make a profile for panasonic 2014 models based on the mezzmo profile?
I don't want to give up serviio, I find it simpler and I can use the basic version as well free.
I attach the mezzmo profile, maybe someone who knows could translate it into a serviio renderer profile.
TIA
PanasonicViera2014.prf.txt
(11.78 KiB) Downloaded 1098 times
Post Thu Dec 17, 2015 1:56 pm
I am still analyzing your previous log, but are you sure you have all the subtitle boxes clicked and the language set in the console/delivery/subtitle tab?
vibreaza
Post Fri Dec 18, 2015 12:52 pm
Hello jhb50 and sorry I replied a bit late,
I have all 3 subtitle boxes checked and the language set to ro,en in the console/delivery/subtitle tab, still all avi's are transformed in MPEG2-TS without subtitle option, or burned it.
Now, using 2013 profile as you suggested there are files (that otherwise can be played natively with subtitles - example an mkv below) which is transcoded to MPEG2-TS as well, losing aspect ratio and possibiliy to load subtitles.
Unique ID                                : 200661996180631833277946998389819676879 (0x96F6183F354856EEBD1FCC8020E598CF)
Complete name                            : D:\Torrentz\A.Clockwork.Orange.1971.720p.BluRay.DTS.x264-CtrlHD\A.Clockwork.Orange.1971.720p.BluRay.DTS.x264-CtrlHD.mkv
Format version                           : Version 1
File size                                : 4.38 GiB
Duration                                 : 2h 16mn
Overall bit rate                         : 4 585 Kbps
Encoded date                             : UTC 2007-11-03 13:48:15
Writing application                      : mkvmerge v2.1.0 ('Another Place To Fall') built on Aug 19 2007 13:40:07
Writing library                          : libebml v0.7.7 + libmatroska v0.8.1
Format profile                           : High@L5.1
Format settings, ReFrames                : 9 frames
Format settings, GOP                     : N=1
Duration                                 : 2h 16mn
Bit rate                                 : 3 070 Kbps
Width                                    : 1 200 pixels
Display aspect ratio                     : 5:3
Bits/(Pixel*Frame)                       : 0.148
Stream size                              : 2.85 GiB (65%)
Title                                    : A Clockwork Orange (1971)
Writing library                          : x264 core 56 svn-680
Encoding settings                        : cabac=1 / ref=6 / deblock=1:-3:-3 / analyse=0x3:0x133 / me=umh / subme=7 / brdo=1 / mixed_ref=1 / me_range=16 / chroma_me=1 / trellis=1 / 8x8dct=1 / cqm=2 / deadzone=21,11 / chroma_qp_offset=0 / threads=3 / nr=0 / decimate=0 / mbaff=0 / bframes=3 / b_pyramid=1 / b_adapt=1 / b_bias=0 / direct=3 / wpredb=1 / bime=1 / keyint=250 / keyint_min=25 / scenecut=40(pre) / rc=2pass / bitrate=3070 / ratetol=1.0 / rceq='blurCplx^(1-qComp)' / qcomp=0.60 / qpmin=10 / qpmax=51 / qpstep=4 / cplxblur=20.0 / qblur=0.5 / ip_ratio=1.40 / pb_ratio=1.30 / aq=1:0.3:15.0
Format                                   : DTS
Format/Info                              : Digital Theater Systems
Mode                                     : 16
Codec ID                                 : A_DTS
Duration                                 : 2h 16mn
Bit rate                                 : 1 510 Kbps
Frame rate                               : 93.750 fps (512 spf)
Bit depth                                : 24 bits
Stream size                              : 1.44 GiB (33%)
Title                                    : DTS 6 Channels 1536 kb/s
Text #1
Format                                   : SSA
Codec ID                                 : S_TEXT/SSA
Codec ID/Info                            : Sub Station Alpha
Compression mode                         : Lossless
Text #2
Format                                   : SSA
Language                                 : Danish
Text #3
Format                                   : SSA
Language                                 : Dutch
Text #4
Format                                   : SSA
Language                                 : Finnish
Text #5
Format                                   : SSA
Language                                 : French
Text #6
Format                                   : SSA
Language                                 : German
Text #7
Format                                   : SSA
Language                                 : Italian
Text #8
Format                                   : SSA
Language                                 : Norwegian
Text #9
Format                                   : SSA
Language                                 : Spanish
Text #10
Format                                   : SSA
Language                                 : Swedish
What I also noticed, using mezzmo, there are some .avi files which are not transcoded at all, being read as VIDEO , and they are played natively with option for subtitles. Normally, or using serviio, I can't play these "file not supported" without transcoding, and when they are transcoded to MPEG2-TS, I also lose subtitles options.
Here is an example
Complete name                            : D:\Torrentz\Defiance.S01.HDTV.XviD.RoSubbed-FL\Defiance.S01E01.HDTV.XviD-AFG.avi
Format                                   : AVI
File size                                : 695 MiB
Duration                                 : 1h 25mn
Overall bit rate                         : 1 136 Kbps
Format profile                           : Advanced Simple@L5
Format settings, BVOP                    : 2
Format settings, QPel                    : No
Format settings, GMC                     : No warppoints
Format settings, Matrix                  : Default (H.263)
Codec ID                                 : XVID
Codec ID/Hint                            : XviD
Duration                                 : 1h 25mn
Bit rate                                 : 995 Kbps
Width                                    : 640 pixels
Height                                   : 360 pixels
Frame rate                               : 23.976 (23976/1000) fps
Bits/(Pixel*Frame)                       : 0.180
Stream size                              : 609 MiB (88%)
Writing library                          : XviD 64
Format                                   : MPEG Audio
Format profile                           : Layer 3
Mode                                     : Joint stereo
Mode extension                           : MS Stereo
Codec ID                                 : 55
Codec ID/Hint                            : MP3
Duration                                 : 1h 25mn
Bit rate                                 : 128 Kbps
Stream size                              : 78.4 MiB (11%)
Interleave, duration                     : 24 ms (0.58 video frame)
Interleave, preload duration             : 178 ms
Title                                    : Defiance.S01E01.HDTV.XviD-AFG_360p.audio
Thanks and sorry for the headache I might give you, after searching a budget nice TV, I bought this Pana, but I didnt know it would be so problematic with subtitles and reading moive files... :cry:
vibreaza
Post Fri Dec 18, 2015 4:52 pm
Also, can you tell me what's the difference between these 4 mkv files?
2 of them play nicely natively, without any needs for transcoding, whereas the last 2 are unplayable (stuttering, not fluid).
WORKING:
ffmpeg version N-66094-gbb8b752 Copyright (c) 2000-2014 the FFmpeg developers
  built on Sep  4 2014 16:23:51 with gcc 4.8.2 (GCC)
  configuration: --enable-memalign-hack --arch=x86_64 --target-os=mingw32 --cross-prefix=x86_64-w64-mingw32- --enable-static --disable-shared --enable-zlib --disable-postproc --prefix=/home/peter/ffmpeg/build/gpl64 --enable-libmp3lame --enable-libx264 --enable-gpl --extra-libs='-lx264 -lpthread' --enable-runtime-cpudetect --extra-cflags=-I/home/peter/cc32/include --extra-ldflags=-L/home/peter/cc64/lib --pkg-config=pkg-config --disable-w32threads --enable-libvpx --enable-libvorbis
  libavutil      54.  7.100 / 54.  7.100
  libavcodec     56.  1.100 / 56.  1.100
  libavformat    56.  4.100 / 56.  4.100
  libavdevice    56.  0.100 / 56.  0.100
  libavfilter     5.  0.103 /  5.  0.103
  libswscale      3.  0.100 /  3.  0.100
  libswresample   1.  1.100 /  1.  1.100
Input #0, matroska,webm, from 'D:\Torrentz\A.Clockwork.Orange.1971.720p.BluRay.DTS.x264-CtrlHD\A.Clockwork.Orange.1971.720p.BluRay.DTS.x264-CtrlHD.mkv':
    encoder         : libebml v0.7.7 + libmatroska v0.8.1
    creation_time   : 2007-11-03 13:48:15
  Duration: 02:16:36.99, start: 0.000000, bitrate: 4584 kb/s
    Stream #0:0(eng): Video: h264 (High), yuv420p, 1200x720, SAR 1:1 DAR 5:3, 23.98 fps, 23.98 tbr, 1k tbn, 47.95 tbc (default)
      title           : A Clockwork Orange (1971)
    Stream #0:1(eng): Audio: dts (DTS), 48000 Hz, 5.1(side), fltp, 1536 kb/s (default)
      title           : DTS 6 Channels 1536 kb/s
    Stream #0:2(eng): Subtitle: ass (default)
    Stream #0:3(dan): Subtitle: ass
    Stream #0:4(dut): Subtitle: ass
    Stream #0:5(fin): Subtitle: ass
    Stream #0:6(fre): Subtitle: ass
    Stream #0:7(ger): Subtitle: ass
    Stream #0:8(ita): Subtitle: ass
    Stream #0:9(nor): Subtitle: ass
    Stream #0:10(spa): Subtitle: ass
    Stream #0:11(swe): Subtitle: ass
---> DB Level Info: 51, 100
---> Frame rate: 23.98
---> Aspect ratio: 5:3 PAR=1:1
---> Duration: 02:16:36
Input #0, matroska,webm, from 'D:\Torrentz\Beasts.of.No.Nation.2015.720p.WEBRiP.x264-QCF\Beasts.of.No.Nation.2015.720p.WEBRiP.x264-QCF.mkv':
    encoder         : libebml v1.3.0 + libmatroska v1.4.1
    creation_time   : 2015-10-17 22:13:45
  Duration: 02:16:34.60, start: 0.000000, bitrate: 3407 kb/s
    Stream #0:0(eng): Video: h264 (High), yuv420p, 1280x538 [SAR 1:1 DAR 640:269], 23.98 fps, 23.98 tbr, 1k tbn, 47.95 tbc (default)
      BPS             : 2765750
      BPS-eng         : 2765750
      DURATION        : 02:16:34.603000000
      DURATION-eng    : 02:16:34.603000000
      NUMBER_OF_FRAMES: 196474
      NUMBER_OF_FRAMES-eng: 196474
      NUMBER_OF_BYTES : 2833028806
      NUMBER_OF_BYTES-eng: 2833028806
      _STATISTICS_WRITING_APP: mkvmerge v7.4.0 ('Circles') 64bit built on Dec 12 2014 12:19:56
      _STATISTICS_WRITING_APP-eng: mkvmerge v7.4.0 ('Circles') 64bit built on Dec 12 2014 12:19:56
      _STATISTICS_WRITING_DATE_UTC: 2015-10-17 22:13:45
      _STATISTICS_WRITING_DATE_UTC-eng: 2015-10-17 22:13:45
    Stream #0:1: Audio: ac3, 48000 Hz, 5.1(side), fltp, 640 kb/s (default)
      BPS             : 640000
      BPS-eng         : 640000
      DURATION        : 02:16:34.528000000
      DURATION-eng    : 02:16:34.528000000
      NUMBER_OF_FRAMES: 256079
      NUMBER_OF_FRAMES-eng: 256079
      NUMBER_OF_BYTES : 655562240
      NUMBER_OF_BYTES-eng: 655562240
---> DB Level Info: 41, 100
---> Aspect ratio: 640:269 PAR=1:1
---> Duration: 02:16:34
NOT WORKING:
Input #0, matroska,webm, from 'D:\Torrentz\Castaway.on.the.Moon.2009.720p.BluRay.DD5.1.x264.RoSubbed-EbP\Castaway.on.the.Moon.2009.720p.BluRay.DD5.1.x264.RoSubbed-EbP.mkv':
    creation_time   : 2014-09-11 11:32:30
  Duration: 01:57:09.02, start: 0.000000, bitrate: 5032 kb/s
    Chapter #0.0: start 0.000000, end 299.633000
    Chapter #0.1: start 299.633000, end 850.433000
      title           : 00:04:59.633
    Chapter #0.2: start 850.433000, end 1193.025000
      title           : 00:14:10.433
    Chapter #0.3: start 1193.025000, end 1649.690000
      title           : 00:19:53.025
    Chapter #0.4: start 1649.690000, end 2024.231000
      title           : 00:27:29.690
    Chapter #0.5: start 2024.231000, end 2324.113000
      title           : 00:33:44.231
    Chapter #0.6: start 2324.113000, end 2788.536000
      title           : 00:38:44.113
    Chapter #0.7: start 2788.536000, end 3042.998000
      title           : 00:46:28.536
    Chapter #0.8: start 3042.998000, end 3422.628000
      title           : 00:50:42.998
    Chapter #0.9: start 3422.628000, end 3999.537000
      title           : 00:57:02.628
    Chapter #0.10: start 3999.537000, end 4480.351000
      title           : 01:06:39.537
    Chapter #0.11: start 4480.351000, end 5021.642000
      title           : 01:14:40.351
    Chapter #0.12: start 5021.642000, end 5460.455000
      title           : 01:23:41.642
    Chapter #0.13: start 5460.455000, end 5782.902000
      title           : 01:31:00.455
    Chapter #0.14: start 5782.902000, end 6072.316000
      title           : 01:36:22.902
    Chapter #0.15: start 6072.316000, end 6280.941000
      title           : 01:41:12.316
    Chapter #0.16: start 6280.941000, end 6703.196000
      title           : 01:44:40.941
    Chapter #0.17: start 6703.196000, end 7029.022000
      title           : 01:51:43.196
    Stream #0:0(eng): Video: h264 (High), yuv420p, 1280x546 [SAR 1:1 DAR 640:273], 23.98 fps, 23.98 tbr, 1k tbn, 47.95 tbc (default)
      BPS             : 4335982
      BPS-eng         : 4335982
      DURATION        : 01:57:09.022000000
      DURATION-eng    : 01:57:09.022000000
      NUMBER_OF_FRAMES: 168528
      NUMBER_OF_FRAMES-eng: 168528
      NUMBER_OF_BYTES : 3809714983
      NUMBER_OF_BYTES-eng: 3809714983
      _STATISTICS_WRITING_APP: mkvmerge v7.1.0 ('Good Love') 32bit built on Jul 27 2014 12:59:18
      _STATISTICS_WRITING_APP-eng: mkvmerge v7.1.0 ('Good Love') 32bit built on Jul 27 2014 12:59:18
      _STATISTICS_WRITING_DATE_UTC: 2014-09-11 11:32:30
      _STATISTICS_WRITING_DATE_UTC-eng: 2014-09-11 11:32:30
    Stream #0:1(kor): Audio: ac3, 48000 Hz, 5.1(side), fltp, 640 kb/s (default)
      BPS             : 640000
      BPS-eng         : 640000
      DURATION        : 01:56:17.984000000
      DURATION-eng    : 01:56:17.984000000
      NUMBER_OF_FRAMES: 218062
      NUMBER_OF_FRAMES-eng: 218062
      NUMBER_OF_BYTES : 558238720
      NUMBER_OF_BYTES-eng: 558238720
    Stream #0:2(kor): Audio: aac, 48000 Hz, stereo, fltp
      title           : Commentary
      BPS             : 59773
      BPS-eng         : 59773
      DURATION        : 01:56:17.963000000
      DURATION-eng    : 01:56:17.963000000
      NUMBER_OF_FRAMES: 163546
      NUMBER_OF_FRAMES-eng: 163546
      NUMBER_OF_BYTES : 52137590
      NUMBER_OF_BYTES-eng: 52137590
    Stream #0:3(rum): Subtitle: subrip (default)
      title           : Romanian
      BPS             : 15
      BPS-eng         : 15
      DURATION        : 01:51:11.520000000
      DURATION-eng    : 01:51:11.520000000
      NUMBER_OF_FRAMES: 514
      NUMBER_OF_FRAMES-eng: 514
      NUMBER_OF_BYTES : 12874
      NUMBER_OF_BYTES-eng: 12874
    Stream #0:4(eng): Subtitle: subrip
      BPS             : 16
      BPS-eng         : 16
      DURATION        : 01:50:06.599000000
      DURATION-eng    : 01:50:06.599000000
      NUMBER_OF_FRAMES: 508
      NUMBER_OF_FRAMES-eng: 508
      NUMBER_OF_BYTES : 13821
      NUMBER_OF_BYTES-eng: 13821
---> Aspect ratio: 640:273 PAR=1:1
---> Duration: 01:57:09
Input #0, matroska,webm, from 'D:\Torrentz\Dope.2015.720p.BluRay.DD5.1.x264-DON\Dope.2015.720p.BluRay.DD5.1.x264-DON.mkv':
    creation_time   : 2015-10-13 17:11:14
  Duration: 01:43:18.43, start: 0.000000, bitrate: 7257 kb/s
    Chapter #0.0: start 0.000000, end 364.072000
    Chapter #0.1: start 364.072000, end 574.532000
      title           : 00:06:04.072
    Chapter #0.2: start 574.532000, end 905.363000
      title           : 00:09:34.532
    Chapter #0.3: start 905.363000, end 1197.405000
      title           : 00:15:05.363
    Chapter #0.4: start 1197.405000, end 1478.977000
      title           : 00:19:57.405
    Chapter #0.5: start 1478.977000, end 1679.678000
      title           : 00:24:38.977
    Chapter #0.6: start 1679.678000, end 1963.503000
      title           : 00:27:59.678
    Chapter #0.7: start 1963.503000, end 2242.782000
      title           : 00:32:43.503
    Chapter #0.8: start 2242.782000, end 2505.253000
      title           : 00:37:22.782
    Chapter #0.9: start 2505.253000, end 2778.025000
      title           : 00:41:45.253
    Chapter #0.10: start 2778.025000, end 3139.511000
      title           : 00:46:18.025
    Chapter #0.11: start 3139.511000, end 3555.427000
      title           : 00:52:19.511
    Chapter #0.12: start 3555.427000, end 3868.823000
      title           : 00:59:15.427
    Chapter #0.13: start 3868.823000, end 4158.654000
      title           : 01:04:28.823
    Chapter #0.14: start 4158.654000, end 4489.110000
      title           : 01:09:18.654
    Chapter #0.15: start 4489.110000, end 4827.031000
      title           : 01:14:49.110
    Chapter #0.16: start 4827.031000, end 5107.144000
      title           : 01:20:27.031
    Chapter #0.17: start 5107.144000, end 5490.819000
      title           : 01:25:07.144
    Chapter #0.18: start 5490.819000, end 5889.133000
      title           : 01:31:30.819
    Chapter #0.19: start 5889.133000, end 6198.432000
      title           : 01:38:09.133
    Stream #0:0(eng): Video: h264 (High), yuv420p, 1280x534 [SAR 1:1 DAR 640:267], 23.98 fps, 23.98 tbr, 1k tbn, 47.95 tbc (default)
      BPS             : 6615580
      BPS-eng         : 6615580
      DURATION        : 01:43:18.359000000
      DURATION-eng    : 01:43:18.359000000
      NUMBER_OF_FRAMES: 148612
      NUMBER_OF_FRAMES-eng: 148612
      NUMBER_OF_BYTES : 5125717550
      NUMBER_OF_BYTES-eng: 5125717550
      _STATISTICS_WRITING_APP: mkvmerge v8.4.0 ('A better way to fly') 64bit
      _STATISTICS_WRITING_APP-eng: mkvmerge v8.4.0 ('A better way to fly') 64bit
      _STATISTICS_WRITING_DATE_UTC: 2015-10-13 17:11:14
      _STATISTICS_WRITING_DATE_UTC-eng: 2015-10-13 17:11:14
      BPS             : 640000
      BPS-eng         : 640000
      DURATION        : 01:43:18.432000000
      DURATION-eng    : 01:43:18.432000000
      NUMBER_OF_FRAMES: 193701
      NUMBER_OF_FRAMES-eng: 193701
      NUMBER_OF_BYTES : 495874560
      NUMBER_OF_BYTES-eng: 495874560
      BPS             : 89
      BPS-eng         : 89
      DURATION        : 01:41:25.206000000
      DURATION-eng    : 01:41:25.206000000
      NUMBER_OF_FRAMES: 1996
      NUMBER_OF_FRAMES-eng: 1996
      NUMBER_OF_BYTES : 67976
      NUMBER_OF_BYTES-eng: 67976
    Stream #0:3(spa): Subtitle: subrip
      BPS             : 78
      BPS-eng         : 78
      DURATION        : 01:41:47.014000000
      DURATION-eng    : 01:41:47.014000000
      NUMBER_OF_FRAMES: 1854
      NUMBER_OF_FRAMES-eng: 1854
      NUMBER_OF_BYTES : 59648
      NUMBER_OF_BYTES-eng: 59648
    Stream #0:4(fre): Subtitle: subrip
      BPS             : 88
      BPS-eng         : 88
      DURATION        : 01:41:47.143000000
      DURATION-eng    : 01:41:47.143000000
      NUMBER_OF_FRAMES: 1873
      NUMBER_OF_FRAMES-eng: 1873
      NUMBER_OF_BYTES : 67832
      NUMBER_OF_BYTES-eng: 67832
---> Aspect ratio: 640:267 PAR=1:1
---> Duration: 01:43:18
Since I can play natively MKV, I think these lines could be removed from the profile. I need to identify which are the particularities for those mkvs which need to be transcoded. Can someone help? I've given up on avi's, but maybe the mkv's could be solved? Thanks!!!
<!-- Transcode h264 videos with profile level > 4.1 to mpegts with ac3 audio -->
         <Video targetContainer="mpegts" targetVCodec="mpeg2video" targetACodec="ac3" aBitrate="384" DAR="16:9" forceInheritance="true">
            <Matches container="*" vCodec="h264" profile="high_10" />
            <Matches container="*" vCodec="h263" />
Post Fri Dec 18, 2015 6:14 pm
Still working on previous notes but try adding eng and english as well as en to languages and see if it fixes the subtitles. That was zips stated requirement.
Per the last note..the Not Playing have a much higher bit rate. If you are sending over wireless, try switching to wired.
Do not remove those profile lines. They are for special case files including mkv's that cannot be played natively on TV's.
vibreaza
Post Fri Dec 18, 2015 6:56 pm
Will try adding those to languages and post back the feedback.
Now, I think I might have solved the avi problem. At least some of them.
I tried the generic profile, and avi's were no longer displayed as MPEG2-TS, but as VIDEO and in most of them the subtitles were available to be selected.
So I modified the line in 2013 profile
<MediaFormatProfiles>
      </MediaFormatProfiles>
with this line found in the generic profile
         <MediaFormatProfile mime-type="video/x-msvideo">AVI</MediaFormatProfile>
Now 90% of the avi files work and they have subtitles. They are read as "VIDEO". The rest of about 10% are "File not supported".
As for the mkv's. I studied them myself and I noticed the high bitrate difference between worked/not worked and I thought that was the cause, especially since I'm on wifi. (though on 5ghz band with 1 gigabyte connection and highend router).
But it seems not. I will show below a couple of files with way bigger bitrate and they play nicely as well, so bitrate is not a factor I guess.
Complete name                            : D:\Torrentz\The.Man.From.UNCLE.2015.1080p.BluRay.DD5.1.x264-HDMaNiAcS\The.Man.From.UNCLE.2015.1080p.BluRay.DD5.1.x264-HDMaNiAcS.mkv
Duration                                 : 1h 56mn
Duration                                 : 1h 56mn
Height                                   : 800 pixels
Duration                                 : 1h 56mn
Bit rate                                 : 640 Kbps
Text #1
Format                                   : UTF-8
Duration                                 : 1h 53mn
Bit rate                                 : 50 bps
Text #2
Format                                   : UTF-8
Duration                                 : 1h 55mn
Bit rate                                 : 43 bps
Language                                 : French
Text #3
Format                                   : UTF-8
Duration                                 : 1h 56mn
Bit rate                                 : 49 bps
Language                                 : Spanish
Text #4
Format                                   : UTF-8
Duration                                 : 1h 56mn
Bit rate                                 : 47 bps
Menu
Unique ID                                : 199866051831981901197225947783037069123 (0x965CCD292355F7D7BC517F35E7CA2743)
Complete name                            : D:\Torrentz\Eyes.Wide.Shut.1999.720p.Blu-ray.DTS.x264.RoSubbed-playHD\Eyes.Wide.Shut.1999.720p.Blu-ray.DTS.x264.RoSubbed-playHD.mkv
File size                                : 8.79 GiB
Duration                                 : 2h 39mn
Overall bit rate                         : 7 914 Kbps
Encoded date                             : UTC 2014-07-14 08:47:04
Writing application                      : mkvmerge v6.8.0 ('Theme for Great Cities') 64bit built on Mar  2 2014 21:34:26
Writing library                          : libebml v1.3.0 + libmatroska v1.4.1
Duration                                 : 2h 39mn
Bit rate                                 : 6 247 Kbps
Bits/(Pixel*Frame)                       : 0.283
Stream size                              : 6.94 GiB (79%)
Writing library                          : x264 core 142 r2409kMod d6b4e63
Encoding settings                        : cabac=1 / ref=9 / deblock=1:-3:-3 / analyse=0x3:0x133 / me=umh / subme=11 / psy=1 / fade_compensate=0.00 / psy_rd=1.00:0.00 / mixed_ref=1 / me_range=24 / chroma_me=1 / trellis=2 / 8x8dct=1 / cqm=0 / deadzone=21,11 / fast_pskip=0 / chroma_qp_offset=-2 / threads=6 / lookahead_threads=1 / sliced_threads=0 / nr=0 / decimate=0 / interlaced=0 / bluray_compat=0 / constrained_intra=0 / fgo=0 / bframes=6 / b_pyramid=2 / b_adapt=2 / b_bias=0 / direct=3 / weightb=1 / open_gop=0 / weightp=2 / keyint=250 / keyint_min=24 / scenecut=40 / intra_refresh=0 / rc=crf / mbtree=0 / crf=18.0000 / qcomp=0.60 / qpmin=0 / qpmax=69 / qpstep=4 / ip_ratio=1.40 / pb_ratio=1.30 / aq=2:0.80
Color range                              : Limited
Format                                   : DTS
Mode                                     : 16
Codec ID                                 : A_DTS
Duration                                 : 2h 39mn
Bit depth                                : 24 bits
Stream size                              : 1.68 GiB (19%)
Text
Format                                   : UTF-8
Title                                    : Romanian
Language                                 : Romanian
Menu
00:02:42.162                             : en:00:02:42.162
00:06:26.052                             : en:00:06:26.052
00:10:13.112                             : en:00:10:13.112
00:12:53.106                             : en:00:12:53.106
00:20:45.578                             : en:00:20:45.578
00:31:25.217                             : en:00:31:25.217
00:37:20.738                             : en:00:37:20.738
00:41:46.838                             : en:00:41:46.838
00:45:34.899                             : en:00:45:34.899
00:46:59.984                             : en:00:46:59.984
00:51:01.558                             : en:00:51:01.558
00:54:49.620                             : en:00:54:49.620
01:01:26.683                             : en:01:01:26.683
01:05:15.912                             : en:01:05:15.912
01:08:42.285                             : en:01:08:42.285
01:12:05.321                             : en:01:12:05.321
01:15:40.035                             : en:01:15:40.035
01:19:25.761                             : en:01:19:25.761
01:22:19.601                             : en:01:22:19.601
01:24:12.214                             : en:01:24:12.214
01:27:22.904                             : en:01:27:22.904
01:30:01.396                             : en:01:30:01.396
01:32:55.737                             : en:01:32:55.737
01:38:32.740                             : en:01:38:32.740
01:41:15.736                             : en:01:41:15.736
01:44:52.453                             : en:01:44:52.453
01:47:37.951                             : en:01:47:37.951
01:52:02.716                             : en:01:52:02.716
01:55:30.257                             : en:01:55:30.257
02:01:31.951                             : en:02:01:31.951
02:04:46.312                             : en:02:04:46.312
02:10:30.489                             : en:02:10:30.489
02:15:02.094                             : en:02:15:02.094
02:19:02.501                             : en:02:19:02.501
02:24:12.477                             : en:02:24:12.477
02:27:47.859                             : en:02:27:47.859
02:33:38.209                             : en:02:33:38.209
So.. still puzzling :roll:
Post Fri Dec 18, 2015 9:21 pm
Are you sure of the six videos that they are all playing natively? The debug log will show when transcoding is used, but the easier way is to display the "transcoding" directory in explorer to see if an .stf file is being created. I think the other stuttering cause can be the cpu is not transcoding fast enough.
vibreaza
Post Fri Dec 18, 2015 10:59 pm
Hello and thanks again for replying,
Yes, they play natively since I tried with the generic profile which doesn't transcode anything, but I also double checked the transcoded folder when playing the mkv's, there is no .stf.
I tried with a .divx file which can't be played natively and the .stf was instantly created.
As for the cpu power, I really doubt it, my pc has an i7 4790k with 16gb of ram. Something else must be the culprit here. Thanks anyway for all your help, maybe we'll find a solution, or wait for a release of a new 2014 panasonic profile.
Have a great weekend and thanks for taking the time to reply.
Post Sat Dec 19, 2015 12:02 am
For the AVI files, using the Panasonic 2013 files:
Can you please post Mediainfo details for the file that doesn't play. You may also want to try putting in:
    <MediaFormatProfile mime-type="video/avi">AVI</MediaFormatProfile>
Your TV should support all of these, so try them one at a time and/or put all three into the profile (in the order shown, which is how they are in the sink, but try different orders depending on what works best when entered individually).
Below this in the profile is a section:
    <Matches container="avi" /> <!-- Remove this line for models that natively support AVI's with Xvid video (some ST60's) -->
    <Matches container="avi" vCodec="mpeg4" vFourCC="div3,div4,div5,divx,dm4v,dx50" />
    <Matches container="avi" vCodec="msmpeg4" vFourCC="div3,div4,div5,divx,dm4v,dx50" />
Try removing the red line first, and then the green (testing at each stage). This section is transcoding AVI's which isn't needed for (at least some AVI's) your TV (I suspect it will be both sections that can be removed).
Remember when changing profiles, restart your PC (or the serviio service if you know how).
MKV Files:
Can't see the issue either at this stage. Some things to try (you may have done some, so apologies) - do all tests with both the generic and the now modified Panasonic 2013 Profile and see if anything gets rid of the stuttering:
  • Make sure only the top option is selected on the subtitles tab or this will force extraction and/or transcoding (even in the generic profile and even with transcoding switched off). Keep it this way for all testing as we don't want this to impact.
  • Try comparing MediaInfo details for files that play, and those that stutter (rather than ffmpeg -i details).
  • Try a wired connection rather than wireless (yes, plenty of bandwidth, but it is shared and subject to the crappy wifi sub-systems they put in some TV's). Needs to be ruled-out.
  • Use task manager to shut down any running processes on your server other than Serviio
Post Sat Dec 19, 2015 12:21 am
@vibreaza You are really in luck with Denyall's advice. His expertise should help you resolve the panny profile that you need. My knowledge is much less than his.
vibreaza
Post Sat Dec 19, 2015 2:25 am
Great! Thanks guys, I sorted out the avi playing problem, no more "format not supported" with these lines:
What the TV didn't like were avi's with div3 and dx50 codecs. The rest play natively. But these are now playable as MPEG2-TS.
I still have however a problem with subtitles for those avi who get transcoded to mpegts (MPEG2TS). I am unable to load the srt subtitles to these. They show "no subtitles". As a matter of fact, all serviio transcoded files in my TV which show as MPEG2TS can't be subbed.
What I tried to do was to modify this:
<HardSubs>
            <RequiredFor container="mp4" />
         </HardSubs>
into
<HardSubs>
            <RequiredFor container="mpegts" />
         </HardSubs>
But it doesnt work.
If I put "avi" instead of "mpegts", it works, the avi files are hardsubbed, but ALL avi's in my PC are transcoded now to MPEG2TS, not only those which didnt play natively with div3 and dx50 codecs.
So what gives? Any workaround? Is it normal for MPEG2TS to refuse subtitles?
Thanks alot and sorry if I dont make sense, it's late and Im tired :)
vibreaza
Post Sat Dec 19, 2015 2:39 am
For the mkv's now.
I did what you advised.
I am unable to get a wired connection, sorry.
I compared mediainfo for files that played/didn't play but I can't seem to find anything, except for the Format settings, ReFrames. Those that cant be played have higher frames.
I will post it here as well, maybe you might spot something.
WORKING FLAWLESSLY with no need for transcoding
Duration                                 : 1h 56mn
Duration                                 : 1h 56mn
Height                                   : 800 pixels
Duration                                 : 1h 56mn
Bit rate                                 : 640 Kbps
Text #1
Format                                   : UTF-8
Duration                                 : 1h 53mn
Bit rate                                 : 50 bps
Text #2
Format                                   : UTF-8
Duration                                 : 1h 55mn
Bit rate                                 : 43 bps
Language                                 : French
Text #3
Format                                   : UTF-8
Duration                                 : 1h 56mn
Bit rate                                 : 49 bps
Language                                 : Spanish
Text #4
Format                                   : UTF-8
Duration                                 : 1h 56mn
Bit rate                                 : 47 bps
Menu
Duration                                 : 2h 16mn
Duration                                 : 2h 16mn
Format                                   : DTS
Mode                                     : 16
Codec ID                                 : A_DTS
Duration                                 : 2h 16mn
Bit depth                                : 24 bits
Text #1
Format                                   : SSA
Text #2
Format                                   : SSA
Language                                 : Danish
Text #3
Format                                   : SSA
Language                                 : Dutch
Text #4
Format                                   : SSA
Language                                 : Finnish
Text #5
Format                                   : SSA
Language                                 : French
Text #6
Format                                   : SSA
Language                                 : German
Text #7
Format                                   : SSA
Language                                 : Italian
Text #8
Format                                   : SSA
Text #9
Format                                   : SSA
Language                                 : Spanish
Text #10
Format                                   : SSA
Language                                 : Swedish
Unique ID                                : 208089396539656703237359684076458408936 (0x9C8C8F5B89E71BF3B6503C71619EFBE8)
Complete name                            : D:\Torrentz\Beasts.of.No.Nation.2015.720p.WEBRiP.x264-QCF\Beasts.of.No.Nation.2015.720p.WEBRiP.x264-QCF.mkv
File size                                : 3.25 GiB
Duration                                 : 2h 16mn
Overall bit rate                         : 3 408 Kbps
Encoded date                             : UTC 2015-10-17 22:13:45
Writing application                      : mkvmerge v7.4.0 ('Circles') 64bit built on Dec 12 2014 12:19:56
Duration                                 : 2h 16mn
Bit rate                                 : 2 766 Kbps
Height                                   : 538 pixels
Bits/(Pixel*Frame)                       : 0.168
Stream size                              : 2.64 GiB (81%)
Encoding settings                        : cabac=1 / ref=5 / deblock=1:0:0 / analyse=0x3:0x113 / me=umh / subme=8 / psy=1 / psy_rd=1.00:0.00 / mixed_ref=1 / me_range=16 / chroma_me=1 / trellis=1 / 8x8dct=1 / cqm=0 / deadzone=21,11 / fast_pskip=1 / chroma_qp_offset=-2 / threads=6 / lookahead_threads=1 / sliced_threads=0 / nr=0 / decimate=1 / interlaced=0 / bluray_compat=0 / constrained_intra=0 / bframes=3 / b_pyramid=2 / b_adapt=2 / b_bias=0 / direct=3 / weightb=1 / open_gop=0 / weightp=2 / keyint=250 / keyint_min=25 / scenecut=40 / intra_refresh=0 / rc_lookahead=50 / rc=crf / mbtree=1 / crf=18.0 / qcomp=0.60 / qpmin=0 / qpmax=69 / qpstep=4 / ip_ratio=1.40 / aq=1:1.00
Duration                                 : 2h 16mn
Bit rate                                 : 640 Kbps
Delay relative to video                  : 31ms
Stream size                              : 625 MiB (19%)
Unique ID                                : 226534018418454820303899389469667085607 (0xAA6CDD6D53B44FD4A6F400B82C17CD27)
Complete name                            : D:\Torrentz\Da.Vincis.Demons.S01.720p.BluRay.x264-SCC\Da.Vincis.Demons.S01E01.720p.BluRay.x264-DEMAND\da.vincis.demons.s01e01.720p.bluray.x264-demand.mkv
File size                                : 2.18 GiB
Duration                                 : 58mn 55s
Overall bit rate                         : 5 301 Kbps
Encoded date                             : UTC 2013-08-14 03:08:17
Writing application                      : mkvmerge v6.2.0 ('Promised Land') built on Apr 28 2013 12:22:01
Writing library                          : libebml v1.3.0 + libmatroska v1.4.0
Duration                                 : 58mn 55s
Bit rate                                 : 4 661 Kbps
Bits/(Pixel*Frame)                       : 0.211
Stream size                              : 1.87 GiB (86%)
Title                                    : X264
Writing library                          : x264 core 135 r2345 f0c1c53
Encoding settings                        : cabac=1 / ref=5 / deblock=1:0:0 / analyse=0x3:0x133 / me=umh / subme=7 / psy=1 / psy_rd=1.00:0.00 / mixed_ref=1 / me_range=16 / chroma_me=1 / trellis=1 / 8x8dct=1 / cqm=0 / deadzone=21,11 / fast_pskip=0 / chroma_qp_offset=-2 / threads=12 / lookahead_threads=2 / sliced_threads=0 / nr=0 / decimate=1 / interlaced=0 / bluray_compat=0 / constrained_intra=0 / bframes=3 / b_pyramid=2 / b_adapt=1 / b_bias=0 / direct=1 / weightb=1 / open_gop=0 / weightp=2 / keyint=250 / keyint_min=23 / scenecut=40 / intra_refresh=0 / rc_lookahead=40 / rc=2pass / mbtree=1 / bitrate=4661 / ratetol=1.0 / qcomp=0.60 / qpmin=0 / qpmax=69 / qpstep=4 / cplxblur=20.0 / qblur=0.5 / ip_ratio=1.40 / aq=1:1.00
Duration                                 : 58mn 55s
Bit rate                                 : 640 Kbps
Stream size                              : 270 MiB (12%)
Title                                    : DTS
Menu
00:01:07.067                             : en:00:01:07.067
00:09:59.098                             : en:00:09:59.098
00:21:14.398                             : en:00:21:14.398
00:32:42.752                             : en:00:32:42.752
00:42:05.356                             : en:00:42:05.356
00:47:49.283                             : en:00:47:49.283
00:57:50.300                             : en:00:57:50.300
Duration                                 : 2h 39mn
Duration                                 : 2h 39mn
Format                                   : DTS
Mode                                     : 16
Codec ID                                 : A_DTS
Duration                                 : 2h 39mn
Bit depth                                : 24 bits
Text
Format                                   : UTF-8
Title                                    : Romanian
Language                                 : Romanian
Menu
Unique ID                                : 222640681944007528291435693514198138865 (0xA77F091E5BA3F4A59BF6E35EF064BFF1)
Complete name                            : D:\Torrentz\Star.Wars.Complete.720p.HDTV.x264.INTERNAL.RoSubbed-hV\Star.Wars.Episode.I.The.Phantom.Menace.1999.720p.HDTV.x264.INTERNAL.RoSubbed-hV\Star.Wars.Episode.I.The.Phantom.Menace.1999.720p.HDTV.x264.INTERNAL.RoSubbed-hV.mkv
File size                                : 4.37 GiB
Duration                                 : 2h 10mn
Overall bit rate                         : 4 797 Kbps
Encoded date                             : UTC 2009-11-20 14:40:44
Writing application                      : mkvmerge v2.2.0 ('Turn It On Again') built on Mar  4 2008 13:20:25
Format settings, ReFrames                : 8 frames
Duration                                 : 2h 10mn
Bit rate                                 : 4 409 Kbps
Height                                   : 544 pixels
Display aspect ratio                     : 2.35:1
Frame rate                               : 25.000 fps
Bits/(Pixel*Frame)                       : 0.253
Stream size                              : 3.94 GiB (90%)
Writing library                          : x264 core 56 svn-667C
Encoding settings                        : cabac=1 / ref=5 / deblock=1:-4:-4 / analyse=0x3:0x133 / me=umh / subme=6 / brdo=1 / mixed_ref=1 / me_range=16 / chroma_me=1 / trellis=1 / 8x8dct=1 / cqm=2 / deadzone=4,6 / chroma_qp_offset=0 / threads=3 / nr=0 / decimate=1 / mbaff=0 / bframes=3 / b_pyramid=1 / b_adapt=1 / b_bias=0 / direct=3 / wpredb=1 / bime=1 / keyint=250 / keyint_min=25 / scenecut=40(pre) / rc=2pass / bitrate=4409 / ratetol=1.0 / rceq='blurCplx^(1-qComp)' / qcomp=0.60 / qpmin=10 / qpmax=51 / qpstep=4 / cplxblur=20.0 / qblur=0.5 / ip_ratio=1.40 / pb_ratio=1.30 / zones=187687,195786,b=0.15 / aq=1:0.3:15.0
Duration                                 : 2h 10mn
Bit rate                                 : 384 Kbps
Stream size                              : 358 MiB (8%)
Text
Format                                   : UTF-8
Language                                 : Romanian
NOT WORKING / STUTTERING/UNPLAYABLE
Unique ID                                : 210987042496326360211606472096842311465 (0x9EBAA055563EEB809E408335B8E4E729)
Complete name                            : D:\Torrentz\Castaway.on.the.Moon.2009.720p.BluRay.DD5.1.x264.RoSubbed-EbP\Castaway.on.the.Moon.2009.720p.BluRay.DD5.1.x264.RoSubbed-EbP.mkv
File size                                : 4.12 GiB
Duration                                 : 1h 57mn
Overall bit rate                         : 5 033 Kbps
Encoded date                             : UTC 2014-09-11 11:32:30
Writing application                      : mkvmerge v7.1.0 ('Good Love') 32bit built on Jul 27 2014 12:59:18
Format settings, ReFrames                : 11 frames
Duration                                 : 1h 57mn
Bit rate                                 : 4 336 Kbps
Height                                   : 546 pixels
Bits/(Pixel*Frame)                       : 0.259
Stream size                              : 3.55 GiB (86%)
Writing library                          : x264 core 129 r2245 bc13772
Encoding settings                        : cabac=1 / ref=11 / deblock=1:-3:-3 / analyse=0x3:0x113 / me=tesa / subme=11 / psy=1 / psy_rd=0.80:0.00 / mixed_ref=1 / me_range=16 / chroma_me=1 / trellis=2 / 8x8dct=1 / cqm=0 / deadzone=21,11 / fast_pskip=0 / chroma_qp_offset=-2 / threads=12 / lookahead_threads=2 / sliced_threads=0 / nr=0 / decimate=0 / interlaced=0 / bluray_compat=0 / constrained_intra=0 / bframes=8 / b_pyramid=2 / b_adapt=2 / b_bias=0 / direct=3 / weightb=1 / open_gop=0 / weightp=2 / keyint=250 / keyint_min=23 / scenecut=40 / intra_refresh=0 / rc=crf / mbtree=0 / crf=16.8 / qcomp=0.60 / qpmin=0 / qpmax=69 / qpstep=4 / ip_ratio=1.40 / pb_ratio=1.30 / aq=1:0.90
Audio #1
Duration                                 : 1h 56mn
Bit rate                                 : 640 Kbps
Stream size                              : 532 MiB (13%)
Language                                 : Korean
Audio #2
Format profile                           : HE-AAC / LC
Codec ID                                 : A_AAC
Duration                                 : 1h 56mn
Bit rate                                 : 59.8 Kbps
Sampling rate                            : 48.0 KHz / 24.0 KHz
Frame rate                               : 23.438 fps (1024 spf)
Stream size                              : 49.7 MiB (1%)
Title                                    : Commentary
Language                                 : Korean
Text #1
Format                                   : UTF-8
Duration                                 : 1h 51mn
Bit rate                                 : 15 bps
Count of elements                        : 514
Stream size                              : 12.6 KiB (0%)
Title                                    : Romanian
Language                                 : Romanian
Text #2
Format                                   : UTF-8
Duration                                 : 1h 50mn
Bit rate                                 : 16 bps
Count of elements                        : 508
Stream size                              : 13.5 KiB (0%)
Menu
00:04:59.633                             : en:00:04:59.633
00:14:10.433                             : en:00:14:10.433
00:19:53.025                             : en:00:19:53.025
00:27:29.690                             : en:00:27:29.690
00:33:44.231                             : en:00:33:44.231
00:38:44.113                             : en:00:38:44.113
00:46:28.536                             : en:00:46:28.536
00:50:42.998                             : en:00:50:42.998
00:57:02.628                             : en:00:57:02.628
01:06:39.537                             : en:01:06:39.537
01:14:40.351                             : en:01:14:40.351
01:23:41.642                             : en:01:23:41.642
01:31:00.455                             : en:01:31:00.455
01:36:22.902                             : en:01:36:22.902
01:41:12.316                             : en:01:41:12.316
01:44:40.941                             : en:01:44:40.941
01:51:43.196                             : en:01:51:43.196
Unique ID                                : 171513044052342702789441303279511202994 (0x810835F3037341C38270D41B356EECB2)
Complete name                            : D:\Torrentz\Dope.2015.720p.BluRay.DD5.1.x264-DON\Dope.2015.720p.BluRay.DD5.1.x264-DON.mkv
File size                                : 5.24 GiB
Duration                                 : 1h 43mn
Overall bit rate                         : 7 258 Kbps
Encoded date                             : UTC 2015-10-13 17:11:14
Writing application                      : mkvmerge v8.4.0 ('A better way to fly') 64bit
Duration                                 : 1h 43mn
Bit rate                                 : 6 616 Kbps
Height                                   : 534 pixels
Bits/(Pixel*Frame)                       : 0.404
Stream size                              : 4.77 GiB (91%)
Writing library                          : x264 core 148 r2597+53 5548565 t_mod_Custom [8-bit@all X86_64]
Encoding settings                        : cabac=1 / ref=12 / deblock=1:-3:-3 / analyse=0x3:0x133 / me=tesa / subme=10 / psy=1 / fade_compensate=0.00 / psy_rd=0.90:0.00 / mixed_ref=1 / me_range=32 / chroma_me=1 / trellis=2 / 8x8dct=1 / cqm=0 / deadzone=21,11 / fast_pskip=0 / chroma_qp_offset=-2 / threads=12 / lookahead_threads=3 / sliced_threads=0 / nr=0 / decimate=1 / interlaced=0 / bluray_compat=0 / constrained_intra=0 / fgo=0 / bframes=10 / b_pyramid=2 / b_adapt=2 / b_bias=0 / direct=3 / weightb=1 / open_gop=0 / weightp=2 / keyint=241 / keyint_min=23 / scenecut=40 / intra_refresh=0 / rc_lookahead=60 / rc=crf / mbtree=0 / crf=15.5000 / qcomp=0.70 / qpmin=0:0:0 / qpmax=69:69:69 / qpstep=4 / vbv_maxrate=50000 / vbv_bufsize=62500 / crf_max=0.0 / nal_hrd=none / filler=0 / ip_ratio=1.40 / pb_ratio=1.30 / aq=3:0.80 / aq-sensitivity=10.00 / aq-factor=1.00:1.00:1.00 / aq2=0 / aq3=0
Duration                                 : 1h 43mn
Bit rate                                 : 640 Kbps
Frame rate                               : 31.250 fps (1536 spf)
Stream size                              : 473 MiB (9%)
Text #1
Format                                   : UTF-8
Duration                                 : 1h 41mn
Bit rate                                 : 89 bps
Count of elements                        : 1996
Stream size                              : 66.4 KiB (0%)
Text #2
Format                                   : UTF-8
Duration                                 : 1h 41mn
Bit rate                                 : 78 bps
Count of elements                        : 1854
Stream size                              : 58.3 KiB (0%)
Language                                 : Spanish
Text #3
Format                                   : UTF-8
Duration                                 : 1h 41mn
Bit rate                                 : 88 bps
Count of elements                        : 1873
Stream size                              : 66.2 KiB (0%)
Language                                 : French
Menu
00:06:04.072                             : en:00:06:04.072
00:09:34.532                             : en:00:09:34.532
00:15:05.363                             : en:00:15:05.363
00:19:57.405                             : en:00:19:57.405
00:24:38.977                             : en:00:24:38.977
00:27:59.678                             : en:00:27:59.678
00:32:43.503                             : en:00:32:43.503
00:37:22.782                             : en:00:37:22.782
00:41:45.253                             : en:00:41:45.253
00:46:18.025                             : en:00:46:18.025
00:52:19.511                             : en:00:52:19.511
00:59:15.427                             : en:00:59:15.427
01:04:28.823                             : en:01:04:28.823
01:09:18.654                             : en:01:09:18.654
01:14:49.110                             : en:01:14:49.110
01:20:27.031                             : en:01:20:27.031
01:25:07.144                             : en:01:25:07.144
01:31:30.819                             : en:01:31:30.819
01:38:09.133                             : en:01:38:09.133
Unique ID                                : 229570697154705346011611293131409955340 (0xACB5B53F83CEC691A12DB66C85DF9A0C)
Complete name                            : D:\Torrentz\Everest.2015.BluRay.720p.DD5.1.x264-EPiC\Everest.2015.BluRay.720p.DD5.1.x264-EPiC.mkv
File size                                : 5.36 GiB
Duration                                 : 2h 1mn
Overall bit rate                         : 6 327 Kbps
Movie name                               : Everest.2015.BluRay.720p.DD5.1.x264-EPiC@HDArea
Encoded date                             : UTC 2015-12-16 02:55:06
Writing application                      : mkvmerge v8.3.0 ('Over the Horizon') 64bit
Duration                                 : 2h 1mn
Bit rate                                 : 5 636 Kbps
Height                                   : 536 pixels
Bits/(Pixel*Frame)                       : 0.343
Stream size                              : 4.77 GiB (89%)
Title                                    : Everest.2015.BluRay.720p.DD5.1.x264-EPiC@HDArea
Writing library                          : x264 core 142 r2431+42 c69a006 tMod [8-bit@all X86_64]
Encoding settings                        : cabac=1 / ref=12 / deblock=1:-3:-3 / analyse=0x3:0x133 / me=umh / subme=11 / psy=1 / fade_compensate=0.00 / psy_rd=1.05:1.00 / mixed_ref=1 / me_range=32 / chroma_me=1 / trellis=2 / 8x8dct=1 / cqm=0 / deadzone=21,11 / fast_pskip=0 / chroma_qp_offset=-4 / threads=12 / lookahead_threads=2 / sliced_threads=0 / nr=0 / decimate=0 / interlaced=0 / bluray_compat=0 / constrained_intra=0 / fgo=0 / bframes=8 / b_pyramid=2 / b_adapt=2 / b_bias=0 / direct=3 / weightb=1 / open_gop=0 / weightp=2 / keyint=240 / keyint_min=23 / scenecut=40 / intra_refresh=0 / rc_lookahead=60 / rc=crf / mbtree=0 / crf=16.5000 / qcomp=0.60 / qpmin=0:0:0 / qpmax=69:69:69 / qpstep=4 / vbv_maxrate=40000 / vbv_bufsize=30000 / crf_max=0.0 / nal_hrd=none / filler=0 / ip_ratio=1.40 / pb_ratio=1.30 / aq=1:1.00 / aq-sensitivity=10.00 / aq-factor=1.00:1.00:1.00 / aq2=0 / aq3=0
Duration                                 : 2h 1mn
Bit rate                                 : 640 Kbps
Stream size                              : 555 MiB (10%)
Title                                    : English DD5.1-EX 640 Kbps
Text #1
Format                                   : PGS
Muxing mode                              : zlib
Codec ID                                 : S_HDMV/PGS
Codec ID/Info                            : Picture based subtitle format used on BDs/HD-DVDs
Duration                                 : 1h 50mn
Bit rate                                 : 13.7 Kbps
Count of elements                        : 3606
Stream size                              : 10.8 MiB (0%)
Title                                    : ENG/SUP (SDH)
Text #2
Format                                   : PGS
Muxing mode                              : zlib
Duration                                 : 1h 59mn
Bit rate                                 : 13.2 Kbps
Count of elements                        : 3222
Stream size                              : 11.3 MiB (0%)
Title                                    : CHS/SUP (TW)
Language                                 : Chinese
Text #3
Format                                   : PGS
Muxing mode                              : zlib
Duration                                 : 1h 59mn
Bit rate                                 : 10.9 Kbps
Count of elements                        : 3224
Stream size                              : 9.37 MiB (0%)
Title                                    : CHT/SUP (HK)
Language                                 : Chinese
Text #4
Format                                   : PGS
Muxing mode                              : zlib
Duration                                 : 1h 59mn
Bit rate                                 : 12.5 Kbps
Count of elements                        : 3286
Stream size                              : 10.7 MiB (0%)
Title                                    : CHT/SUP (TW)
Language                                 : Chinese
Menu
00:00:00.000                             : en:Chapter 01
00:05:12.145                             : en:Chapter 02
00:09:36.075                             : en:Chapter 03
00:15:13.162                             : en:Chapter 04
00:20:58.423                             : en:Chapter 05
00:26:30.714                             : en:Chapter 06
00:33:15.118                             : en:Chapter 07
00:40:23.754                             : en:Chapter 08
00:47:23.382                             : en:Chapter 09
00:52:14.589                             : en:Chapter 10
00:57:49.174                             : en:Chapter 11
01:01:54.794                             : en:Chapter 12
01:07:22.079                             : en:Chapter 13
01:15:40.577                             : en:Chapter 14
01:21:03.900                             : en:Chapter 15
01:26:59.589                             : en:Chapter 16
01:32:39.136                             : en:Chapter 17
01:41:20.449                             : en:Chapter 18
01:46:47.651                             : en:Chapter 19
01:54:06.464                             : en:Chapter 20
02:01:10.221                             : en:Chapter 21
Post Sat Dec 19, 2015 7:50 am
For your AVI's - between a rock and a hard place I'm afraid.
As you have surmised, if you transcode the AVI you lose your subtitle support. If you enable burning in for subs (with or without the RequiredFor to limit it to AVIs only), then Serviio will transcode any AVI that has subtitles. There is no work-around for this - Serviio doesn't go to the same level of granularity in the RequiredFor statement (ie. it only goes to the container level, not to the video codec or fourCC level).
There's nothing you can do within Serviio, but you may be able to change the file:
  • You could try is to change the fourCC on the AVI to try and fool the Serviio and the TV to thinking its an XVid. Try this tool: http://wiki.serviio.org/doku.php?id=avi4cc to do so. I think it's unlikely to work, but worth a quick test (back up the original file)
  • Re-encode the video - note that there will be some quality loss. Choose an MP4 container or something that supports subs on your system and re-encode the video to h264. This (unlike the next option) will make the sub selectable on you TV still
  • Burn the subs in permanently for these files. If you want to go down this path come back to me and I'll come back with the ffmpeg command (I have to research it, and need to go out tonight...) or google if you prefer (there's plenty of tools that do this).
or simply choose to forgo subs for these files.... :(
As for your MKV's ... that's tomorrows job (may take some time). No way to rule out wifi?? perhaps move the PC to the TV?
Which profile were you using when doing those tests?
Were subtitles available on all the working ones (some would have been transcoded if using the pana profile so shouldnt have had sub titles available??)
vibreaza
Post Sat Dec 19, 2015 1:47 pm
Hello DenyAll and thanks for your useful input,
For avi's I think the only way is to toggle on/off burning in subtitles when needed. I'm fine with that, there seems no other way, though I don't really get it why <RequiredFor container="mpegts" /> doesn't work.
Now for mkv's.
When doing the tests, I was using a "tweaked to my needs" 2013 profile (mainly I removed a few lines and replaced the mime-type for avi) and it works just fine. No mkv's were transcoded, so all subtitles were available on all the working ones.
When I have them transcoded to MPEG2-TS by keeping the above lines, the same stuttering is present in those which don't work, so I completely removed them and let them play natively.
Here it goes. If there are any other lines that should be added/tweaked let me know. But with this profile, I tested lots of files and I get no "unsupported file format" error. Also I can see mp4 files with external subs without problems and no transcoding.
<Profile id="99" name="Panasonic AS640" extendsProfileId="1">
      <Detection>
         <UPnPSearch>
            <FriendlyName>.*VIERA AS640.*</FriendlyName>
            <Manufacturer>Panasonic</Manufacturer>
         </UPnPSearch>
      </Detection>
         <!-- remux FLAC/TrueHD in MKV/MP4 to AC3, DTS (MP4) to AC3 -->
         <Video targetContainer="mpegts" targetACodec="ac3" aBitrate="384" forceInheritance="true">
            <!-- Matches container="matroska" vCodec="h264" aCodec="dca" / --> <!-- Uncomment this line if DTS is not supported natively -->
            <Matches container="matroska" vCodec="h264" aCodec="dts-hd" />
         <Video targetContainer="mpegts" targetVCodec="mpeg2video" targetACodec="ac3" forceInheritance="true">
            <Matches container="*" vCodec="h263"/>
         <!-- Remux MPEG-PS with no transcoding -->
         <Video targetContainer="mpegts" forceInheritance="true">
            <Matches container="wtv" />
         <Video targetContainer="mpegts" targetVCodec="mpeg2video" targetACodec="ac3" aBitrate="384" forceInheritance="true">
            <Matches container="mp4" vCodec="dvvideo" />
            <Matches container="mp4" vCodec="mpeg4" />
            <Matches container="mpeg" vCodec="mpeg1video" />
            <Matches container="matroska" vCodec="mpeg4" />
            <Matches container="*" vCodec="h265" />
            <Matches container="asf" />
            <Matches container="ogg" />
            <Matches container="rm" />
         <!-- AVI files will be transcoded into mpeg-ts, mpeg2 video and ac3 audio.
         This section is NOT inherited by other Panasonic profiles  -->
         <!-- unsupported audio will be transcoded into lpcm audio -->
         <Audio targetContainer="lpcm" forceInheritance="true">
            <Matches container="adts" />
            <Matches container="wavpack" />
            <Matches container="mpc" />
            <Matches container="ape" />
         </Audio>
      <HardSubsTranscoding>
         <Video targetContainer="mpeg" targetVCodec="mpeg2video" DAR="16:9" targetACodec="ac3" aBitrate="384" forceVTranscoding="true"/>
      </HardSubsTranscoding>
      <Subtitles>
         <SoftSubs mime-type="text/srt" />
         <HardSubs>
            <RequiredFor container="avi" />
         </HardSubs>
      </Subtitles>
      <ThumbnailsResolution>HD</ThumbnailsResolution>
</Profiles>
Now, I do believe the problem with those stuttering mkv's are the frames.
I tried your software serviio winhelper to remux to same file format, no go. I tried to make it mp4 from mkv, but I only got a 1kb file, so it didn't work.
Then I tried MKVtool and MkvToMp4, no success.
I found then this post
moonmopus wrote:i thought i would offer some input based on what has worked for me with problem mkvs. i have always enjoyed using handbrake and have been very happy with how it has developed over the years. its been more stable for me in linux and mac than windows. it seems that most of the mkvs i have had trouble with have b frame issues. the best way, in my experience, to resolve this in handbrake is to ensure that in advanced -analysis - adaptive b frames, you switch from the defauklt of 'fast' to 'optimal'some mkv. this will take longer but i have always had success. you can tweak some other features in the advanced section but this is the one that seems to make all the difference.
and I used handbrake with those settings, and it works. It's a bit timeconsuming to rewrite them and I need to burnin the subtitles, but at least they work now. And they have lower frames (whatever that means :D ).
Here is a mediainfo for before-not working/after-working for a mkv. As far as my eyes can see, I didn't lose quality, but I dont know for sure.
Format version                           : Version 4 / Version 2
Duration                                 : 1h 43mn
Writing library                          : libebml v1.3.1 + libmatroska v1.4.2
Format settings, ReFrames                : 12 frames
Duration                                 : 1h 43mn
Height                                   : 534 pixels
Display aspect ratio                     : 2.40:1
Frame rate                               : 23.976 (24000/1001) fps
Duration                                 : 1h 43mn
Bit rate                                 : 640 Kbps
Text #1
Format                                   : UTF-8
Codec ID                                 : S_TEXT/UTF8
Codec ID/Info                            : UTF-8 Plain Text
Duration                                 : 1h 41mn
Bit rate                                 : 89 bps
Text #2
Format                                   : UTF-8
Duration                                 : 1h 41mn
Bit rate                                 : 78 bps
Language                                 : Spanish
Text #3
Format                                   : UTF-8
Duration                                 : 1h 41mn
Bit rate                                 : 88 bps
Language                                 : French
Menu
00:00:00.000                             : en:00:00:00.000
Unique ID                                : 288754615017605540997711427251658739979 (0xD93C1DAFD520A2B2017D0B32119AD10B)
Complete name                            : D:\Torrentz\Dope.2015.720p.BluRay.DD5.1.x264-DON\Dope.2015.720p.BluRay.DD5.1.x264-DON-repack.mkv
File size                                : 1.47 GiB
Duration                                 : 1h 43mn
Overall bit rate                         : 2 035 Kbps
Encoded date                             : UTC
Writing application                      : HandBrake 0.10.2 2015060900
Writing library                          : Lavf55.12.0 / Lavf55.12.0
Duration                                 : 1h 43mn
Height                                   : 534 pixels
Writing library                          : x264 core 142 r2479 dd79a61
Encoding settings                        : cabac=1 / ref=3 / deblock=1:0:0 / analyse=0x3:0x113 / me=hex / subme=7 / psy=1 / psy_rd=1.00:0.00 / mixed_ref=0 / me_range=16 / chroma_me=1 / trellis=1 / 8x8dct=1 / cqm=0 / deadzone=21,11 / fast_pskip=1 / chroma_qp_offset=-2 / threads=12 / lookahead_threads=2 / sliced_threads=0 / nr=0 / decimate=1 / interlaced=0 / bluray_compat=0 / constrained_intra=0 / bframes=3 / b_pyramid=2 / b_adapt=1 / b_bias=0 / direct=1 / weightb=1 / open_gop=0 / weightp=2 / keyint=240 / keyint_min=24 / scenecut=40 / intra_refresh=0 / rc_lookahead=10 / rc=crf / mbtree=1 / crf=20.0 / qcomp=0.60 / qpmin=0 / qpmax=69 / qpstep=4 / vbv_maxrate=20000 / vbv_bufsize=25000 / crf_max=0.0 / nal_hrd=none / filler=0 / ip_ratio=1.40 / aq=1:1.00
Codec ID                                 : A_AAC
Duration                                 : 1h 43mn
Frame rate                               : 46.875 fps (1024 spf)
Title                                    : Stereo
Menu
00:00:00.000                             : :00:00:00.000
00:06:04.197                             : :00:06:04.072
00:09:34.699                             : :00:09:34.532
00:15:05.446                             : :00:15:05.363
00:19:57.529                             : :00:19:57.405
00:24:39.061                             : :00:24:38.977
00:27:59.761                             : :00:27:59.678
00:32:43.628                             : :00:32:43.503
00:37:22.907                             : :00:37:22.782
00:41:45.336                             : :00:41:45.253
00:46:18.150                             : :00:46:18.025
00:52:19.720                             : :00:52:19.511
00:59:15.552                             : :00:59:15.427
01:04:29.031                             : :01:04:28.823
01:09:18.863                             : :01:09:18.654
01:14:49.193                             : :01:14:49.110
01:20:27.155                             : :01:20:27.031
01:25:07.227                             : :01:25:07.144
01:31:31.069                             : :01:31:30.819
01:38:09.216                             : :01:38:09.133
So I guess, there are no settings in a profile for my TV for "faulty" mkv's, maybe it's the wireless that cant handle above 10 frames? I don't know but before downloading a movie I'll look at those frames in the "sample" lol.
Thanks guys!
Post Sat Dec 19, 2015 2:50 pm
Maybe?
https://en.wikipedia.org/wiki/Reference_frame_(video)
Decoding[edit]
When decoding, reference frames must be stored in memory until they are no longer needed for further decoding. This can considerably raise the memory usage of the decoder for videos with large numbers of reference frames. The use of several reference frames also decreases locality of reference, which might cause a speed impact. Stand-alone players that can play AVC/MKV files off of recorded DVDs or USB sticks cannot handle the full 16 REF frames.
Most of my downloaded videos are 4 ref frames.
Return to Panasonic
