Suggest future DLNA features for Sony devices
Post Tue Feb 24, 2015 6:34 pm
Re: Suggest future DLNA features for Sony devices
gpsis wrote:Hello Zip,
Has there been any progress on showing video file thumbnails in the SMP-N100/200 streamers?
If there is a Plug-In that will allow for thumbnails to be seen that would also work for me.
Thanks!
This is a Sony firmware limitation, nothing that serviio can do.
gpsis
Post Tue Feb 24, 2015 6:54 pm
OK thanks!
Regards!
Device: Sony Media Player SMP-N100
Win7 Dual Core 2.9GHz
3GBR
Malwarebytes Anti-Spyware
BitDefender Total Security
Serviio allowed in all security software
ddasd
Post Sun Sep 27, 2015 6:18 pm
anything new?
medway33
Post Tue Dec 29, 2015 1:07 pm
to run videos consecutively automatically would be ideal then I can get rid of apple tv :D
millahjovich
Post Mon Jun 13, 2016 10:20 am
I don't know if this is relevant in this topic but functionnal fast forward end rewind functions would be nice.
Also It would be more efficient to navigate into subfolders; for now, I'm forced to share (in the console) every single folder I want to appear in the list
I am Devil Find me in your Heart
marianituns
Post Fri Nov 11, 2016 5:13 am
Para poder ver los subtítulos en formato .srt en mi Sony KDL-50W805B por DNLA en la configuración de subtítulos de Serviio en lugar de "UTF-8" o "ANSI" yo lo solucione poniendo "windows-1252" sin las comillas, espero que les sirva, saludos!
Henderson
Post Tue Jan 31, 2017 10:05 pm
I know this was brought up several years ago and it sounded like it was in the works then, (I sure can't find a way to do it though), but a way to filter certain file types to exclude them from the library would really be a great feature. I've run into the problem with raw photos that was brought up in this thread on a newer Sony player, so every time it comes to a raw image, it takes the time in the slideshow to display the broken image icon. For editing purposes, keeping the raw image with the other jpgs is a must, plus it's great to see the before and after edited photos. Oddly this is a new stumbling block for me with the newest player because my 2 older Sony players in the same line do display raw images perfectly (even though they're also not listed as supporting .arw images).
sonicm
Post Thu Jun 01, 2017 4:52 pm
I dont see a better place to put this but would like a profile or profile recommendation for my sony Bravia KD-55X8505B, I'm currently using the Sony Bravia 2009 profile which seems ok but still (for example) having trouble with files made from DIVX Pro in HD (MKV), for example this works:
Format : Matroska
Format_Version : Version 1
FileSize/String : 1.33 GiB
Duration/String : 43 min 58 s
OverallBitRate/String : 4 329 kb/s
Encoded_Application/String : DivXMKVMux 9.11.15.2214
Encoded_Library/String : libDivXMediaFormat 4.0.0.0578
ID/String : 1
Format : HEVC
Format/Info : High Efficiency Video Coding
CodecID : V_MPEGH/ISO/HEVC
Width/String : 1 920 pixels
Height/String : 1 080 pixels
DisplayAspectRatio/String : 16:9
FrameRate_Mode/String : Constant
FrameRate/String : 25.000 FPS
Language/String : English
Default/String : Yes
Forced/String : No
ID/String : 2
Format : AAC
Format_Profile : LC
CodecID : A_AAC
Channel(s)/String : 2 channels
ChannelPositions : Front: L R
SamplingRate/String : 48.0 kHz
FrameRate/String : 46.875 FPS (1024 spf)
Compression_Mode/String : Lossy
Forced/String : No
And this does not:
Format : Matroska
Format version : Version 1
File size : 1.93 GiB
Duration : 43 min 57 s
Overall bit rate : 6 269 kb/s
Writing application : DivXMKVMux 10.3.16.2026
Writing library : libDivXMediaFormat 4.0.0.0578
Format : AVC
Format profile : High@L4
Format settings, CABAC : Yes
Format settings, ReFrames : 2 frames
Codec ID : V_MPEG4/ISO/AVC
Bit rate mode : Variable
Maximum bit rate : 6 629 kb/s
Width : 1 920 pixels
Height : 1 080 pixels
Display aspect ratio : 16:9
Frame rate mode : Constant
Frame rate : 29.970 (30000/1001) FPS
Standard : NTSC
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Progressive
Language : English
Default : Yes
Forced : No
Color range : Full
Color primaries : BT.709
Matrix coefficients : BT.709
Format : AAC
Format profile : LC
Codec ID : A_AAC
Channel(s) : 6 channels
Sampling rate : 48.0 kHz
Frame rate : 46.875 FPS (1024 spf)
Compression mode : Lossy
Language : English
Default : Yes
Forced : No
I know that the 5.1 DS is fine as it's working on films, just seems a bit random although the working was done on an older version DIVX Pro?
Any help would be appreciated, or best settings for the TV DNLA using DIVX PRO and SERVIIO?
Many thanks in advance
Mike
lagunaa
Post Thu Nov 09, 2017 9:39 am
The media player on my Sony Bravia TV KDL-42W705B has menu option for ordering items but then it says Serviio server doesn't support this feature.
@zip Any chance to implement this feature? Maybe @SonyHomestream can help on this...
Thanks in advance.
Cheers.
Previous
Users browsing this forum: Baidu [Spider], Bing [Bot] and 9 guests
