Unespextec error occurs when uploading license file
daniele.lagreca76
Post Sat Jan 02, 2016 8:59 am
I'm uploading license file just bought, but appears a dialog box with the message An unexpected error occurred (500). Check the log.
I'm trying to use Serviio on Ubuntu 15.10
pepa.sajdler
Post Sat Jan 02, 2016 1:09 pm
Re: Unespextec error occurs when uploading license file
Did you check the log? Any clue there?
Odesláno z mého A0001 pomocí Tapatalk
Post Sat Jan 02, 2016 9:57 pm
and are you using the desktop Linux console or some web ui?
daniele.lagreca76
Post Sun Jan 03, 2016 10:10 pm
Hi, I don't know where to check... and I'm using Serviio console 1.5.2 for linux
daniele.lagreca76
Post Sun Jan 03, 2016 10:14 pm
another issue i noticed... now the console send the same error message always I need to save a change... and the library isn't updated anymore
Post Mon Jan 04, 2016 12:36 pm
Log is here: http://wiki.serviio.org/doku.php?id=detail_logging
It looks like your installation is perhaps corrupted, we can see from the log.
pepa.sajdler
Post Mon Jan 04, 2016 6:07 pm
My guess: it's a permission problem - try to check if the user (serviio is running under) has the permission to write into serviio folder. If you installed following this http://wiki.serviio.org/doku.php?id=how ... buntu15-04, then try chown -R serviio:serviio /your/serviio/dir - I think the wiki is wrong here, because the service runs under serviio user, but the directory is owned (except for serviio/lib & loh) by root... I think, licence file and settings are saved somewhere else.
Users browsing this forum: No registered users and 60 guests
