Servio installation on debian - debian.i-matrixx.de down?
darmach
Post Sat Aug 09, 2014 6:33 pm
Hi
Im attempting to install serviio on Debian headless box, running Jessie.
Im following guide located at: http://wiki.serviio.org/doku.php?id=howto:linux:install:debian but is seem that
http://debian.i-matrixx.de is not being resolved at all. I get such error:
Is that domain alive?
xybirium
Post Thu Aug 14, 2014 2:55 pm
Re: Servio installation on debian - debian.i-matrixx.de down
I would also like to know too.
emzem2008
Post Wed Sep 10, 2014 9:31 pm
Me three... Been using Serviio for 2 years. Paid for a license. Tried installing and same error. Stuck using Plex. :x :( :cry: :x :x :x :x
emzem2008
Post Sat Sep 20, 2014 4:45 pm
Hello ?! Is anyone working on this problem ? Have any information ? I would like to use what I paid for.... :evil: :evil: :evil: :evil:
emzem2008
Post Sat Sep 20, 2014 8:57 pm
Hey darmach, I just installed it from source on debian. Problem solved. :D 8-)
Bruno
Post Fri May 22, 2015 1:26 pm
for debian jessie and above:
wget -O - https://apt.z-index.net/apt.z-index.net.gpg.key | sudo apt-key add -
wget https://apt.z-index.net/debian/pc5dczc_1.5.2-1_all.deb
dpkg -i pc5dczc_1.5.2-1_all.deb
but its require java8, i recommend this guide for jessie
http://linuxg.net/how-to-install-the-or ... epository/
Bruno
Post Thu Jan 21, 2016 11:27 am
yann49
Post Thu Jan 28, 2016 9:01 am
I am new to Linux/Debian and to Serviio.
Trying to install Serviio I went to this wiki page : http://wiki.serviio.org/doku.php?id=how ... all:debian
where it is written to create the following two lines in the etc/apt/sources.list.d/debian.i-matrixx.list file.
deb-src http://debian.i-matrixx.de serviio main
wget -O - http://debian.i-matrixx.de/52CE883E.asc | sudo apt-key add -
This is what I did (copy / paste) but it did not work. I got the following error message (it was in French so it is a translation not sure the real one is the same in English) :
Type "wget" is unknown on line 2 in the liste of sources at .....
Sources list cannot be read.
Can somebody confirm that this line of command using wget is correct ?
If not could you please tell me how to fix it ?
Is the http://debian.i-matrixx.de the one to use or should I go for https://apt.z-index.net/debian/ ?
Thank you for your help
Bruno
Post Thu Jan 28, 2016 2:02 pm
http://debian.i-matrixx.de does not exists anymore since serviio 1.4, thats the reason why i build the new packages.
install serviio with this commands in your terminal
wget https://apt.z-index.net/debian/pc5dczc_1.6.0-1_all.deb
dpkg -i pc5dczc_1.6.0-1_all.deb
Post Thu Jan 28, 2016 2:19 pm
Any chance you could update the wiki article too to keep it up-to-date?
yann49
Post Fri Jan 29, 2016 10:12 am
Bruno wrote:http://debian.i-matrixx.de does not exists anymore since serviio 1.4, thats the reason why i build the new packages.
Hi Bruno,
Thank you ... it is working fine now.
Great support
stefankrieger
Post Sat Mar 12, 2016 5:07 am
I'm trying to install Serviio on Debian Weezy 7.9, but
results in
root@debian:/home/stefan# wget -O - https://apt.z-index.net/apt.z-index.net.gpg.key | sudo apt-key add -
--2016-03-11 23:43:25-- https://apt.z-index.net/apt.z-index.net.gpg.key
Resolving apt.z-index.net (apt.z-index.net)... 37.120.174.49, 2a03:4000:6:7079::1
Connecting to apt.z-index.net (apt.z-index.net)|37.120.174.49|:443... connected.
ERROR: The certificate of `apt.z-index.net' is not trusted.
ERROR: The certificate of `apt.z-index.net' hasn't got a known issuer.
gpg: no valid OpenPGP data found.
What do I do?
Bruno
Post Mon Mar 14, 2016 9:59 am
its look like the root cert on your debian is missing for startssl.com.
you can download the .deb file manually from here
and install it with "dpkg -i *.deb"
woodrook
Post Wed Apr 19, 2017 12:17 pm
I'm trying to install serviio 1.8 on debian jessie but i'm having a lot of trouble with java and serviio as well
Unfortunately the wiki si very old and i'm unable to find a guide over the web
I'll probably switch my os to ubuntu server
Bruno
Post Wed Apr 19, 2017 12:46 pm
i switched last year to plex (pass) and does not use serviio anymore, sorry.
Users browsing this forum: Baidu [Spider], Google [Bot] and 35 guests
