Skipping processing metadata for an unsupported file
uzzi
Post Thu Jan 21, 2016 10:24 pm
I have serviio 1.6 on Centos 6 and not all files are indexed. The log is full of this warning
2016-01-21 20:04:02,844 WARN [MetadataExtractionCoordinator] Skipping processing metadata for an unsupported file (/home/3TB/filme/Seriale/Bones/Bones.S09.DVDRip.x264-Mixed/bones.915.dvdrip.x264-ositv.mkv). Message: Unknown video file type.
2016-01-21 20:04:02,781 WARN [MetadataExtractionCoordinator] Skipping processing metadata for an unsupported file (/home/3TB/filme/Seriale/Bones/Bones.S09.DVDRip.x264-Mixed/snow-bones.s09e10.dvdrip.x264.mkv). Message: Unknown video file type.
2016-01-21 20:04:02,712 WARN [MetadataExtractionCoordinator] Skipping processing metadata for an unsupported file (/home/3TB/filme/Seriale/Bones/Bones.S09.DVDRip.x264-Mixed/bones.s09e21.dvdrip.x264-demand.mkv). Message: Unknown video file type.
ffmpeg version:
FFmpeg version SVN-r26402, Copyright (c) 2000-2011 the FFmpeg developers
  built on Jan 20 2016 22:56:25 with gcc 4.4.7 20120313 (Red Hat 4.4.7-16)
  configuration:
  libavutil     50.36. 0 / 50.36. 0
  libavcore      0.16. 1 /  0.16. 1
  libavcodec    52.108. 0 / 52.108. 0
  libavformat   52.93. 0 / 52.93. 0
  libavdevice   52. 2. 3 / 52. 2. 3
  libavfilter    1.74. 0 /  1.74. 0
  libswscale     0.12. 0 /  0.12. 0
ffmpeg -i
ffmpeg -i /home/3TB/filme/Seriale/Bones/Bones.S09.DVDRip.x264-Mixed/bones.915.dvdrip.x264-ositv.mkv
  configuration:
[matroska,webm @ 0x1eb3510] Estimating duration from bitrate, this may be inaccurate
Seems stream 0 codec frame rate differs from container frame rate: 47.95 (48000/1001) -> 24.00 (24/1)
Input #0, matroska,webm, from '/home/3TB/filme/Seriale/Bones/Bones.S09.DVDRip.x264-Mixed/bones.915.dvdrip.x264-ositv.mkv':
  Duration: 00:43:26.10, start: 0.000000, bitrate: N/A
    Stream #0.0: Video: h264, yuv420p, 720x404 [PAR 1:1 DAR 180:101], 23.98 fps, 24 tbr, 1k tbn, 47.95 tbc
      BPS             : 810554
      BPS-eng         : 810554
      DURATION        : 00:43:26.104000000
      DURATION-eng    : 00:43:26.104000000
      NUMBER_OF_FRAMES: 62484
      NUMBER_OF_FRAMES-eng: 62484
      NUMBER_OF_BYTES : 264048608
      NUMBER_OF_BYTES-eng: 264048608
      _STATISTICS_WRITING_APP: mkvmerge v7.2.0 ('On Every Street') 32bit built on Sep 13 2014 15:42:11
      _STATISTICS_WRITING_APP-eng: mkvmerge v7.2.0 ('On Every Street') 32bit built on Sep 13 2014 15:42:11
      _STATISTICS_WRITING_DATE_UTC: 2014-09-24 19:47:19
      _STATISTICS_WRITING_DATE_UTC-eng: 2014-09-24 19:47:19
      _STATISTICS_TAGS: BPS DURATION NUMBER_OF_FRAMES NUMBER_OF_BYTES
      _STATISTICS_TAGS-eng: BPS DURATION NUMBER_OF_FRAMES NUMBER_OF_BYTES
    Stream #0.1: Audio: aac, 48000 Hz, stereo, s16
      BPS             : 112749
      BPS-eng         : 112749
      DURATION        : 00:43:26.037000000
      DURATION-eng    : 00:43:26.037000000
      NUMBER_OF_FRAMES: 122158
      NUMBER_OF_FRAMES-eng: 122158
      NUMBER_OF_BYTES : 36728777
      NUMBER_OF_BYTES-eng: 36728777
Any idea? As far as i see this happens only on some mkv's
Post Thu Jan 21, 2016 11:53 pm
Re: Skipping processing metadata for an unsupported file
are you sure Serviio can see your ffmpeg?
uzzi
Post Fri Jan 22, 2016 3:50 pm
How can i check if serviio can see my ffmpeg? And this happens only for some of my files from the library, not all. Its a 2TB library, on only 10-15 movies are affected
Thank you
Post Sat Jan 23, 2016 11:21 am
The example that you gave (ffmpeg -i) is not for one of the failed file, if I'm looking right.
Can you do the same for
ffmpeg -i /home/3TB/filme/Seriale/Bones/Bones.S09.DVDRip.x264-Mixed/snow-bones.s09e10.dvdrip.x264.mkv
uzzi
Post Sat Jan 23, 2016 11:54 am
here it is
  configuration:
[matroska,webm @ 0x1ab9510] Unknown entry 0xF0
    Last message repeated 917 times
[matroska,webm @ 0x1ab9510] Estimating duration from bitrate, this may be inaccurate
Input #0, matroska,webm, from '/home/3TB/filme/Seriale/Bones/Bones.S09.DVDRip.x264-Mixed/snow-bones.s09e10.dvdrip.x264.mkv':
  Duration: 00:43:57.88, start: 0.000000, bitrate: N/A
    Chapter #0.0: start 0.000000, end 336.534000
      title           : Chapter 01
    Chapter #0.1: start 336.534000, end 468.834000
      title           : Chapter 02
    Chapter #0.2: start 468.834000, end 611.834000
      title           : Chapter 03
    Chapter #0.3: start 611.834000, end 858.168000
      title           : Chapter 04
    Chapter #0.4: start 858.168000, end 1040.036000
      title           : Chapter 05
    Chapter #0.5: start 1040.036000, end 1213.036000
      title           : Chapter 06
    Chapter #0.6: start 1213.036000, end 1379.503000
      title           : Chapter 07
    Chapter #0.7: start 1379.503000, end 1616.670000
      title           : Chapter 08
    Chapter #0.8: start 1616.670000, end 1797.004000
      title           : Chapter 09
    Chapter #0.9: start 1797.004000, end 2211.838000
      title           : Chapter 10
    Chapter #0.10: start 2211.838000, end 2385.505000
      title           : Chapter 11
    Chapter #0.11: start 2385.505000, end 2635.206000
      title           : Chapter 12
    Chapter #0.12: start 2635.206000, end 2637.886000
      title           : Chapter 13
    Stream #0.0(eng): Video: h264, yuv420p, 720x406, PAR 1:1 DAR 360:203, 23.98 fps, 24 tbr, 1k tbn, 47.95 tbc
      BPS             : 994249
      BPS-eng         : 994249
      DURATION        : 00:43:57.886000000
      DURATION-eng    : 00:43:57.886000000
      NUMBER_OF_FRAMES: 63246
      NUMBER_OF_FRAMES-eng: 63246
      NUMBER_OF_BYTES : 327839557
      NUMBER_OF_BYTES-eng: 327839557
      _STATISTICS_WRITING_APP: mkvmerge v7.1.0 ('Good Love') 64bit built on Jul 27 2014 13:06:55
      _STATISTICS_WRITING_APP-eng: mkvmerge v7.1.0 ('Good Love') 64bit built on Jul 27 2014 13:06:55
      _STATISTICS_WRITING_DATE_UTC: 2014-08-28 02:38:08
      _STATISTICS_WRITING_DATE_UTC-eng: 2014-08-28 02:38:08
    Stream #0.1(eng): Audio: aac, 48000 Hz, stereo, s16
      BPS             : 128019
      BPS-eng         : 128019
      DURATION        : 00:43:57.738000000
      DURATION-eng    : 00:43:57.738000000
      NUMBER_OF_FRAMES: 123644
      NUMBER_OF_FRAMES-eng: 123644
      NUMBER_OF_BYTES : 42210174
      NUMBER_OF_BYTES-eng: 42210174
Post Sat Jan 23, 2016 1:00 pm
Ok, that works in my test.
Just noticed your FFmpeg is very old
You could try to upgrade it / build your own from latest sources.
uzzi
Post Sat Jan 23, 2016 2:17 pm
Ok, updated ffmpeg to the latest version: 2.8.5 from source. It was installed from SVN as can be seen in my initial post
Same errors, same files persists in not indexing :(((
ffmpeg
ffmpeg version 2.8.5 Copyright (c) 2000-2016 the FFmpeg developers
  built with gcc 4.4.7 (GCC) 20120313 (Red Hat 4.4.7-16)
  configuration:
  libavutil      54. 31.100 / 54. 31.100
  libavcodec     56. 60.100 / 56. 60.100
  libavformat    56. 40.101 / 56. 40.101
  libavdevice    56.  4.100 / 56.  4.100
  libavfilter     5. 40.101 /  5. 40.101
  libswscale      3.  1.101 /  3.  1.101
  libswresample   1.  2.101 /  1.  2.101
Any other ideas? Im banging my head against the wall here :)
Post Sat Jan 23, 2016 4:05 pm
if you enable detailed log, restart serviio and chenck the log. It should give some information about the ffmpeg executable it's using. Is it the one you're expecting?
uzzi
Post Sun Jan 24, 2016 5:19 pm
I enabled detailed log, restarted serviio but the error message is the same
2016-01-24 19:12:33,574 DEBUG [ApplicationInstanceManager] Successfully notified first instance.
2016-01-24 19:13:48,096 WARN  [MetadataExtractionCoordinator] Skipping processing metadata for an unsupported file (/home/3TB/filme/Full HD/Actiune/Chappie.2015.720p.RoSubbed.WEB-DL.AAC2.0.H.264-XSY.mkv). Message: Unknown video file type.
Thank you
Post Sun Jan 24, 2016 7:26 pm
I wnated you to check the ffmpeg info it prints out at the beggining after startup. Check it's the ffmpeg you compiled.
uzzi
Post Mon Jan 25, 2016 7:05 pm
A more detailed log is below. I can't tell if ffmpeg is the one that i compiled
2016-01-25 21:02:52,984 WARN [MetadataExtractionCoordinator] Skipping processing metadata for an unsupported file (/home/3TB/filme/Seriale/Bones/Bones.S09_test/bones.s09e19.dvdrip.x264.mkv). Message: Unknown video file type.
2016-01-25 21:02:52,897 DEBUG [ProcessExecutor] Starting ffmpeg -i /home/3TB/filme/Seriale/Bones/Bones.S09_test/bones.s09e19.dvdrip.x264.mkv
2016-01-25 21:02:52,896 DEBUG [FFMPEGWrapper] Invoking FFMPEG to retrieve media information for file: /home/3TB/filme/Seriale/Bones/Bones.S09_test/bones.s09e19.dvdrip.x264.mkv
2016-01-25 21:02:52,896 DEBUG [VideoExtractionStrategy] Extracting metadata of video file: /home/3TB/filme/Seriale/Bones/Bones.S09_test/bones.s09e19.dvdrip.x264.mkv
2016-01-25 21:02:52,896 DEBUG [LibraryHelper] File is complete with size 306077098
2016-01-25 21:02:52,145 DEBUG [LibraryHelper] Checking if the file is complete using file size
2016-01-25 21:02:52,145 DEBUG [LibraryHelper] Checking if the file is complete using file lock
2016-01-25 21:02:52,145 DEBUG [MediaFileIndexer] File not in Library, will add it
2016-01-25 21:02:52,145 DEBUG [MediaItemDAOImpl] Media item /home/3TB/filme/Seriale/Bones/Bones.S09_test/bones.s09e19.dvdrip.x264.mkv doesn't exist in DB yet
2016-01-25 21:02:52,144 DEBUG [MediaItemDAOImpl] Looking up a media item for file path: /home/3TB/filme/Seriale/Bones/Bones.S09_test/bones.s09e19.dvdrip.x264.mkv, ignore case: false
2016-01-25 21:02:52,144 DEBUG [MediaItemDAOImpl] Checking if DB already contains media item /home/3TB/filme/Seriale/Bones/Bones.S09_test/bones.s09e19.dvdrip.x264.mkv
2016-01-25 21:02:52,144 DEBUG [MediaFileIndexer] Found file 'bones.s09e19.dvdrip.x264.mkv', checking if it's already in the Library
2016-01-25 21:02:52,144 DEBUG [PendingFilesCache] Adding file '/home/3TB/filme/Seriale/Bones/Bones.S09_test/bones.s09e02.dvdrip.x264.mkv' for the pending files cache
2016-01-25 21:02:52,144 WARN [MetadataExtractionCoordinator] Skipping processing metadata for an unsupported file (/home/3TB/filme/Seriale/Bones/Bones.S09_test/bones.s09e02.dvdrip.x264.mkv). Message: Unknown video file type.
2016-01-25 21:02:52,060 DEBUG [ProcessExecutor] Starting ffmpeg -i /home/3TB/filme/Seriale/Bones/Bones.S09_test/bones.s09e02.dvdrip.x264.mkv
2016-01-25 21:02:52,059 DEBUG [FFMPEGWrapper] Invoking FFMPEG to retrieve media information for file: /home/3TB/filme/Seriale/Bones/Bones.S09_test/bones.s09e02.dvdrip.x264.mkv
2016-01-25 21:02:52,059 DEBUG [VideoExtractionStrategy] Extracting metadata of video file: /home/3TB/filme/Seriale/Bones/Bones.S09_test/bones.s09e02.dvdrip.x264.mkv
2016-01-25 21:02:52,059 DEBUG [LibraryHelper] File is complete with size 416583133
2016-01-25 21:02:51,308 DEBUG [LibraryHelper] Checking if the file is complete using file size
2016-01-25 21:02:51,308 DEBUG [LibraryHelper] Checking if the file is complete using file lock
2016-01-25 21:02:51,308 DEBUG [MediaFileIndexer] File not in Library, will add it
2016-01-25 21:02:51,307 DEBUG [MediaItemDAOImpl] Media item /home/3TB/filme/Seriale/Bones/Bones.S09_test/bones.s09e02.dvdrip.x264.mkv doesn't exist in DB yet
2016-01-25 21:02:51,307 DEBUG [MediaItemDAOImpl] Looking up a media item for file path: /home/3TB/filme/Seriale/Bones/Bones.S09_test/bones.s09e02.dvdrip.x264.mkv, ignore case: false
2016-01-25 21:02:51,307 DEBUG [MediaItemDAOImpl] Checking if DB already contains media item /home/3TB/filme/Seriale/Bones/Bones.S09_test/bones.s09e02.dvdrip.x264.mkv
2016-01-25 21:02:51,307 DEBUG [MediaFileIndexer] Found file 'bones.s09e02.dvdrip.x264.mkv', checking if it's already in the Library
2016-01-25 21:02:51,307 DEBUG [PendingFilesCache] Adding file '/home/3TB/filme/Seriale/Bones/Bones.S09_test/bones.s09e18.dvdrip.x264.mkv' for the pending files cache
2016-01-25 21:02:51,307 WARN [MetadataExtractionCoordinator] Skipping processing metadata for an unsupported file (/home/3TB/filme/Seriale/Bones/Bones.S09_test/bones.s09e18.dvdrip.x264.mkv). Message: Unknown video file type.
2016-01-25 21:02:51,219 DEBUG [ProcessExecutor] Starting ffmpeg -i /home/3TB/filme/Seriale/Bones/Bones.S09_test/bones.s09e18.dvdrip.x264.mkv
2016-01-25 21:02:51,218 DEBUG [FFMPEGWrapper] Invoking FFMPEG to retrieve media information for file: /home/3TB/filme/Seriale/Bones/Bones.S09_test/bones.s09e18.dvdrip.x264.mkv
2016-01-25 21:02:51,218 DEBUG [VideoExtractionStrategy] Extracting metadata of video file: /home/3TB/filme/Seriale/Bones/Bones.S09_test/bones.s09e18.dvdrip.x264.mkv
2016-01-25 21:02:51,218 DEBUG [LibraryHelper] File is complete with size 338948113
2016-01-25 21:02:50,467 DEBUG [LibraryHelper] Checking if the file is complete using file size
2016-01-25 21:02:50,467 DEBUG [LibraryHelper] Checking if the file is complete using file lock
2016-01-25 21:02:50,467 DEBUG [MediaFileIndexer] File not in Library, will add it
2016-01-25 21:02:50,467 DEBUG [MediaItemDAOImpl] Media item /home/3TB/filme/Seriale/Bones/Bones.S09_test/bones.s09e18.dvdrip.x264.mkv doesn't exist in DB yet
2016-01-25 21:02:50,466 DEBUG [MediaItemDAOImpl] Looking up a media item for file path: /home/3TB/filme/Seriale/Bones/Bones.S09_test/bones.s09e18.dvdrip.x264.mkv, ignore case: false
2016-01-25 21:02:50,466 DEBUG [MediaItemDAOImpl] Checking if DB already contains media item /home/3TB/filme/Seriale/Bones/Bones.S09_test/bones.s09e18.dvdrip.x264.mkv
2016-01-25 21:02:50,466 DEBUG [MediaFileIndexer] Found file 'bones.s09e18.dvdrip.x264.mkv', checking if it's already in the Library
2016-01-25 21:02:50,466 DEBUG [PendingFilesCache] Adding file '/home/3TB/filme/Seriale/Bones/Bones.S09_test/bones.s09e12.dvdrip.x264.mkv' for the pending files cache
2016-01-25 21:02:50,466 WARN [MetadataExtractionCoordinator] Skipping processing metadata for an unsupported file (/home/3TB/filme/Seriale/Bones/Bones.S09_test/bones.s09e12.dvdrip.x264.mkv). Message: Unknown video file type.
uzzi
Post Mon Jan 25, 2016 7:14 pm
I think i found the ffmpeg version as seen by serviio in DEBUG mod
2016-01-25 21:10:23,048 DEBUG [ProcessExecutor] Starting dcraw
2016-01-25 21:10:23,047 DEBUG [DCRawWrapper] Invoking DCRAW to check if it exists of path dcraw
2016-01-25 21:10:22,926 DEBUG [ConfigEntryDAOImpl] Updating ConfigEntry (name = subtitles_hardsubs_enabled, value = false)
2016-01-25 21:10:22,911 DEBUG [ConfigEntryDAOImpl] Reading a ConfigEntry (name = subtitles_hardsubs_enabled)
2016-01-25 21:10:22,911 WARN [FFMPEGWrapper] FFmpeg is not compiled with libass support, rendering subtitles (hardsubs) will not work.
2016-01-25 21:10:22,911 WARN [FFMPEGWrapper] FFmpeg is not compiled with librtmp support, RTMP streaming will not work.
2016-01-25 21:10:22,911 INFO [FFMPEGWrapper] Found FFmpeg: ffmpeg version 2.8.5 Copyright (c) 2000-2016 the FFmpeg developers
2016-01-25 21:10:22,834 DEBUG [ProcessExecutor] Starting ffmpeg
2016-01-25 21:10:22,816 DEBUG [FFMPEGWrapper] Invoking FFMPEG to check if it exists of path ffmpeg
2016-01-25 21:10:22,779 INFO [UpdateChecker] Checking if a new version is available
2016-01-25 21:10:22,771 INFO [PluginCompilerThread] Started looking for plugins
It looks like its 2.8.5 the one i just installed the other day
Post Mon Jan 25, 2016 7:47 pm
ok, looks good.
Just for completeness sake, can you post ffmpeg -i for the unsupported file using this ffmpeg 2.8.5 version?
uzzi
Post Tue Jan 26, 2016 5:52 pm
Last night after a power loss the server rebooted and, believe it or not, the error is gone and all unindexed MKS's by Serviio are now indexed :roll:
The one and only thing i can think of is related to java. Since last java jdk update on this server it was not rebooted in more then 100 days. I dont know if this is the case but maybe this info helps someone in the future
Thank you zip for your support ! Thumbs up for Serviio product and support forum ! 8-)
Users browsing this forum: Google [Bot] and 41 guests
