Serviio Not Running
sheriff
Post Tue Jan 26, 2016 7:00 pm
Serviio Not Running
I Upgraded to the latest version of Serviio on Mac OS X 10.11.3
Its been working fine for me until I upgraded now servo comes up "the application serviio cannot be opened"
Anyone know whats wrong or have a similar problem?
Post Tue Jan 26, 2016 8:15 pm
Re: Serviio Not Running
try this: viewtopic.php?f=5&t=21440&start=20#p106530
If it still doesn't help, try to run the installer again
sheriff
Post Thu Jan 28, 2016 2:31 am
Looked into that, not entirely sure what to do with what they posted
Post Thu Jan 28, 2016 8:45 am
Try to move the Serviio COnsole out of the Applications older. Then run it. It should work. Then you can move it back to Applications.
Krangh
Post Fri Jan 29, 2016 7:43 pm
Sorry for posting on another persons thread, but I have exactly the same issue.
Following your advice, I can now start Serviio-Console, and a window named "Electron" comes up. In it it displays the message "Cannot connect to the server, it doesn't seem to be running...".
I am a bit lost here, because I have uninstalled the old version, reinstalled 1.6 and then followed the trick to move it to another folder and then back to the program folder. :(
Post Fri Jan 29, 2016 10:49 pm
In your case it now doesn't start the actual server. Post your serviio log.
Users browsing this forum: Baidu [Spider] and 21 guests
