Sony BluRay Players (BDP-S370)
Post Tue Feb 22, 2011 1:51 pm
Re: [Profile] Sony BluRay Players (BDP-S370)
Please read FAQ: viewtopic.php?f=5&t=1126&p=5340#p5344
Picard007 wrote:Is the 60hz problem (MKV stream over Network - LCD show 1080p/60hz instead of 24Hz) still there ?
I'll check on mine
Picard007 wrote:Did the S-370 show the embedded subtitles (stream Network / serviio)?
Read FAQ:
-Embedded Subtitles not supported in MPEG program streams (VOB files in other words). The player supports these from disc, but not via DLNA
but
- Embedded Subtitles and Multi Audio Tracks are supported from MKV and MPEG Transport Stream files over DLNA (European model)
Picard007
Post Tue Feb 22, 2011 2:10 pm
Thank you.
one further question..
must serviio transcode MKV Files ?
Post Tue Feb 22, 2011 2:59 pm
Picard007 wrote:must serviio transcode MKV Files ?
See here for Serviio supported format: http://www.serviio.org/features
But, if you have a look on Sony BDP (EU) profile, viewtopic.php?f=5&t=1126&p=5343#p5341
Default, Serviio will transcode MKV to MPEG2 Transport Stream, but you will find that Serviio could streams MKV in native format, by removing some section on the profile:
remove all matroska transcoding matches if you stream over a wired connection and want mkv subtitle support and alt audio
tracks
Picard007
Post Tue Feb 22, 2011 3:29 pm
Great Support ! Thanks again.
I look forward to your test (MKV 60hz).
sorry i am newbie... wich lines i have to change? I´ve searched in this forum but...
  <Profile id="10" name="Sony BD Player (EU)" extendsProfileId="1">
          <!-- European models only - check Serviio forums for profiles for other regions -->
          <Detection>
             <HttpHeaders>
                <X-AV-Client-Info>.*Blu-ray Disc Player.*</X-AV-Client-Info>
             </HttpHeaders>
          </Detection>
          <MediaFormatProfiles>
             <!-- force DLNA profile names of supported formats -->
             <!-- e.g. though renderer should support wma, it only does so when disguised as mp3 -->
             <MediaFormatProfile mime-type="audio/mpeg" name="MP3">WMA_BASE</MediaFormatProfile>
             <MediaFormatProfile mime-type="audio/mpeg" name="MP3">WMA_FULL</MediaFormatProfile>
             <!-- set mkv to divx mime-type to allow subtitle and multiple audio track support -->
             <MediaFormatProfile mime-type="video/divx">MATROSKA</MediaFormatProfile>
             <!-- for mp4 containers, set MPEG_PS_PAL DLNA profile -->
             <MediaFormatProfile mime-type="video/mp4" name="MPEG_PS_PAL">AVC_MP4_MP_SD_AAC_MULT5</MediaFormatProfile>
             <MediaFormatProfile mime-type="video/mp4" name="MPEG_PS_PAL">AVC_MP4_MP_SD_MPEG1_L3</MediaFormatProfile>
             <MediaFormatProfile mime-type="video/mp4" name="MPEG_PS_PAL">AVC_MP4_MP_SD_AC3</MediaFormatProfile>
             <MediaFormatProfile mime-type="video/mp4" name="MPEG_PS_PAL">AVC_MP4_MP_HD_720p_AAC</MediaFormatProfile>
             <MediaFormatProfile mime-type="video/mp4" name="MPEG_PS_PAL">AVC_MP4_MP_HD_1080i_AAC</MediaFormatProfile>
             <MediaFormatProfile mime-type="video/mp4" name="MPEG_PS_PAL">AVC_MP4_HP_HD_AAC</MediaFormatProfile>
             <MediaFormatProfile mime-type="video/mp4" name="MPEG_PS_PAL">AVC_MP4_LPCM</MediaFormatProfile>
             <MediaFormatProfile mime-type="video/mp4" name="MPEG_PS_PAL">MPEG4_P2_MP4_ASP_AAC</MediaFormatProfile>
             <MediaFormatProfile mime-type="video/mp4" name="MPEG_PS_PAL">MPEG4_P2_MP4_SP_L6_AAC</MediaFormatProfile>
             <MediaFormatProfile mime-type="video/mp4" name="MPEG_PS_PAL">MPEG4_P2_MP4_NDSD</MediaFormatProfile>
             <!-- for mpeg transport streams, set MPEG_TS_SD_EU DLNA profile -->
             <MediaFormatProfile mime-type="video/vnd.dlna.mpeg-tts" name="MPEG_TS_SD_EU">AVC_TS_MP_SD_AAC_MULT5</MediaFormatProfile>
             <MediaFormatProfile mime-type="video/vnd.dlna.mpeg-tts" name="MPEG_TS_SD_EU">AVC_TS_MP_SD_AAC_MULT5_T</MediaFormatProfile>
             <MediaFormatProfile mime-type="video/vnd.dlna.mpeg-tts" name="MPEG_TS_SD_EU">AVC_TS_MP_SD_AAC_MULT5_ISO</MediaFormatProfile>
             <MediaFormatProfile mime-type="video/vnd.dlna.mpeg-tts" name="MPEG_TS_SD_EU">AVC_TS_MP_SD_MPEG1_L3</MediaFormatProfile>
             <MediaFormatProfile mime-type="video/vnd.dlna.mpeg-tts" name="MPEG_TS_SD_EU">AVC_TS_MP_SD_MPEG1_L3_T</MediaFormatProfile>
             <MediaFormatProfile mime-type="video/vnd.dlna.mpeg-tts" name="MPEG_TS_SD_EU">AVC_TS_MP_SD_MPEG1_L3_ISO</MediaFormatProfile>
             <MediaFormatProfile mime-type="video/vnd.dlna.mpeg-tts" name="MPEG_TS_SD_EU">AVC_TS_MP_SD_AC3</MediaFormatProfile>
             <MediaFormatProfile mime-type="video/vnd.dlna.mpeg-tts" name="MPEG_TS_SD_EU">AVC_TS_MP_SD_AC3_T</MediaFormatProfile>
             <MediaFormatProfile mime-type="video/vnd.dlna.mpeg-tts" name="MPEG_TS_SD_EU">AVC_TS_MP_SD_AC3_ISO</MediaFormatProfile>
             <MediaFormatProfile mime-type="video/vnd.dlna.mpeg-tts" name="MPEG_TS_SD_EU">AVC_TS_MP_HD_AAC_MULT5</MediaFormatProfile>
             <MediaFormatProfile mime-type="video/vnd.dlna.mpeg-tts" name="MPEG_TS_SD_EU">AVC_TS_MP_HD_AAC_MULT5_T</MediaFormatProfile>
             <MediaFormatProfile mime-type="video/vnd.dlna.mpeg-tts" name="MPEG_TS_SD_EU">AVC_TS_MP_HD_AAC_MULT5_ISO</MediaFormatProfile>
             <MediaFormatProfile mime-type="video/vnd.dlna.mpeg-tts" name="MPEG_TS_SD_EU">AVC_TS_MP_HD_MPEG1_L3</MediaFormatProfile>
             <MediaFormatProfile mime-type="video/vnd.dlna.mpeg-tts" name="MPEG_TS_SD_EU">AVC_TS_MP_HD_MPEG1_L3_T</MediaFormatProfile>
             <MediaFormatProfile mime-type="video/vnd.dlna.mpeg-tts" name="MPEG_TS_SD_EU">AVC_TS_MP_HD_MPEG1_L3_ISO</MediaFormatProfile>
             <MediaFormatProfile mime-type="video/vnd.dlna.mpeg-tts" name="MPEG_TS_SD_EU">AVC_TS_MP_HD_AC3</MediaFormatProfile>
             <MediaFormatProfile mime-type="video/vnd.dlna.mpeg-tts" name="MPEG_TS_SD_EU">AVC_TS_MP_HD_AC3_T</MediaFormatProfile>
             <MediaFormatProfile mime-type="video/vnd.dlna.mpeg-tts" name="MPEG_TS_SD_EU">AVC_TS_MP_HD_AC3_ISO</MediaFormatProfile>
             <MediaFormatProfile mime-type="video/vnd.dlna.mpeg-tts" name="MPEG_TS_SD_EU">AVC_TS_HD_DTS_T</MediaFormatProfile>
             <MediaFormatProfile mime-type="video/vnd.dlna.mpeg-tts" name="MPEG_TS_SD_EU">AVC_TS_HD_DTS_ISO</MediaFormatProfile>
             <MediaFormatProfile mime-type="video/vnd.dlna.mpeg-tts" name="MPEG_TS_SD_EU">AVC_TS_HD_50_LPCM_T</MediaFormatProfile>
             <MediaFormatProfile mime-type="video/vnd.dlna.mpeg-tts" name="MPEG_TS_SD_EU">AVC_TS_HP_SD_MPEG1_L2_ISO</MediaFormatProfile>
             <MediaFormatProfile mime-type="video/vnd.dlna.mpeg-tts" name="MPEG_TS_SD_EU">AVC_TS_HP_SD_MPEG1_L2_T</MediaFormatProfile>
             <MediaFormatProfile mime-type="video/vnd.dlna.mpeg-tts" name="MPEG_TS_SD_EU">AVC_TS_HP_HD_MPEG1_L2_ISO</MediaFormatProfile>
             <MediaFormatProfile mime-type="video/vnd.dlna.mpeg-tts" name="MPEG_TS_SD_EU">AVC_TS_HP_HD_MPEG1_L2_T</MediaFormatProfile>
             <MediaFormatProfile mime-type="video/vnd.dlna.mpeg-tts" name="MPEG_TS_SD_EU">MPEG4_P2_TS_ASP_AAC</MediaFormatProfile>
             <MediaFormatProfile mime-type="video/vnd.dlna.mpeg-tts" name="MPEG_TS_SD_EU">MPEG4_P2_TS_ASP_AAC_T</MediaFormatProfile>
             <MediaFormatProfile mime-type="video/vnd.dlna.mpeg-tts" name="MPEG_TS_SD_EU">MPEG4_P2_TS_ASP_AAC_ISO</MediaFormatProfile>
             <MediaFormatProfile mime-type="video/vnd.dlna.mpeg-tts" name="MPEG_TS_SD_EU">MPEG4_P2_TS_ASP_AC3</MediaFormatProfile>
             <MediaFormatProfile mime-type="video/vnd.dlna.mpeg-tts" name="MPEG_TS_SD_EU">MPEG4_P2_TS_ASP_AC3_T</MediaFormatProfile>
             <MediaFormatProfile mime-type="video/vnd.dlna.mpeg-tts" name="MPEG_TS_SD_EU">MPEG4_P2_TS_ASP_AC3_ISO</MediaFormatProfile>
             <MediaFormatProfile mime-type="video/vnd.dlna.mpeg-tts" name="MPEG_TS_SD_EU">MPEG4_P2_TS_ASP_MPEG1_L3</MediaFormatProfile>
             <MediaFormatProfile mime-type="video/vnd.dlna.mpeg-tts" name="MPEG_TS_SD_EU">MPEG4_P2_TS_ASP_MPEG1_L3_T</MediaFormatProfile>
             <MediaFormatProfile mime-type="video/vnd.dlna.mpeg-tts" name="MPEG_TS_SD_EU">MPEG4_P2_TS_ASP_MPEG1_L3_ISO</MediaFormatProfile>
             <MediaFormatProfile mime-type="video/vnd.dlna.mpeg-tts" name="MPEG_TS_SD_EU">VC1_TS_AP_L1_AC3_ISO</MediaFormatProfile>
             <MediaFormatProfile mime-type="video/vnd.dlna.mpeg-tts" name="MPEG_TS_SD_EU">VC1_TS_AP_L2_AC3_ISO</MediaFormatProfile>
          </MediaFormatProfiles>
             <!-- remux to mpeg-ts and transcode audio -->
                <!-- Sony BDP requests all formats except mpeg-ps and mpeg-ts in 32KB chunks which works badly over wifi -->
                   tracks
             <!-- remux container only, to minimize server CPU overhead and quality loss -->
                   tracks
                <!-- remux mp4 container files to mpeg-ts to allow seeking -->
                <!-- this also fixes the renderer's jerky playback of mov container files such as iPhone 4 HD video recordings -->
             <!-- unsupported codecs will be transcoded into mpeg-ts, mpeg2 video and ac3 audio -->
                <Matches container="asf" />
                <Matches container="flv" />
                <!-- digital camera video formats -->
Post Tue Feb 22, 2011 4:35 pm
Replace the Section id="10" with this on the profiles.xml file, restart the serviio service
          <Detection>
             <HttpHeaders>
             </HttpHeaders>
          </Detection>
I only remove all matroska transcoding matches sub section
<Matches container="matroska" ........ />
Post Tue Feb 22, 2011 8:31 pm
Check the video profile with "DISPLAY" remote button pressed:
Profile AVC_TS_MP_HD_AC3_T Delivered files *.m2ts in native format
MPEG2TS, AVC/H264 M@4.1 1280x528 with 23,976 fps => Display 1080/60p
MPEG2TS, AVC/H264 H@4.1 1920x1080 with 29,970 fps => Display 1080/60p
MPEG2TS, AVC/H264 H@4.0 1920x818 with 24,000 fps => Display 1080/60p
Profile MATROSKA Delivered files *.mkv in native format
MKV, AVC/H264 H@4.0 1920x818 with 24,000 fps => Display 1080/60p
MKV, AVC/H264 H@4.0 1920x1080 with 24.000 fps => Display 1080/60p
fiferboy
Post Tue Feb 22, 2011 8:38 pm
I have a Canadian Sony S370 running the latest firmware. I could not play videos with the US or EU profile, but adding the Canadian profile has resulted in flawless playback.
I will try to test more video types in the near future, but mp4, mov, avi, and mts files have all been fine. Playing/pausing definitely works, but I can't remember if I tried scanning forward and back. I will try that tonight.
If there are any file types I should specifically try I will do so.
Post Wed Feb 23, 2011 7:55 am
fiferboy wrote:I have a Canadian Sony S370 running the latest firmware. I could not play videos with the US or EU profile, but adding the Canadian profile has resulted in flawless playback.
Good, I suppose you used CA 0.4.2 Profile?
Could you try this updated CA 0.5 Profile? (add some new 0.5 profile AVC-DTS, and format support, flv, camecorder, etc)
<Profile id="10" name="Sony BD Player (CA)" extendsProfileId="1">
      <!-- Canadian models -->
         <!-- CA players need most movie types to be forced to video/mpeg and MPEG_PS_PAL DLNA profile -->
         <MediaFormatProfile mime-type="video/mpeg" name="MPEG_PS_NTSC">AVC_MP4_MP_SD_AAC_MULT5</MediaFormatProfile>
         <MediaFormatProfile mime-type="video/mpeg" name="MPEG_PS_NTSC">AVC_MP4_MP_SD_MPEG1_L3</MediaFormatProfile>
         <MediaFormatProfile mime-type="video/mpeg" name="MPEG_PS_NTSC">AVC_MP4_MP_SD_AC3</MediaFormatProfile>
         <MediaFormatProfile mime-type="video/mpeg" name="MPEG_PS_NTSC">AVC_MP4_MP_HD_720p_AAC</MediaFormatProfile>
         <MediaFormatProfile mime-type="video/mpeg" name="MPEG_PS_NTSC">AVC_MP4_MP_HD_1080i_AAC</MediaFormatProfile>
         <MediaFormatProfile mime-type="video/mpeg" name="MPEG_PS_NTSC">AVC_MP4_HP_HD_AAC</MediaFormatProfile>
         <MediaFormatProfile mime-type="video/mpeg" name="MPEG_PS_NTSC">AVC_MP4_LPCM</MediaFormatProfile>
         <MediaFormatProfile mime-type="video/mpeg" name="MPEG_PS_NTSC">MPEG4_P2_MP4_ASP_AAC</MediaFormatProfile>
         <MediaFormatProfile mime-type="video/mpeg" name="MPEG_PS_NTSC">MPEG4_P2_MP4_SP_L6_AAC</MediaFormatProfile>
         <MediaFormatProfile mime-type="video/mpeg" name="MPEG_PS_NTSC">MPEG4_P2_MP4_NDSD</MediaFormatProfile>
         <MediaFormatProfile mime-type="video/vnd.dlna.mpeg-tts" name="MPEG_TS_SD_NA">AVC_TS_MP_SD_AAC_MULT5</MediaFormatProfile>
         <MediaFormatProfile mime-type="video/vnd.dlna.mpeg-tts" name="MPEG_TS_SD_NA">AVC_TS_MP_SD_AAC_MULT5_T</MediaFormatProfile>
         <MediaFormatProfile mime-type="video/vnd.dlna.mpeg-tts" name="MPEG_TS_SD_NA">AVC_TS_MP_SD_AAC_MULT5_ISO</MediaFormatProfile>
         <MediaFormatProfile mime-type="video/vnd.dlna.mpeg-tts" name="MPEG_TS_SD_NA">AVC_TS_MP_SD_MPEG1_L3</MediaFormatProfile>
         <MediaFormatProfile mime-type="video/vnd.dlna.mpeg-tts" name="MPEG_TS_SD_NA">AVC_TS_MP_SD_MPEG1_L3_T</MediaFormatProfile>
         <MediaFormatProfile mime-type="video/vnd.dlna.mpeg-tts" name="MPEG_TS_SD_NA">AVC_TS_MP_SD_MPEG1_L3_ISO</MediaFormatProfile>
         <MediaFormatProfile mime-type="video/vnd.dlna.mpeg-tts" name="MPEG_TS_SD_NA">AVC_TS_MP_SD_AC3</MediaFormatProfile>
         <MediaFormatProfile mime-type="video/vnd.dlna.mpeg-tts" name="MPEG_TS_SD_NA">AVC_TS_MP_SD_AC3_T</MediaFormatProfile>
         <MediaFormatProfile mime-type="video/vnd.dlna.mpeg-tts" name="MPEG_TS_SD_NA">AVC_TS_MP_SD_AC3_ISO</MediaFormatProfile>
         <MediaFormatProfile mime-type="video/vnd.dlna.mpeg-tts" name="MPEG_TS_SD_NA">AVC_TS_MP_HD_AAC_MULT5</MediaFormatProfile>
         <MediaFormatProfile mime-type="video/vnd.dlna.mpeg-tts" name="MPEG_TS_SD_NA">AVC_TS_MP_HD_AAC_MULT5_T</MediaFormatProfile>
         <MediaFormatProfile mime-type="video/vnd.dlna.mpeg-tts" name="MPEG_TS_SD_NA">AVC_TS_MP_HD_AAC_MULT5_ISO</MediaFormatProfile>
         <MediaFormatProfile mime-type="video/vnd.dlna.mpeg-tts" name="MPEG_TS_SD_NA">AVC_TS_MP_HD_MPEG1_L3</MediaFormatProfile>
         <MediaFormatProfile mime-type="video/vnd.dlna.mpeg-tts" name="MPEG_TS_SD_NA">AVC_TS_MP_HD_MPEG1_L3_T</MediaFormatProfile>
         <MediaFormatProfile mime-type="video/vnd.dlna.mpeg-tts" name="MPEG_TS_SD_NA">AVC_TS_MP_HD_MPEG1_L3_ISO</MediaFormatProfile>
         <MediaFormatProfile mime-type="video/vnd.dlna.mpeg-tts" name="MPEG_TS_SD_NA">AVC_TS_MP_HD_AC3</MediaFormatProfile>
         <MediaFormatProfile mime-type="video/vnd.dlna.mpeg-tts" name="MPEG_TS_SD_NA">AVC_TS_MP_HD_AC3_T</MediaFormatProfile>
         <MediaFormatProfile mime-type="video/vnd.dlna.mpeg-tts" name="MPEG_TS_SD_NA">AVC_TS_MP_HD_AC3_ISO</MediaFormatProfile>
         <MediaFormatProfile mime-type="video/vnd.dlna.mpeg-tts" name="MPEG_TS_SD_NA">AVC_TS_HD_DTS_T</MediaFormatProfile>
         <MediaFormatProfile mime-type="video/vnd.dlna.mpeg-tts" name="MPEG_TS_SD_NA">AVC_TS_HD_DTS_ISO</MediaFormatProfile>
         <MediaFormatProfile mime-type="video/vnd.dlna.mpeg-tts" name="MPEG_TS_SD_NA">AVC_TS_HD_50_LPCM_T</MediaFormatProfile>
         <MediaFormatProfile mime-type="video/vnd.dlna.mpeg-tts" name="MPEG_TS_SD_NA">AVC_TS_HP_SD_MPEG1_L2_ISO</MediaFormatProfile>
         <MediaFormatProfile mime-type="video/vnd.dlna.mpeg-tts" name="MPEG_TS_SD_NA">AVC_TS_HP_SD_MPEG1_L2_T</MediaFormatProfile>
         <MediaFormatProfile mime-type="video/vnd.dlna.mpeg-tts" name="MPEG_TS_SD_NA">AVC_TS_HP_HD_MPEG1_L2_ISO</MediaFormatProfile>
         <MediaFormatProfile mime-type="video/vnd.dlna.mpeg-tts" name="MPEG_TS_SD_NA">AVC_TS_HP_HD_MPEG1_L2_T</MediaFormatProfile>
         <MediaFormatProfile mime-type="video/vnd.dlna.mpeg-tts" name="MPEG_TS_SD_NA">MPEG4_P2_TS_ASP_AAC</MediaFormatProfile>
         <MediaFormatProfile mime-type="video/vnd.dlna.mpeg-tts" name="MPEG_TS_SD_NA">MPEG4_P2_TS_ASP_AAC_T</MediaFormatProfile>
         <MediaFormatProfile mime-type="video/vnd.dlna.mpeg-tts" name="MPEG_TS_SD_NA">MPEG4_P2_TS_ASP_AAC_ISO</MediaFormatProfile>
         <MediaFormatProfile mime-type="video/vnd.dlna.mpeg-tts" name="MPEG_TS_SD_NA">MPEG4_P2_TS_ASP_AC3</MediaFormatProfile>
         <MediaFormatProfile mime-type="video/vnd.dlna.mpeg-tts" name="MPEG_TS_SD_NA">MPEG4_P2_TS_ASP_AC3_T</MediaFormatProfile>
         <MediaFormatProfile mime-type="video/vnd.dlna.mpeg-tts" name="MPEG_TS_SD_NA">MPEG4_P2_TS_ASP_AC3_ISO</MediaFormatProfile>
         <MediaFormatProfile mime-type="video/vnd.dlna.mpeg-tts" name="MPEG_TS_SD_NA">MPEG4_P2_TS_ASP_MPEG1_L3</MediaFormatProfile>
         <MediaFormatProfile mime-type="video/vnd.dlna.mpeg-tts" name="MPEG_TS_SD_NA">MPEG4_P2_TS_ASP_MPEG1_L3_T</MediaFormatProfile>
         <MediaFormatProfile mime-type="video/vnd.dlna.mpeg-tts" name="MPEG_TS_SD_NA">MPEG4_P2_TS_ASP_MPEG1_L3_ISO</MediaFormatProfile>
         <MediaFormatProfile mime-type="video/vnd.dlna.mpeg-tts" name="MPEG_TS_SD_NA">VC1_TS_AP_L1_AC3_ISO</MediaFormatProfile>
         <MediaFormatProfile mime-type="video/vnd.dlna.mpeg-tts" name="MPEG_TS_SD_NA">VC1_TS_AP_L2_AC3_ISO</MediaFormatProfile>
         <!-- unsupported codecs will be transcoded into mpeg2ts, mpeg2video and ac3 audio (MPEG_TS_SD_EU). -->
Post Wed Feb 23, 2011 10:01 am
I thought we only have EU/US profiles now. There will be just 1 profile in 0.5.1 which serves the files with both profile names (NTSC/PAL etc) but the same mime type and transcoding config.
fiferboy
Post Wed Feb 23, 2011 1:08 pm
I have copied this new profile into my config and restarted serviio. I will test it tonight and report back.
zip: Will the Canadian version work with the single US/EU profile in 0.5.1? My player did not work with either version when I tried them in 0.5 the other day. I Will be happy to test that in 0.5.1 when there is a beta.
fiferboy
Post Thu Feb 24, 2011 1:12 pm
The updated Canadian profile worked well with my usual videos. I am going to try to find some sample videos in different formats to test out as well.
Post Thu Feb 24, 2011 4:21 pm
The only differences between updated CA 0.5 profile and US 0.5 profile are:
CA
USA
<MediaFormatProfile mime-type="video/mpeg" name="MPEG_PS_NTSC">MATROSKA</MediaFormatProfile>
<MediaFormatProfile mime-type="video/mpeg" name="MPEG_PS_NTSC">AVI</MediaFormatProfile>
1) Could you check that with updated CA profile, MKV and AVI are well displayed ?
2) Could you try to modified the updated CA with these two US lines and check that MKV and AVI are not displayed?
fiferboy
Post Thu Feb 24, 2011 4:42 pm
Illico: I have been playing AVI files without issue. I will try MKV tonight and make sure they play. Then I will take out those lines and try them again.
I am already pretty sure the AVI files won't play without those lines, because they weren't playing with the US profile. I will confirm this for you tonight.
fiferboy
Post Fri Feb 25, 2011 2:42 am
Okay, I have confirmed with the updated Canadian profile I can play AVI and MKV files very well - they start playing immediately.
If I switch to the US profile, I can still play AVI and MKV files, but they take a long time to start, presumably because they are being encoded to a format the US player understands.
If I change my Canadian profile lines to the US lines as you specified (which I think is what you wanted me to do) it still plays the AVI files after encoding on-the-fly with the same delay to start. I could not test the MKV with this profile change, because it was not displayed in the file list.
All-in-all, the Canadian profile is best for me because there is no re-encoding of AVI and MKV files. I'm sure if I took the transcoding section out of the US profile the AVI and MKV files would fail to play. I can test that if it would be helpful.
Post Fri Feb 25, 2011 8:54 am
fiferboy wrote:Okay, I have confirmed with the updated Canadian profile I can play AVI and MKV files very well - they start playing immediately.
OK, good
fiferboy wrote:If I switch to the US profile, I can still play AVI and MKV files, but they take a long time to start, presumably because they are being encoded to a format the US player understands.
Could you check the logging file when you start theses files to confirm the encoding?
fiferboy wrote:If I change my Canadian profile lines to the US lines as you specified (which I think is what you wanted me to do) it still plays the AVI files after encoding on-the-fly with the same delay to start. I could not test the MKV with this profile change, because it was not displayed in the file list.
YES I confirm, that I only want you to change your Canadian profile with these two US lines I specified (this is the only differences between the two US and CA 0.5 version, except transcoding section).
Could you check the logging file at the point too?
CA updated profile:
CA with US two lines modified:
wotg
Post Wed Mar 02, 2011 1:07 am
Hi everyone,
I have a few questions on European profile:
1. When streaming files in mp4 container and h264 vCodec, they are demuxed into mpegts. Why does the profile limit the demuxing applied to h264 materials only? Can we delete vCodec="h264" in the <Matches container> or add divx, xvid to the <Matches container>?
2. In order for FF/Rewind to work in mp4 files, do we have to wait unit the whole file is demuxed, or they are supposed to work on the fly during demuxing? My experience on this functionality was a bit inconsistent. Sometimes FF/Rewind worked, sometimes not. Sometimes rebooting the Sony solved the FF/Rewind problem. I am a bit lost.
3. For mkv files with dts audio, the audio track is trancoded into 2ch ac3. Can serviio output multi-channel ac3 track instead of 2ch only? Can I specifiy the output ac3 bit rate?
4. What modifcations should be made to trancode multi-channel PCM audio in mkv files to multi-channel ac3?
Regards,
wotg
CaptainRewind
Post Tue Mar 08, 2011 4:35 am
I am using Ubuntu 10.04 and a Sony BDP-S370.
I have been trying in great detail to stream .mkv files to my device, with no success. I have posted on the PS3 Media Server forums (see here http://www.ps3mediaserver.org/forum/viewtopic.php?f=15&t=6930&start=270#p46841 ) as well, and thought I'd give Serviio a try.
Currently in Serviio I am able to get the folder to show up, and it contains an HD mkv file (ffmpeg output below). Additionally, I have applied the changes for US devices to the profiles.xml and have applied that profile to the BDP-S370 device in the serviio console.
Unfortunately the player returns an error that my Folder contains no playable media (Video) file.
$ ffmpeg -i ./Iron_Man_2-DivXPlusHD.mkv
FFmpeg version git-6a7e074, Copyright (c) 2000-2011 the FFmpeg developers
  built on Mar  7 2011 22:40:00 with gcc 4.4.3
  configuration: --enable-gpl --enable-version3 --enable-nonfree --enable-postproc --enable-libfaac --enable-libopencore-amrnb --enable-libopencore-amrwb --enable-libtheora --enable-libvorbis --enable-libx264 --enable-libxvid --enable-x11grab
  libavutil    50. 39. 0 / 50. 39. 0
  libavcodec   52.113. 2 / 52.113. 2
  libavformat  52.102. 0 / 52.102. 0
  libavdevice  52.  2. 3 / 52.  2. 3
  libavfilter   1. 76. 0 /  1. 76. 0
  libswscale    0. 12. 0 /  0. 12. 0
  libpostproc  51.  2. 0 / 51.  2. 0
[matroska,webm @ 0x95ae600] Unknown entry 0xC6
[matroska,webm @ 0x95ae600] Unknown entry 0xEA
[matroska,webm @ 0x95ae600] Unknown entry 0x53B8
[matroska,webm @ 0x95ae600] Unknown entry 0x2AD1D3
[matroska,webm @ 0x95ae600] Estimating duration from bitrate, this may be inaccurate
Input #0, matroska,webm, from './Iron_Man_2-DivXPlusHD.mkv':
  Duration: 00:02:30.51, start: 0.000000, bitrate: N/A
    Stream #0.0(eng): Video: h264 (High), yuvj420p, 1920x800 [PAR 1:1 DAR 12:5], 23.98 fps, 23.98 tbr, 1k tbn, 47.95 tbc (default)
    Stream #0.1(eng): Audio: aac, 48000 Hz, stereo, s16 (default)
What other options can I try?
Post Tue Mar 08, 2011 9:31 am
The file is not added to the library because your FFmpeg is too new. 0.5.1 will fix this issue.
krizzz
Post Tue Mar 08, 2011 3:12 pm
Hey Folks, n00b could really use some guidance here. I'm running 0.5.1 (I have tried 4.2, 5.0 and some betas previously) with an S370 (US) with physical ethernet cable. .
I updated my profile with the one below, but I cannot run any video files. I have not ever been able to run them with any version, getting the errors below:
    MKV - The file is corrupted or unsupported
    AVI - There is no playable file.
I downloaded some of the sample MKVs listed in this and other threads with no success. I tried commenting out lines in the XML file, but apparently did something wrong because I couldn't get Seviio to load again.
I ran some MKVs through MKVmerge but no joy.
Also tried different re-encodes with multiple Handbrake profiles, also no help.
Any ideas??? Thanks!!!!
   <Profile id="10" name="Sony BD Player" extendsProfileId="1">
    <!-- Since Serviio 0.5.1 this profile is multiregion -->
      <Detection>
         <HttpHeaders>
         </HttpHeaders>
      </Detection>
         <!-- set mkv to divx mime-type to allow subtitle and multiple audio track support for European and Canadian players -->
      <!-- This native mkv playback disabled by default - read next comment below for reasons -->
         <MediaFormatProfile mime-type="video/mp4" name="MPEG_PS_PAL,MPEG_PS_NTSC">AVC_MP4_MP_SD_AAC_MULT5</MediaFormatProfile>
         <MediaFormatProfile mime-type="video/mp4" name="MPEG_PS_PAL,MPEG_PS_NTSC">AVC_MP4_MP_SD_MPEG1_L3</MediaFormatProfile>
         <MediaFormatProfile mime-type="video/mp4" name="MPEG_PS_PAL,MPEG_PS_NTSC">AVC_MP4_MP_SD_AC3</MediaFormatProfile>
         <MediaFormatProfile mime-type="video/mp4" name="MPEG_PS_PAL,MPEG_PS_NTSC">AVC_MP4_MP_HD_720p_AAC</MediaFormatProfile>
         <MediaFormatProfile mime-type="video/mp4" name="MPEG_PS_PAL,MPEG_PS_NTSC">AVC_MP4_MP_HD_1080i_AAC</MediaFormatProfile>
         <MediaFormatProfile mime-type="video/mp4" name="MPEG_PS_PAL,MPEG_PS_NTSC">AVC_MP4_HP_HD_AAC</MediaFormatProfile>
         <MediaFormatProfile mime-type="video/mp4" name="MPEG_PS_PAL,MPEG_PS_NTSC">AVC_MP4_LPCM</MediaFormatProfile>
         <MediaFormatProfile mime-type="video/mp4" name="MPEG_PS_PAL,MPEG_PS_NTSC">MPEG4_P2_MP4_ASP_AAC</MediaFormatProfile>
         <MediaFormatProfile mime-type="video/mp4" name="MPEG_PS_PAL,MPEG_PS_NTSC">MPEG4_P2_MP4_SP_L6_AAC</MediaFormatProfile>
         <MediaFormatProfile mime-type="video/mp4" name="MPEG_PS_PAL,MPEG_PS_NTSC">MPEG4_P2_MP4_NDSD</MediaFormatProfile>
         <MediaFormatProfile mime-type="video/vnd.dlna.mpeg-tts" name="MPEG_TS_SD_EU,MPEG_TS_SD_NA,MPEG_TS_SD_KO">AVC_TS_MP_SD_AAC_MULT5</MediaFormatProfile>
         <MediaFormatProfile mime-type="video/vnd.dlna.mpeg-tts" name="MPEG_TS_SD_EU,MPEG_TS_SD_NA,MPEG_TS_SD_KO">AVC_TS_MP_SD_AAC_MULT5_T</MediaFormatProfile>
         <MediaFormatProfile mime-type="video/vnd.dlna.mpeg-tts" name="MPEG_TS_SD_EU,MPEG_TS_SD_NA,MPEG_TS_SD_KO">AVC_TS_MP_SD_AAC_MULT5_ISO</MediaFormatProfile>
         <MediaFormatProfile mime-type="video/vnd.dlna.mpeg-tts" name="MPEG_TS_SD_EU,MPEG_TS_SD_NA,MPEG_TS_SD_KO">AVC_TS_MP_SD_MPEG1_L3</MediaFormatProfile>
         <MediaFormatProfile mime-type="video/vnd.dlna.mpeg-tts" name="MPEG_TS_SD_EU,MPEG_TS_SD_NA,MPEG_TS_SD_KO">AVC_TS_MP_SD_MPEG1_L3_T</MediaFormatProfile>
         <MediaFormatProfile mime-type="video/vnd.dlna.mpeg-tts" name="MPEG_TS_SD_EU,MPEG_TS_SD_NA,MPEG_TS_SD_KO">AVC_TS_MP_SD_MPEG1_L3_ISO</MediaFormatProfile>
         <MediaFormatProfile mime-type="video/vnd.dlna.mpeg-tts" name="MPEG_TS_SD_EU,MPEG_TS_SD_NA,MPEG_TS_SD_KO">AVC_TS_MP_SD_AC3</MediaFormatProfile>
         <MediaFormatProfile mime-type="video/vnd.dlna.mpeg-tts" name="MPEG_TS_SD_EU,MPEG_TS_SD_NA,MPEG_TS_SD_KO">AVC_TS_MP_SD_AC3_T</MediaFormatProfile>
         <MediaFormatProfile mime-type="video/vnd.dlna.mpeg-tts" name="MPEG_TS_SD_EU,MPEG_TS_SD_NA,MPEG_TS_SD_KO">AVC_TS_MP_SD_AC3_ISO</MediaFormatProfile>
         <MediaFormatProfile mime-type="video/vnd.dlna.mpeg-tts" name="MPEG_TS_SD_EU,MPEG_TS_SD_NA,MPEG_TS_SD_KO">AVC_TS_MP_HD_AAC_MULT5</MediaFormatProfile>
         <MediaFormatProfile mime-type="video/vnd.dlna.mpeg-tts" name="MPEG_TS_SD_EU,MPEG_TS_SD_NA,MPEG_TS_SD_KO">AVC_TS_MP_HD_AAC_MULT5_T</MediaFormatProfile>
         <MediaFormatProfile mime-type="video/vnd.dlna.mpeg-tts" name="MPEG_TS_SD_EU,MPEG_TS_SD_NA,MPEG_TS_SD_KO">AVC_TS_MP_HD_AAC_MULT5_ISO</MediaFormatProfile>
         <MediaFormatProfile mime-type="video/vnd.dlna.mpeg-tts" name="MPEG_TS_SD_EU,MPEG_TS_SD_NA,MPEG_TS_SD_KO">AVC_TS_MP_HD_MPEG1_L3</MediaFormatProfile>
         <MediaFormatProfile mime-type="video/vnd.dlna.mpeg-tts" name="MPEG_TS_SD_EU,MPEG_TS_SD_NA,MPEG_TS_SD_KO">AVC_TS_MP_HD_MPEG1_L3_T</MediaFormatProfile>
         <MediaFormatProfile mime-type="video/vnd.dlna.mpeg-tts" name="MPEG_TS_SD_EU,MPEG_TS_SD_NA,MPEG_TS_SD_KO">AVC_TS_MP_HD_MPEG1_L3_ISO</MediaFormatProfile>
         <MediaFormatProfile mime-type="video/vnd.dlna.mpeg-tts" name="MPEG_TS_SD_EU,MPEG_TS_SD_NA,MPEG_TS_SD_KO">AVC_TS_MP_HD_AC3</MediaFormatProfile>
         <MediaFormatProfile mime-type="video/vnd.dlna.mpeg-tts" name="MPEG_TS_SD_EU,MPEG_TS_SD_NA,MPEG_TS_SD_KO">AVC_TS_MP_HD_AC3_T</MediaFormatProfile>
         <MediaFormatProfile mime-type="video/vnd.dlna.mpeg-tts" name="MPEG_TS_SD_EU,MPEG_TS_SD_NA,MPEG_TS_SD_KO">AVC_TS_MP_HD_AC3_ISO</MediaFormatProfile>
         <MediaFormatProfile mime-type="video/vnd.dlna.mpeg-tts" name="MPEG_TS_SD_EU,MPEG_TS_SD_NA,MPEG_TS_SD_KO">AVC_TS_HD_DTS_T</MediaFormatProfile>
         <MediaFormatProfile mime-type="video/vnd.dlna.mpeg-tts" name="MPEG_TS_SD_EU,MPEG_TS_SD_NA,MPEG_TS_SD_KO">AVC_TS_HD_DTS_ISO</MediaFormatProfile>
         <MediaFormatProfile mime-type="video/vnd.dlna.mpeg-tts" name="MPEG_TS_SD_EU,MPEG_TS_SD_NA,MPEG_TS_SD_KO">AVC_TS_HD_50_LPCM_T</MediaFormatProfile>
         <MediaFormatProfile mime-type="video/vnd.dlna.mpeg-tts" name="MPEG_TS_SD_EU,MPEG_TS_SD_NA,MPEG_TS_SD_KO">AVC_TS_HP_SD_MPEG1_L2_ISO</MediaFormatProfile>
         <MediaFormatProfile mime-type="video/vnd.dlna.mpeg-tts" name="MPEG_TS_SD_EU,MPEG_TS_SD_NA,MPEG_TS_SD_KO">AVC_TS_HP_SD_MPEG1_L2_T</MediaFormatProfile>
         <MediaFormatProfile mime-type="video/vnd.dlna.mpeg-tts" name="MPEG_TS_SD_EU,MPEG_TS_SD_NA,MPEG_TS_SD_KO">AVC_TS_HP_HD_MPEG1_L2_ISO</MediaFormatProfile>
         <MediaFormatProfile mime-type="video/vnd.dlna.mpeg-tts" name="MPEG_TS_SD_EU,MPEG_TS_SD_NA,MPEG_TS_SD_KO">AVC_TS_HP_HD_MPEG1_L2_T</MediaFormatProfile>
         <MediaFormatProfile mime-type="video/vnd.dlna.mpeg-tts" name="MPEG_TS_SD_EU,MPEG_TS_SD_NA,MPEG_TS_SD_KO">MPEG4_P2_TS_ASP_AAC</MediaFormatProfile>
         <MediaFormatProfile mime-type="video/vnd.dlna.mpeg-tts" name="MPEG_TS_SD_EU,MPEG_TS_SD_NA,MPEG_TS_SD_KO">MPEG4_P2_TS_ASP_AAC_T</MediaFormatProfile>
         <MediaFormatProfile mime-type="video/vnd.dlna.mpeg-tts" name="MPEG_TS_SD_EU,MPEG_TS_SD_NA,MPEG_TS_SD_KO">MPEG4_P2_TS_ASP_AAC_ISO</MediaFormatProfile>
         <MediaFormatProfile mime-type="video/vnd.dlna.mpeg-tts" name="MPEG_TS_SD_EU,MPEG_TS_SD_NA,MPEG_TS_SD_KO">MPEG4_P2_TS_ASP_AC3</MediaFormatProfile>
         <MediaFormatProfile mime-type="video/vnd.dlna.mpeg-tts" name="MPEG_TS_SD_EU,MPEG_TS_SD_NA,MPEG_TS_SD_KO">MPEG4_P2_TS_ASP_AC3_T</MediaFormatProfile>
         <MediaFormatProfile mime-type="video/vnd.dlna.mpeg-tts" name="MPEG_TS_SD_EU,MPEG_TS_SD_NA,MPEG_TS_SD_KO">MPEG4_P2_TS_ASP_AC3_ISO</MediaFormatProfile>
         <MediaFormatProfile mime-type="video/vnd.dlna.mpeg-tts" name="MPEG_TS_SD_EU,MPEG_TS_SD_NA,MPEG_TS_SD_KO">MPEG4_P2_TS_ASP_MPEG1_L3</MediaFormatProfile>
         <MediaFormatProfile mime-type="video/vnd.dlna.mpeg-tts" name="MPEG_TS_SD_EU,MPEG_TS_SD_NA,MPEG_TS_SD_KO">MPEG4_P2_TS_ASP_MPEG1_L3_T</MediaFormatProfile>
         <MediaFormatProfile mime-type="video/vnd.dlna.mpeg-tts" name="MPEG_TS_SD_EU,MPEG_TS_SD_NA,MPEG_TS_SD_KO">MPEG4_P2_TS_ASP_MPEG1_L3_ISO</MediaFormatProfile>
         <MediaFormatProfile mime-type="video/vnd.dlna.mpeg-tts" name="MPEG_TS_SD_EU,MPEG_TS_SD_NA,MPEG_TS_SD_KO">VC1_TS_AP_L1_AC3_ISO</MediaFormatProfile>
         <MediaFormatProfile mime-type="video/vnd.dlna.mpeg-tts" name="MPEG_TS_SD_EU,MPEG_TS_SD_NA,MPEG_TS_SD_KO">VC1_TS_AP_L2_AC3_ISO</MediaFormatProfile>
         <!-- Sony BDP requests all formats except mpeg-ps and mpeg-ts in 32KB chunks which works badly over wifi, hence mkv files
        are remuxed to mpeg-ts by default in this profile.
            Natively played mkv files stutter irretrievably after seeks, which seems to be a DLNA firmware issue with the player.
        If you have a European or Canadian player (not US), you stream over a wired connection and want mkv subtitles, dts
        support, and multiple audio tracks - but don't care that you can't seek - remove all matroska transcoding matches
        below to have the player decode mkv natively.
            <!-- FFmpeg cannot currently remux dts audio properly so it must be transcoded, but all other audio is left alone -->
        <Matches container="mp4" />
        <Matches container="flac" />
        <Matches container="ogg" />
      </Audio>
CaptainRewind
Post Tue Mar 08, 2011 8:07 pm
zip wrote:The file is not added to the library because your FFmpeg is too new. 0.5.1 will fix this issue.
Awesome find! I will downgrade and test. Should I use any specific versions of x264, libfaac, liblame, etc, when I recompile ffmpeg?
EDIT: It seems libx264 doesn't play nice with ffmpeg v0.5.1. I'm going to compile without it for testing.
Thanks!
