4K Support
hansolo
Post Wed Aug 26, 2015 11:46 am
4K Support
Hi All,
Should i expect serviio to recognise 4k files when scanning my library? I have the timescapes 4k videos (4k and 1080p) and when browsing only the 1080p videos show in the browser? The folder contains:-
shared videos/TimeScapes/TimeScapes (2012).mp4
shared videos/TimeScapes/TimeScapes.Directors.Commentary.1080p.mp4
The only file that shows up is the directors commentary. Any ideas?
Cheers
Post Wed Aug 26, 2015 12:50 pm
Re: 4K Support
I have one 4K clip (Sintel). It displays in the list but won't play. When I switch from Serviio to the PC itself, the TV will play it, so I know there's something in the Samsung H profile that isn't optimized for 4K. Unfortunately I think none of the transcoding gurus here have a 4K set to use to create a new 4K profile. I know enough to tweak an existing profile, but haven't a clue how to build a new one from scratch.
I've posted the Device Spy info for the JU series on the wiki page, but I don't know how to translate that into the first part of the profile, which of course guides the remainder of the profile.
Which profile do you have selected, and what TV are you using?
hansolo
Post Thu Aug 27, 2015 8:34 am
Re: 4K Support
LG TV and its set to LG TV/Player profile. Doesn't even list the video under LG dlna smartshare.
However if i use serviio mediabrowser when on my pc the video is listed, i assume tats just because media browsers use the CDS api.
Post Thu Aug 27, 2015 12:53 pm
Re: 4K Support
OK, that isolates the issue for you as the LG profile. I noticed that there's only one LG profile, compared to multiples for Samsung and Sony. Someone with the necessary knowledge will need to update (preferably create a new version) the LG profile for 4K. In my opinion, all 4K sets need their own dedicated profile, just for issues like this. I wish I understood the profiles better, as I'd be happy to work on it.
You are correct that MediaBrowser uses its own profile, which will show files that the TV profile does not recognize.
Post Thu Aug 27, 2015 2:12 pm
Re: 4K Support
It may be that your TV does not support streaming of 4K files via DLNA. For example, some 4K Sony models do not support it (https://sony-paa-pa-en-web--paa.custhel ... p1bQ%3D%3D).
The best place to start is to confirm whether your TV actually supports 4K via DLNA. Maybe in your manual, or Google may help.
Post Thu Aug 27, 2015 11:51 pm
Re: 4K Support
DenyAll is spot on. My Samsung will play 4K over DLNA, but I have no idea about your LG, especially since you still haven't said the model.
Resonate
Post Thu Dec 17, 2015 11:44 pm
Re: 4K Support
Did anyone resolve this? I have a 65UF850V and just reports "this file cannot be played"
Post Fri Dec 18, 2015 12:49 am
Re: 4K Support
Resonate wrote:Did anyone resolve this? I have a 65UF850V and just reports "this file cannot be played"
I did a search for LG DLNA support, and I couldn't find anything. As has been mentioned, many TVs can play files via USB but not DLNA. Nothing Serviio can do about that, except transcode the file to 1080p. Kind of defeats the purpose.
The way I confirmed my TV can play something via DLNA is to access the built-in Windows DLNA server and try playing the file. The only 4K video I have will play that way, so for that file I know the issue is with my Serviio profile. However, I don't know how to determine where the issue is. Probably in all that text at the beginning of each profile that identifies the file types.
Resonate
Post Fri Dec 18, 2015 1:07 pm
Re: 4K Support
Thanks, trying not to spill my issue over multiple threads. But I have a word from LG that the files will play over DLNA. How much accuracy there is in that statement is another matter though!
"Thank you for your query regarding this TV 65UF850V and of course I can help you with this. It would seem that what you have read is incorrect.
As this TV is a 4K TV, if you can provide the TV with a 4K input then the TV would display it without any issues and this would be over DNLA or a USB stick.
I hope you are happy with the service that I have personally provided, if you are, please take the time to fill out a short survey that rates me on my customer service to you today. It is based solely on my efforts for you. I appreciate any feedback given!"
Post Fri Dec 18, 2015 1:54 pm
Re: 4K Support
Resonate wrote:Thanks, trying not to spill my issue over multiple threads. But I have a word from LG that the files will play over DLNA. How much accuracy there is in that statement is another matter though!
Yeah, that's a pretty generic response, and doesn't mentions the supported formats. And he/she couldn't spell DLNA! I know, a typo :lol:
I'd try the method I used, which was to play it via Windows Media DLNA services. If it plays there (as mine did), then the issue is the Serviio profile. If it won't, then that particular file won't play via DLNA.
Resonate
Post Fri Dec 18, 2015 3:48 pm
Re: 4K Support
"play it via Windows Media DLNA services" What is that?
Post Fri Dec 18, 2015 10:15 pm
Re: 4K Support
Beginning with Windows 7, Microsoft built a DLNA server into Windows Media Player. I think it's enabled by default, but I could be wrong.
Open Windows Media Player. On the menu bar there should be an option labeled "Stream". Click that and the menu opens, with Media Streaming at the bottom. On my Work PC (the only Win 7 I have in front of me at the moment) it says "Turn on media streaming...", indicating that it is currently turned off. My Windows 10 computer says "More streaming options...", because it's already on. Clicking on either allows you to configure what you share, and what devices are permitted to connect. Once it's enabled, you'll see it as another DLNA service available on your player/TV. On my Samsung, it has a Windows icon instead of the Serviio icon, so it's real obvious which is which.
Take a look and let me know if you need more.
Resonate
Post Sun Dec 20, 2015 8:08 pm
Re: 4K Support
Hi tried that. Same issue.
Post Sun Dec 20, 2015 8:27 pm
Re: 4K Support
Resonate wrote:Hi tried that. Same issue.
Then my thought is that the TV doesn't support that particular video via DLNA. Remember that many (most) devices will not necessarily play the same files via DLNA that plays via USB. From what I've seen, USB support is more robust than DLNA. There's nothing Serviio can do about that except transcode the file into something the TV supports.
It might be worth seeing what video and audio codecs your file contains. Get the media info and post it back here.
Resonate
Post Tue Dec 22, 2015 10:56 am
Re: 4K Support
Hope this is correct!
C:\Program Files\Serviio\lib>ffmpeg.exe -i D:\UHD1.by.Astra.2160p.UHDTV.MP2.HEVC.x265-LiebeIst.mkv
ffmpeg version 2.4.git Copyright (c) 2000-2014 the FFmpeg developers
built on Nov 19 2014 22:12:09 with gcc 4.7.2 (GCC)
configuration: --enable-static --disable-shared --disable-ffplay --disable-ffserver --enable-memalign-hack --enable-libmp3lame --enable-libass --enable-librtmp --enable-fontconfig --enable-libfreetype --enable-zlib --enable-libx264 --enable-libspeex --extra-libs='-lrtmp -lpolarssl -lws2_32 -lwinmm -lexpat -lfreetype -lfribidi -lz' --arch=x86 --enable-runtime-cpudetect --enable-pthreads --target-os=mingw32 --cross-prefix=i686-w64-mingw32- --enable-gpl --pkg-config=pkg-config
libavutil 54. 14.100 / 54. 14.100
libavcodec 56. 12.101 / 56. 12.101
libavformat 56. 14.100 / 56. 14.100
libavdevice 56. 3.100 / 56. 3.100
libavfilter 5. 2.103 / 5. 2.103
libswscale 3. 1.101 / 3. 1.101
libswresample 1. 1.100 / 1. 1.100
libpostproc 53. 3.100 / 53. 3.100
[hevc @ 03C93120] Could not find ref with POC 96
[hevc @ 03C93120] Could not find ref with POC 92
[hevc @ 03C93120] Could not find ref with POC 88
Input #0, matroska,webm, from 'D:\UHD1.by.Astra.2160p.UHDTV.MP2.HEVC.x265-LiebeIst.mkv':
encoder : libebml v1.3.1 + libmatroska v1.4.2
creation_time : 2015-10-03 14:34:39
Duration: 00:17:25.91, start: 0.140000, bitrate: 18163 kb/s
Stream #0:0: Video: hevc (Main 10), yuv420p10le(tv), 3840x2160, SAR 1:1 DAR 16:9, 50 fps, 50 tbr, 1k tbn, 50 tbc (default)
BPS : 17970404
BPS-eng : 17970404
DURATION : 00:17:25.760000000
DURATION-eng : 00:17:25.760000000
NUMBER_OF_FRAMES: 52199
NUMBER_OF_FRAMES-eng: 52199
NUMBER_OF_BYTES : 2349091245
NUMBER_OF_BYTES-eng: 2349091245
_STATISTICS_WRITING_APP: mkvmerge v8.0.0 ('Til The Day That I Die') 64bit
_STATISTICS_WRITING_APP-eng: mkvmerge v8.0.0 ('Til The Day That I Die') 64bit
_STATISTICS_WRITING_DATE_UTC: 2015-10-03 14:34:39
_STATISTICS_WRITING_DATE_UTC-eng: 2015-10-03 14:34:39
_STATISTICS_TAGS: BPS DURATION NUMBER_OF_FRAMES NUMBER_OF_BYTES
_STATISTICS_TAGS-eng: BPS DURATION NUMBER_OF_FRAMES NUMBER_OF_BYTES
Stream #0:1(ger): Audio: mp2, 48000 Hz, stereo, s16p, 192 kb/s (default)
BPS : 192000
BPS-eng : 192000
DURATION : 00:17:25.752000000
DURATION-eng : 00:17:25.752000000
NUMBER_OF_FRAMES: 43573
NUMBER_OF_FRAMES-eng: 43573
NUMBER_OF_BYTES : 25098048
NUMBER_OF_BYTES-eng: 25098048
Post Thu Dec 24, 2015 7:38 pm
Re: 4K Support
The one thing I noticed is your FFMPEG is over a year old. It's possible it doesn't contain x265 support. I can't compare it to my version, as I always replace the Serviio included version with a later 64 bit version. What version of Serviio are you using?
Users browsing this forum: No registered users and 72 guests
