DB size growing
josch.hh
Post Mon Dec 21, 2015 12:55 am
DB size growing
It seems that the database is not well cleaned after removing a complete folder from the library.
The DB was about 597MB size including the folder i am talking about.
After removing it the DB got somerthing about 590MB.
After adding it again the size is now 625MB an growing....
Seems not ok for me.
Is there an option to clean up the DB files?
Post Wed Dec 23, 2015 3:00 am
Re: DB size growing
I believe the only way is to delete it and let it rebuild.
Post Wed Dec 23, 2015 1:28 pm
Re: DB size growing
Serviio uses Apache Derby DB. I don't know the inner workings but it's possible it doesn't shrink the data blobs in order to keep consistency and performance.
skiaccianos
Post Wed Dec 23, 2015 6:57 pm
Re: DB size growing
Btw, zip: I've tested the very latest derby.jar with serviio. It works fine and has same weight.
Inviato dal mio Moto G utilizzando Tapatalk
Running Serviio - for several years now - on Debian and Win boxes.
R850R biker, sysadmin & DBA, FOSS and Linux enthusiast (desktop_is_home_dir)
josch.hh
Post Wed Dec 23, 2015 8:08 pm
Re: DB size growing
skiaccianos wrote:Btw, zip: I've tested the very latest derby.jar with serviio. It works fine and has same weight.
And is the behaviour concerning the database cleanup for remove folders from serviio better,.... or what is the improvement?
josch.hh
Post Wed Dec 23, 2015 8:15 pm
Re: DB size growing
zip wrote:Serviio uses Apache Derby DB. I don't know the inner workings but it's possible it doesn't shrink the data blobs in order to keep consistency and performance.
Mmh, so what is the consequence? If one is regularly updating or modifying his media files a recreation of the derby db is needed to avoid that the database gets bigger than the source media files it points to?
Post Thu Dec 24, 2015 1:02 am
Re: DB size growing
Bearing in mind I know nothing about derby:
This post http://apache-database.10148.n7.nabble. ... 04961.html (assuming that the response in that forum is accurate) begs the question - does Serviio periodically compress the database programatically? Is it practical to do so (time taken to compress, etc)? If not, perhaps by a third party tool?
josch.hh
Post Thu Dec 24, 2015 8:49 am
Re: DB size growing
Hi again, dont get me wrong, i really like Serviio, but as the DB is a major part i guess you should be sure about its behaviour in combination with the functionallity of your software.
Dont you think it is worth to take a deeper look from your side... i think the source cocde of serviio is not published so you are the only one to check to collaboration.
What i found was the following:
https://db.apache.org/derby/docs/10.1/adminguide/cadminspace21579.html
http://www-01.ibm.com/support/docview.wss?uid=swg21577292
The last link even with some java exmaples.
skiaccianos
Post Thu Dec 24, 2015 1:01 pm
Re: DB size growing
"... Derby 10.12.1.1 contains many bug, security, and documentation fixes."
If there's a problem, the first thing to do is to get the latest release. :) About me, I've never had a so huge an half gb db size: my .serviio/library folder has always been around 10 mb or less.
josch.hh
Post Mon Dec 28, 2015 8:44 am
Re: DB size growing
Concerning my DB size: It contains about 500 Movies and maybe 8000 mp3 and about 2000 pictures
... i dont think is this really much
Minidlna consumed only 20% of the db files size and art cache compared with serviio.
Post Fri Jan 01, 2016 2:58 pm
Re: DB size growing
minidlna also doesn't store all the descriptive metadata, like summary, actors, 2 sizes of thumbnails, etc.
josch.hh
Post Fri Jan 01, 2016 3:43 pm
Re: DB size growing
ok, but i dont think that this results in an x times bigger DB
Post Fri Jan 01, 2016 8:29 pm
Re: DB size growing
It could. And obviously they both use different DB engines, so you cannot really compare them anyway.
Post Sat Jan 02, 2016 1:54 am
Re: DB size growing
What did we conclude here about cleaning old stuff out of the db?
My concern is my on-line streams for which the stream urls change regularly, as opposed to files which are static.
Am I correct that "the only way is to delete it and let it rebuild."??
Post Sat Jan 02, 2016 7:21 pm
Re: DB size growing
Online streams are not stored into the DB (Derby), but use a caching mechanism (Apache JCS). No idea how the space in the persistent cache is reclaimed... but i guess you already have better way to test it than me (I hardly use any online sources personally).
Post Sat Jan 02, 2016 8:19 pm
Re: DB size growing
zip wrote:Online streams are not stored into the DB (Derby), but use a caching mechanism (Apache JCS). No idea how the space in the persistent cache is reclaimed... but i guess you already have better way to test it than me (I hardly use any online sources personally).
So online metadata is stored in C:\Program Files\Serviio\library\cache\online_technical_metadata.data (Mine is only 5MB) and the thumbs in and the thumbnails in C:\Program Files\Serviio\library\cache\thumbnails.data (Mine is 99MB). Files metadata is in C:\Program Files\Serviio\library\db (Mine is 282MB)
josch.hh
Post Sat Jan 02, 2016 8:43 pm
Re: DB size growing
How many files of which kind are in your db?
Post Sat Jan 02, 2016 9:20 pm
Re: DB size growing
Is there an easy way to get this number?
Post Sat Jan 02, 2016 9:28 pm
Re: DB size growing
jhb50 wrote:Is there an easy way to get this number?
You can see the numbers (images / audio / videos) in the new 1.6 console homepage.
josch.hh
Post Sat Jan 02, 2016 11:13 pm
Re: DB size growing
nice, so when can we expect this new version ? ;-)
Users browsing this forum: Baidu [Spider], Google [Bot] and 18 guests
