Serviio not finding any devices since Windows 10 upgrade
hanginghelmet
Post Sat Dec 19, 2015 5:38 am
Hello everyone, I am very frustrated and hope i can get some help here. I recently upgraded my computer to Windows 10. Since the upgrade Serviio is no longer finding any of my devices such as my Tv's and Blu Ray players. Nothing is showing up in the Profiles box. Everything was working great under Windows 8. I have uninstalled Serviio and reinstalled but still nothing. I am running Kaspersky Internet Security for my virus protection. Any help would be greatly appreciated!!!
Post Sat Dec 19, 2015 8:17 am
Re: Serviio not finding any devices since Windows 10 upgrade
Check that Serviio is allowed in the Kaspersky Internet Security firewall. You may have to allow access to it manually - see http://www.serviio.org/component/conten ... e?id=21#q1. Allow access to the ports and to the application.
hanginghelmet
Post Sat Dec 19, 2015 6:07 pm
Ok I was able to select my Network card in the Bound IP Address box and the TV now shows up but Serviio still is not showing on my TV so there is some progress lol. How do I "make sure that TCP port 8895 and UDP 1900 are open in your firewall". I don't see where to find those in the firewall settings. Thanks for your help so far!!!!
Post Sun Dec 20, 2015 1:00 am
I dont use Kapersky so others may assist, but also look at:
http://support.kaspersky.com/us/12092#block1 - for applications
http://support.kaspersky.com/us/11589 - for ports
