File Size
timehri747
Post Tue Mar 08, 2011 11:10 pm
File Size
I am a new user of Serviio .5. This is a great program and it runs very good. I have it set up on a pc and is currently streaming videos to two different sources , a Samsung BD-C5500 bluray player and a Samsung UN46C6300.
The only Problem is that serviio does not stream .avi files which are like 5GB or more. All the other files streams ok.
Now i split the same 5gb file into 3 smaller files of 1.6gb and it streams fine.
I am just wondering if there is a limit to the file size as this file is one of many that i have and maybe I will try to limit the file size
Thanks in advance
Post Tue Mar 08, 2011 11:20 pm
Re: File Size
there is no limitation from Serviio's side.
timehri747
Post Tue Mar 08, 2011 11:39 pm
Re: File Size
So, I am wondering why it dosen't play those large files? Now i am also wondering if it is the pc i am using.
It's a 2ghz , 2gb ram and a 1 tb HDD. This pc has nothing else on it.
Please advise on what should I do.
Return to User experiences
Users browsing this forum: Baidu [Spider], Google [Bot] and 3 guests
