Samsung J series H264 troubles
VenoushCZ
Post Tue Dec 22, 2015 7:24 am
Hi! I have the new Samsung UE48JU6472 TV. When I try to play most H264 files it does not work and ends up with unsupported codec message. H265 plays without transcoding. What could be the problem that the TV does not play H264 directly or even with Serviio onthefly transcoding?
Thank you for help
Vaclav
josch.hh
Post Tue Dec 22, 2015 8:50 am
Re: Samsung J series H264 troubles
I own a UE32J6200 and all H264 videos in mkv container with DTS or AC3 run perfectly.
BTW i dont transcode anything.
Post Fri Dec 25, 2015 10:44 pm
VenoushCZ wrote:Hi! I have the new Samsung UE48JU6472 TV. When I try to play most H264 files it does not work and ends up with unsupported codec message. H265 plays without transcoding. What could be the problem that the TV does not play H264 directly or even with Serviio onthefly transcoding?
Thank you for help
Vaclav
No suggestions can be offered without media information. Simply saying it uses h264 isn't enough. There can be a variety of things that can differ. Either provide the media info using FFMPEG command line or from a program that can read the information (such as MediaInfo).
Also, what device profile are you using?
