Serviio only stream ~1h of the full file
gvardian
Post Fri Dec 18, 2015 6:31 am
ffmpeg reports as duration 01:51:32.11 however serviio only sees 1h
$ ffmpeg -i file.avi
ffmpeg version 2.7.3-0ubuntu0.15.10.1 Copyright (c) 2000-2015 the FFmpeg developers
built with gcc 5.2.1 (Ubuntu 5.2.1-22ubuntu2) 20151010
configuration: --prefix=/usr --extra-version=0ubuntu0.15.10.1 --build-suffix=-ffmpeg --toolchain=hardened --libdir=/usr/lib/x86_64-linux-gnu --incdir=/usr/include/x86_64-linux-gnu --enable-gpl --enable-shared --disable-stripping --enable-avresample --enable-avisynth --enable-frei0r --enable-gnutls --enable-ladspa --enable-libass --enable-libbluray --enable-libbs2b --enable-libcaca --enable-libcdio --enable-libflite --enable-libfontconfig --enable-libfreetype --enable-libfribidi --enable-libgme --enable-libgsm --enable-libmodplug --enable-libmp3lame --enable-libopenjpeg --enable-openal --enable-libopus --enable-libpulse --enable-librtmp --enable-libschroedinger --enable-libshine --enable-libspeex --enable-libtheora --enable-libtwolame --enable-libvorbis --enable-libvpx --enable-libwavpack --enable-libwebp --enable-libxvid --enable-libzvbi --enable-opengl --enable-x11grab --enable-libdc1394 --enable-libiec61883 --enable-libzmq --enable-libssh --enable-libsoxr --enable-libx264 --enable-libopencv --enable-libx265
libavutil 54. 27.100 / 54. 27.100
libavcodec 56. 41.100 / 56. 41.100
libavformat 56. 36.100 / 56. 36.100
libavdevice 56. 4.100 / 56. 4.100
libavfilter 5. 16.101 / 5. 16.101
libavresample 2. 1. 0 / 2. 1. 0
libswscale 3. 1.101 / 3. 1.101
libswresample 1. 2.100 / 1. 2.100
libpostproc 53. 3.100 / 53. 3.100
Input #0, avi, from 'file.avi':
Duration: 01:51:32.11, start: 0.000000, bitrate: 1824 kb/s
Stream #0:0: Video: mpeg4 (Advanced Simple Profile) (XVID / 0x44495658), yuv420p, 720x304 [SAR 1:1 DAR 45:19], 1431 kb/s, 23.98 fps, 23.98 tbr, 23.98 tbn, 23.98 tbc
Stream #0:1: Audio: ac3 ([0] [0][0] / 0x2000), 48000 Hz, 5.1(side), fltp, 384 kb/s
Serviio logs show the following:
015-12-17 22:05:15,897 WARN [ProcessExecutor] Process ffmpeg has a return code of 137! This is a possible error. Detailed output follows.
frame= 121 fps= 80 q=6.8 size= 786kB time=00:00:05.61 bitrate=1146.8kbits/s
frame= 179 fps= 89 q=5.6 size= 1127kB time=00:00:08.04 bitrate=1147.6kbits/s
frame= 239 fps= 95 q=6.2 size= 1495kB time=00:00:10.55 bitrate=1160.1kbits/s
frame= 295 fps= 98 q=5.7 size= 1836kB time=00:00:12.87 bitrate=1167.8kbits/s
frame= 354 fps=101 q=9.6 size= 2217kB time=00:00:15.36 bitrate=1182.1kbits/s
File opened directly via SMB works perfectly.
Post Sat Dec 19, 2015 1:26 am
Re: Serviio only stream ~1h of the full file
Which device are you playing to, what profile? Try remuxing the file - often corrects AVI container errors:
ffmpeg -i "file.avi" -c copy -map 0 "newfile.avi"
gvardian
Post Sat Dec 19, 2015 6:23 pm
Thanks for the update.
The Device and profile are for an LG TV.
Remuxing the file gave me an additional 10 min however i'm still missing 20.
From the MediaBrowser the same length is displayed(as in the TV) for both files.
Regards,
Pedro
Post Sat Dec 19, 2015 9:09 pm
Make sure you have enough space in the transcoding folder.
BaronDandy
Post Sun Dec 27, 2015 1:58 pm
zip wrote:Make sure you have enough space in the transcoding folder.
The same is happening to me, only 1:03h in 90% of mkv files.
I'm streaming to a samsung d8000 from a lenovo laptop with windows 10, core i7 4710hq cpu and 16gb ram.
I have enough space in the transcode folder (c:/windows/temp), 750gb free.
Post Mon Dec 28, 2015 5:25 pm
Does it actually stop playing the file at 1 hour? I noticed this on a Samsung as well.. basically they ignore the duration sent to them and derive it from something else (perhaps a fake file size that is used for transcoded files).
Post Mon Dec 28, 2015 5:26 pm
Or try to upgrade FFmpeg.
BaronDandy
Post Mon Dec 28, 2015 6:18 pm
zip wrote:Does it actually stop playing the file at 1 hour? I noticed this on a Samsung as well.. basically they ignore the duration sent to them and derive it from something else (perhaps a fake file size that is used for transcoded files).
Exactly, the timer is showing the proper time (1:03:27), and stops playing when it reach that point.
I forgot to say before that I'm using the samsung C/D series profile.
Do you need any log file?
BaronDandy
Post Mon Dec 28, 2015 6:31 pm
I tried to stream to an xbox one, same file, and it worked fine: 1:56:26
Strange issue.
Users browsing this forum: Baidu [Spider] and 16 guests
