UHD/4K support
blixem
Post Sat Mar 07, 2015 3:46 pm
UHD/4K support
Is there any 4K/UHD support in Serviio? If not, can you add this (soon)?
Post Sun Mar 08, 2015 11:29 pm
Re: UHD/4K support
I believe the latest versions of FFMPEG support H.265, which is the codec used for most 4K video. Of course, the TV would need to support 4K over DLNA, and that's not a given. I'm not sure Samsung knows how to spell DLNA, based on the issue I'm having with simple MPEG2 video playback. :lol: There should be no issue with the audio, so it's completely dependent on the video codec support of the TV. If the TV doesn't support H.265 over DLNA, then transcoding is the only option, and that may downgrade the quality.
I have no idea if Serviio has any other issues with 4K. While I have a UHD TV, I have no local 4K files to attempt it with. What sort of files were you considering playing? Do you have the media info for one? I have some software at work that I believe is capable of saving a video in H.265, so maybe I'll put a file on a thumb drive and make one for testing.
hansolo
Post Wed Aug 26, 2015 11:41 am
Re: UHD/4K support
It appears to me that serviio does not process 4k files when scanning the library. I have the timescapes 4k videos. My folder structure as below and the only file that shows up is the directors commentary (1080p):-
Shared Videos\4k\TimeScapes\TimeScapes (2012).mp4 [this is a 4k video]
Shared Videos\4k\TimeScapes\TimeScapes.directors.commentary.mp4 [this is a 1080p video]
When using the CDS api one can see that it only returns the 1080p video so i assume serviio analyses the video, sees that it is 4k and excludes it?
Cheers
Post Wed Aug 26, 2015 12:58 pm
Re: UHD/4K support
hansolo wrote:It appears to me that serviio does not process 4k files when scanning the library. I have the timescapes 4k videos. My folder structure as below and the only file that shows up is the directors commentary (1080p):-
Cheers
I answered you in your other post, but I believe it's not the fact it's 4K, but is being triggered by something in the profile you are using. You need to tell us the TV you are using and the profile selected.
Resonate
Post Tue Dec 15, 2015 2:55 pm
Re: UHD/4K support
I have an LG 65UF850V 4K tv. The tv will not play any 4k content in servioo over DLNA.
The TV registered as a generic profile in servioo, i have changed that to LG TV with no success.
Is there any plans to fix this?
Post Wed Dec 16, 2015 1:23 am
Re: UHD/4K support
Resonate wrote:Hi,
Serviio is not broken, so there's nothing to fix. Every time a manufacturer changes something in their TV, profiles have to be modified to match. Since the Serviio developer does not have each and every version of TV available, it's up to the user community to make the changes. So, someone that understands profile development, and has a LG TV that needs a revised profile, can provide an update. With the Samsung TVs, we're still waiting for someone that understands it well enough.
When a player isn't recognized by Serviio, the generic profile is assigned by default. It transcodes nothing, but as you noted it still won't necessarily send through a file. It has to recognize the file as playable, which is what all the first lines of the profile identify. That's where my knowledge is lacking, as I don't understand the MediaFormatProfile lines. Once I figure them out, I can likely figure out how to do the rest.
I've seen a number of players that either identify themselves incorrectly (some Sony players) or don't identify themselves at all (Roku).
Post Wed Dec 16, 2015 8:50 am
Re: UHD/4K support
Resonate
Post Thu Dec 17, 2015 11:49 pm
Re: UHD/4K support
Hi zip.
Thanks for the reply and the link. I have read the link but the issue here is not that the file does not display. It shows up on the TV in the library but when I try to play it on my LG 65UF850V 4K TV it says it cannot play the file.
Resonate
Post Fri Dec 18, 2015 12:15 am
Re: UHD/4K support
I have also played the file via USB and it plays back in UHD on TV.
Post Fri Dec 18, 2015 12:57 am
Re: UHD/4K support
Resonate wrote:I have also played the file via USB and it plays back in UHD on TV.
As mentioned before, USB and DLNA are two separate methods of playing files, and a TV may do one and not the other for a particular file. We probably need to see a detailed log of what's happening.
Resonate
Post Fri Dec 18, 2015 1:02 pm
Re: UHD/4K support
Thanks. I currently have the TV set to LG in the profiles. It was originally set to generic with same result.
Let me know if ive got the wrong bit of the file!
2015-12-18 12:59:44,391 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.0.145
2015-12-18 12:59:44,393 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.0.145
2015-12-18 12:59:44,400 DEBUG [ResourceDeliveryProcessor] Resource request accepted. Using client 'Identifier=192.168.0.145, Profile=LG TV / player'
2015-12-18 12:59:44,401 DEBUG [ResourceDeliveryProcessor] Request for resource 78909 and type 'MEDIA_ITEM' received
2015-12-18 12:59:44,401 DEBUG [MediaResourceRetrievalStrategy] Getting information about media item 78909 (local)
2015-12-18 12:59:44,401 DEBUG [MediaItemDAOImpl] Reading a MediaItem (id = 78909)
2015-12-18 12:59:44,408 DEBUG [VideoDAOImpl] Reading a Video (id = 78909)
2015-12-18 12:59:44,409 DEBUG [VideoDeliveryEngine] Retrieving resource information for item 78909, format MATROSKA and profile LG TV / player
2015-12-18 12:59:44,412 DEBUG [MediaResourceRetrievalStrategy] Getting information about media item 78909 (local)
2015-12-18 12:59:44,412 DEBUG [MediaItemDAOImpl] Reading a MediaItem (id = 78909)
2015-12-18 12:59:44,412 DEBUG [VideoDAOImpl] Reading a Video (id = 78909)
2015-12-18 12:59:44,412 DEBUG [VideoDeliveryEngine] Delivering item '78909' for client 'Identifier=192.168.0.145, Profile=LG TV / player'
2015-12-18 12:59:44,412 DEBUG [VideoDeliveryEngine] Delivering file 'UHD1.by.Astra.2160p.UHDTV.MP2.HEVC.x265-LiebeIst.mkv' in native format
2015-12-18 12:59:44,412 DEBUG [MediaItemDAOImpl] Getting file of media item 78909
2015-12-18 12:59:44,413 DEBUG [MediaItemDAOImpl] Marking MediaItem (id = 78909) as read
2015-12-18 12:59:44,443 DEBUG [LocalContentCacheDecorator] Cleared cache (local_resetafterplay)
2015-12-18 12:59:44,443 DEBUG [GETMethodProcessor] Stream entity has length: 2374700889
2015-12-18 12:59:44,444 DEBUG [ResourceTransportRequestHandler] HTTP/1.1 200 OK, headers = [[Content-Length: 2374700889,Content-Type: video/x-matroska,Cache-control: no-cache,Connection: close,Date: Fri, 18 Dec 2015 12:59:44 GMT,realTimeInfo.dlna.org: DLNA.ORG_TLAG=*,Server: Windows 8, UPnP/1.0 DLNADOC/1.50, Serviio/1.5.2,transferMode.dlna.org: Streaming]]
2015-12-18 12:59:44,632 DEBUG [ServiioHttpService] Incoming request from /192.168.0.145:33877: POST /serviceControl HTTP/1.1, headers = [SOAPAction: "urn:schemas-upnp-org:service:ContentDirectory:1#Browse",DLNADeviceName.lge.com: Living%20room%2065UF850V,User-Agent: Linux/3.10.23-p.21.biscayne.lm15u.3 UPnP/1.0 LGE WebOS TV LGE_DLNA_SDK/1.6.0/04.00.40 DLNADOC/1.50,Host: 192.168.0.6:8895,Content-Length: 680,Content-Type: text/xml; charset="utf-8"]]
2015-12-18 12:59:44,632 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.0.145
2015-12-18 12:59:44,633 DEBUG [ServiceControlRequestHandler] ServiceControl request received for action '"urn:schemas-upnp-org:service:ContentDirectory:1#Browse"' from 192.168.0.145
2015-12-18 12:59:44,633 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.0.145
2015-12-18 12:59:44,638 DEBUG [ContentDirectory] Browse() called for renderer LG TV (profile 8) with parameters: objectID = A_ALB, browseFlag = BrowseDirectChildren, filter = res@resolution,res@nrAudioChannels,res@sampleFrequency,res@bitrate,dc:creator,res@dlna:cleartextSize,dc:date,upnp:genre,res,res@duration,res@size,upnp:albumArtURI,upnp:originalTrackNumber,upnp:album,upnp:artist,upnp:author, startIndex = 90, count = 30, sortCriteria =
Post Fri Dec 18, 2015 1:58 pm
Re: UHD/4K support
I see that it is being served without transcoding, but I don't see any error in that portion of the log. When you use DEBUG mode, there are far more lines for each process. I have a feeling that if there's any error it's further down the log. While there's a 500k size limit for attachments, I suggest uploading either the entire log, or at least as much as you can provide per the limit.
Resonate
Post Fri Dec 18, 2015 5:48 pm
Re: UHD/4K support
Ive done it again, the full file is 70 meg so that isnt happening. Ive loaded the file on the TV and clicked go. It then says it cant play it.
This is all that is really happening in the debug log
2015-12-18 17:39:44,500 DEBUG [CoverImageDAOImpl] Reading a CoverImage (id = 156938)
2015-12-18 17:39:44,500 DEBUG [CoverImageDAOImpl] Reading a CoverImage for music album (id = 4611)
2015-12-18 17:39:44,500 DEBUG [MusicTrackDAOImpl] Retrieving number of music tracks for album 4611 [Any]
2015-12-18 17:39:44,500 DEBUG [PersonDAOImpl] Retrieving list of persons with role ALBUM_ARTIST for MusicAlbum 4611
2015-12-18 17:39:44,500 DEBUG [CoverImageDAOImpl] Reading a CoverImage (id = 156937)
2015-12-18 17:39:44,500 DEBUG [CoverImageDAOImpl] Reading a CoverImage for music album (id = 4610)
2015-12-18 17:39:44,501 DEBUG [MusicTrackDAOImpl] Retrieving number of music tracks for album 4610 [Any]
2015-12-18 17:39:44,501 DEBUG [PersonDAOImpl] Retrieving list of persons with role ALBUM_ARTIST for MusicAlbum 4610
2015-12-18 17:39:44,501 DEBUG [CoverImageDAOImpl] Reading a CoverImage (id = 156936)
2015-12-18 17:39:44,501 DEBUG [CoverImageDAOImpl] Reading a CoverImage for music album (id = 4609)
2015-12-18 17:39:44,501 DEBUG [MusicTrackDAOImpl] Retrieving number of music tracks for album 4609 [Any]
2015-12-18 17:39:44,501 DEBUG [PersonDAOImpl] Retrieving list of persons with role ALBUM_ARTIST for MusicAlbum 4609
2015-12-18 17:39:44,502 DEBUG [CoverImageDAOImpl] Reading a CoverImage (id = 156935)
2015-12-18 17:39:44,502 DEBUG [CoverImageDAOImpl] Reading a CoverImage for music album (id = 4608)
2015-12-18 17:39:44,502 DEBUG [MusicTrackDAOImpl] Retrieving number of music tracks for album 4608 [Any]
2015-12-18 17:39:44,502 DEBUG [PersonDAOImpl] Retrieving list of persons with role ALBUM_ARTIST for MusicAlbum 4608
2015-12-18 17:39:44,502 DEBUG [CoverImageDAOImpl] Reading a CoverImage (id = 156934)
2015-12-18 17:39:44,503 DEBUG [MusicAlbumDAOImpl] Getting number of all albums
2015-12-18 17:39:44,509 DEBUG [LocalContentCacheDecorator] Stored entry in the cache (local_default), returning it
2015-12-18 17:39:44,517 DEBUG [ServiceControlRequestHandler] Returning OK SOAP message
2015-12-18 17:39:45,674 DEBUG [ServiioHttpService] Incoming request from /192.168.0.145:56505: GET /resource/78909/MEDIA_ITEM/MATROSKA-0/ORIGINAL HTTP/1.1, headers = [Host: 192.168.0.6:8895,Connection: close,icy-metadata: 1,Referer: ,Cookie: ,User-Agent: Mozilla/5.0 (Web0S; Linux/SmartTV) AppleWebKit/538.2 (KHTML, like Gecko) Large Screen WebAppManager Safari/538.2]]
2015-12-18 17:39:45,674 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.0.145
2015-12-18 17:39:45,675 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.0.145
2015-12-18 17:39:45,675 DEBUG [ResourceDeliveryProcessor] Resource request accepted. Using client 'Identifier=192.168.0.145, Profile=LG TV / player'
2015-12-18 17:39:45,676 DEBUG [ResourceDeliveryProcessor] Request for resource 78909 and type 'MEDIA_ITEM' received
2015-12-18 17:39:45,676 DEBUG [MediaResourceRetrievalStrategy] Getting information about media item 78909 (local)
2015-12-18 17:39:45,676 DEBUG [MediaItemDAOImpl] Reading a MediaItem (id = 78909)
2015-12-18 17:39:45,684 DEBUG [VideoDAOImpl] Reading a Video (id = 78909)
2015-12-18 17:39:45,685 DEBUG [VideoDeliveryEngine] Retrieving resource information for item 78909, format MATROSKA and profile LG TV / player
2015-12-18 17:39:45,686 DEBUG [MediaResourceRetrievalStrategy] Getting information about media item 78909 (local)
2015-12-18 17:39:45,686 DEBUG [MediaItemDAOImpl] Reading a MediaItem (id = 78909)
2015-12-18 17:39:45,687 DEBUG [VideoDAOImpl] Reading a Video (id = 78909)
2015-12-18 17:39:45,687 DEBUG [VideoDeliveryEngine] Delivering item '78909' for client 'Identifier=192.168.0.145, Profile=LG TV / player'
2015-12-18 17:39:45,687 DEBUG [VideoDeliveryEngine] Delivering file 'UHD1.by.Astra.2160p.UHDTV.MP2.HEVC.x265-LiebeIst.mkv' in native format
2015-12-18 17:39:45,688 DEBUG [MediaItemDAOImpl] Getting file of media item 78909
2015-12-18 17:39:45,689 DEBUG [MediaItemDAOImpl] Marking MediaItem (id = 78909) as read
2015-12-18 17:39:45,701 DEBUG [LocalContentCacheDecorator] Cleared cache (local_resetafterplay)
2015-12-18 17:39:45,701 DEBUG [GETMethodProcessor] Stream entity has length: 2374700889
2015-12-18 17:39:45,701 DEBUG [ResourceTransportRequestHandler] HTTP/1.1 200 OK, headers = [[Content-Length: 2374700889,Content-Type: video/x-matroska,Cache-control: no-cache,Connection: close,Date: Fri, 18 Dec 2015 17:39:45 GMT,realTimeInfo.dlna.org: DLNA.ORG_TLAG=*,Server: Windows 8, UPnP/1.0 DLNADOC/1.50, Serviio/1.5.2,transferMode.dlna.org: Streaming]]
2015-12-18 17:39:46,459 DEBUG [ServiioHttpService] Incoming request from /192.168.0.145:56348: POST /serviceControl HTTP/1.1, headers = [SOAPAction: "urn:schemas-upnp-org:service:ContentDirectory:1#Browse",DLNADeviceName.lge.com: Living%20room%2065UF850V,User-Agent: Linux/3.10.23-p.21.biscayne.lm15u.3 UPnP/1.0 LGE WebOS TV LGE_DLNA_SDK/1.6.0/04.00.40 DLNADOC/1.50,Host: 192.168.0.6:8895,Content-Length: 682,Content-Type: text/xml; charset="utf-8"]]
2015-12-18 17:39:46,459 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.0.145
2015-12-18 17:39:46,460 DEBUG [ServiceControlRequestHandler] ServiceControl request received for action '"urn:schemas-upnp-org:service:ContentDirectory:1#Browse"' from 192.168.0.145
2015-12-18 17:39:46,460 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.0.145
2015-12-18 17:39:46,464 DEBUG [ContentDirectory] Browse() called for renderer LG TV (profile 8) with parameters: objectID = A_ALB, browseFlag = BrowseDirectChildren, filter = res@resolution,res@nrAudioChannels,res@sampleFrequency,res@bitrate,dc:creator,res@dlna:cleartextSize,dc:date,upnp:genre,res,res@duration,res@size,upnp:albumArtURI,upnp:originalTrackNumber,upnp:album,upnp:artist,upnp:author, startIndex = 2460, count = 30, sortCriteria =
2015-12-18 17:39:46,464 DEBUG [MusicAlbumDAOImpl] Retrieving list of all music albums (from=2460, count=30)
2015-12-18 17:39:46,487 DEBUG [WebServer] I/O error: Connection reset by peer: socket write error
2015-12-18 17:39:46,496 DEBUG [CoverImageDAOImpl] Reading a CoverImage for music album (id = 4607)
2015-12-18 17:39:46,496 DEBUG [MusicTrackDAOImpl] Retrieving number of music tracks for album 4607 [Any]
2015-12-18 17:39:46,496 DEBUG [PersonDAOImpl] Retrieving list of persons with role ALBUM_ARTIST for MusicAlbum 4607
2015-12-18 17:39:46,496 DEBUG [CoverImageDAOImpl] Reading a CoverImage (id = 156933)
2015-12-18 17:39:46,497 DEBUG [CoverImageDAOImpl] Reading a CoverImage for music album (id = 4606)
2015-12-18 17:39:46,497 DEBUG [MusicTrackDAOImpl] Retrieving number of music tracks for album 4606 [Any]
2015-12-18 17:39:46,497 DEBUG [PersonDAOImpl] Retrieving list of persons with role ALBUM_ARTIST for MusicAlbum 4606
2015-12-18 17:39:46,497 DEBUG [CoverImageDAOImpl] Reading a CoverImage (id = 156932)
2015-12-18 17:39:46,497 DEBUG [CoverImageDAOImpl] Reading a CoverImage for music album (id = 4605)
2015-12-18 17:39:46,498 DEBUG [MusicTrackDAOImpl] Retrieving number of music tracks for album 4605 [Any]
2015-12-18 17:39:46,498 DEBUG [PersonDAOImpl] Retrieving list of persons with role ALBUM_ARTIST for MusicAlbum 4605
2015-12-18 17:39:46,498 DEBUG [CoverImageDAOImpl] Reading a CoverImage (id = 156931)
2015-12-18 17:39:46,498 DEBUG [CoverImageDAOImpl] Reading a CoverImage for music album (id = 4604)
2015-12-18 17:39:46,498 DEBUG [MusicTrackDAOImpl] Retrieving number of music tracks for album 4604 [Any]
2015-12-18 17:39:46,498 DEBUG [PersonDAOImpl] Retrieving list of persons with role ALBUM_ARTIST for MusicAlbum 4604
2015-12-18 17:39:46,499 DEBUG [CoverImageDAOImpl] Reading a CoverImage (id = 156930)
2015-12-18 17:39:46,499 DEBUG [CoverImageDAOImpl] Reading a CoverImage for music album (id = 4603)
2015-12-18 17:39:46,499 DEBUG [MusicTrackDAOImpl] Retrieving number of music tracks for album 4603 [Any]
2015-12-18 17:39:46,499 DEBUG [PersonDAOImpl] Retrieving list of persons with role ALBUM_ARTIST for MusicAlbum 4603
2015-12-18 17:39:46,499 DEBUG [CoverImageDAOImpl] Reading a CoverImage (id = 156908)
2015-12-18 17:39:46,500 DEBUG [CoverImageDAOImpl] Reading a CoverImage for music album (id = 4602)
2015-12-18 17:39:46,500 DEBUG [MusicTrackDAOImpl] Retrieving number of music tracks for album 4602 [Any]
2015-12-18 17:39:46,500 DEBUG [PersonDAOImpl] Retrieving list of persons with role ALBUM_ARTIST for MusicAlbum 4602
2015-12-18 17:39:46,500 DEBUG [CoverImageDAOImpl] Reading a CoverImage (id = 156907)
2015-12-18 17:39:46,501 DEBUG [CoverImageDAOImpl] Reading a CoverImage for music album (id = 4601)
2015-12-18 17:39:46,501 DEBUG [MusicTrackDAOImpl] Retrieving number of music tracks for album 4601 [Any]
2015-12-18 17:39:46,501 DEBUG [PersonDAOImpl] Retrieving list of persons with role ALBUM_ARTIST for MusicAlbum 4601
2015-12-18 17:39:46,501 DEBUG [CoverImageDAOImpl] Reading a CoverImage (id = 156906)
2015-12-18 17:39:46,501 DEBUG [CoverImageDAOImpl] Reading a CoverImage for music album (id = 4600)
2015-12-18 17:39:46,501 DEBUG [MusicTrackDAOImpl] Retrieving number of music tracks for album 4600 [Any]
2015-12-18 17:39:46,502 DEBUG [PersonDAOImpl] Retrieving list of persons with role ALBUM_ARTIST for MusicAlbum 4600
2015-12-18 17:39:46,502 DEBUG [CoverImageDAOImpl] Reading a CoverImage (id = 156905)
2015-12-18 17:39:46,502 DEBUG [CoverImageDAOImpl] Reading a CoverImage for music album (id = 4599)
2015-12-18 17:39:46,502 DEBUG [MusicTrackDAOImpl] Retrieving number of music tracks for album 4599 [Any]
2015-12-18 17:39:46,502 DEBUG [PersonDAOImpl] Retrieving list of persons with role ALBUM_ARTIST for MusicAlbum 4599
2015-12-18 17:39:46,502 DEBUG [CoverImageDAOImpl] Reading a CoverImage (id = 156904)
2015-12-18 17:39:46,503 DEBUG [CoverImageDAOImpl] Reading a CoverImage for music album (id = 4598)
2015-12-18 17:39:46,503 DEBUG [MusicTrackDAOImpl] Retrieving number of music tracks for album 4598 [Any]
2015-12-18 17:39:46,503 DEBUG [PersonDAOImpl] Retrieving list of persons with role ALBUM_ARTIST for MusicAlbum 4598
2015-12-18 17:39:46,503 DEBUG [CoverImageDAOImpl] Reading a CoverImage (id = 156903)
2015-12-18 17:39:46,503 DEBUG [CoverImageDAOImpl] Reading a CoverImage for music album (id = 4597)
2015-12-18 17:39:46,503 DEBUG [MusicTrackDAOImpl] Retrieving number of music tracks for album 4597 [Any]
2015-12-18 17:39:46,504 DEBUG [PersonDAOImpl] Retrieving list of persons with role ALBUM_ARTIST for MusicAlbum 4597
2015-12-18 17:39:46,504 DEBUG [CoverImageDAOImpl] Reading a CoverImage (id = 156902)
2015-12-18 17:39:46,504 DEBUG [CoverImageDAOImpl] Reading a CoverImage for music album (id = 4596)
2015-12-18 17:39:46,504 DEBUG [MusicTrackDAOImpl] Retrieving number of music tracks for album 4596 [Any]
2015-12-18 17:39:46,504 DEBUG [PersonDAOImpl] Retrieving list of persons with role ALBUM_ARTIST for MusicAlbum 4596
2015-12-18 17:39:46,504 DEBUG [CoverImageDAOImpl] Reading a CoverImage (id = 156901)
2015-12-18 17:39:46,505 DEBUG [CoverImageDAOImpl] Reading a CoverImage for music album (id = 4595)
2015-12-18 17:39:46,505 DEBUG [MusicTrackDAOImpl] Retrieving number of music tracks for album 4595 [Any]
2015-12-18 17:39:46,505 DEBUG [PersonDAOImpl] Retrieving list of persons with role ALBUM_ARTIST for MusicAlbum 4595
2015-12-18 17:39:46,505 DEBUG [CoverImageDAOImpl] Reading a CoverImage (id = 156900)
2015-12-18 17:39:46,505 DEBUG [CoverImageDAOImpl] Reading a CoverImage for music album (id = 4594)
2015-12-18 17:39:46,506 DEBUG [MusicTrackDAOImpl] Retrieving number of music tracks for album 4594 [Any]
2015-12-18 17:39:46,506 DEBUG [PersonDAOImpl] Retrieving list of persons with role ALBUM_ARTIST for MusicAlbum 4594
2015-12-18 17:39:46,506 DEBUG [CoverImageDAOImpl] Reading a CoverImage (id = 156899)
2015-12-18 17:39:46,506 DEBUG [CoverImageDAOImpl] Reading a CoverImage for music album (id = 4593)
2015-12-18 17:39:46,506 DEBUG [MusicTrackDAOImpl] Retrieving number of music tracks for album 4593 [Any]
2015-12-18 17:39:46,506 DEBUG [PersonDAOImpl] Retrieving list of persons with role ALBUM_ARTIST for MusicAlbum 4593
2015-12-18 17:39:46,506 DEBUG [CoverImageDAOImpl] Reading a CoverImage (id = 156898)
2015-12-18 17:39:46,507 DEBUG [CoverImageDAOImpl] Reading a CoverImage for music album (id = 4592)
Along with some periodical:-
2015-12-18 17:41:36,116 DEBUG [LocalContentCacheDecorator] Stored entry in the cache (local_default), returning it
2015-12-18 17:41:36,121 DEBUG [ServiceControlRequestHandler] Returning OK SOAP message
2015-12-18 17:41:38,057 DEBUG [ServiioHttpService] Incoming request from /192.168.0.145:56511: POST /serviceControl HTTP/1.1, headers = [SOAPAction: "urn:schemas-upnp-org:service:ContentDirectory:1#Browse",DLNADeviceName.lge.com: Living%20room%2065UF850V,User-Agent: Linux/3.10.23-p.21.biscayne.lm15u.3 UPnP/1.0 LGE WebOS TV LGE_DLNA_SDK/1.6.0/04.00.40 DLNADOC/1.50,Host: 192.168.0.6:8895,Content-Length: 682,Content-Type: text/xml; charset="utf-8"]]
2015-12-18 17:41:38,058 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.0.145
2015-12-18 17:41:38,059 DEBUG [ServiceControlRequestHandler] ServiceControl request received for action '"urn:schemas-upnp-org:service:ContentDirectory:1#Browse"' from 192.168.0.145
2015-12-18 17:41:38,059 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.0.145
2015-12-18 17:41:38,064 DEBUG [ContentDirectory] Browse() called for renderer LG TV (profile 8) with parameters: objectID = A_ALB, browseFlag = BrowseDirectChildren, filter = res@resolution,res@nrAudioChannels,res@sampleFrequency,res@bitrate,dc:creator,res@dlna:cleartextSize,dc:date,upnp:genre,res,res@duration,res@size,upnp:albumArtURI,upnp:originalTrackNumber,upnp:album,upnp:artist,upnp:author, startIndex = 4050, count = 30, sortCriteria =
2015-12-18 17:41:38,064 DEBUG [MusicAlbumDAOImpl] Retrieving list of all music albums (from=4050, count=30)
And one of these shortly after
2015-12-18 17:39:52,535 DEBUG [PersonDAOImpl] Retrieving list of persons with role ALBUM_ARTIST for MusicAlbum 5581
2015-12-18 17:39:52,536 DEBUG [MusicAlbumDAOImpl] Getting number of all albums
2015-12-18 17:39:52,540 DEBUG [LocalContentCacheDecorator] Stored entry in the cache (local_default), returning it
2015-12-18 17:39:52,543 DEBUG [ServiceControlRequestHandler] Returning OK SOAP message
2015-12-18 17:39:53,903 DEBUG [ServiioHttpService] Incoming request from /192.168.0.145:56348: SUBSCRIBE /serviceEventing/ContentDirectory HTTP/1.1, headers = [SID: uuid:b92fa3c7-03d3-40b5-84ef-1372d5fed6e7,TIMEOUT: Second-300,DLNADeviceName.lge.com: Living%20room%2065UF850V,User-Agent: Linux/3.10.23-p.21.biscayne.lm15u.3 UPnP/1.0 LGE WebOS TV LGE_DLNA_SDK/1.6.0/04.00.40 DLNADOC/1.50,Host: 192.168.0.6:8895]]
2015-12-18 17:39:53,903 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.0.145
2015-12-18 17:39:53,903 DEBUG [ServiceEventSubscriptionRequestHandler] ServiceEvent renewal request received for service ContentDirectory and subscription uuid:b92fa3c7-03d3-40b5-84ef-1372d5fed6e7
2015-12-18 17:39:53,903 DEBUG [ServiceEventSubscriptionRequestHandler] Event subscription renewed for service urn:upnp-org:serviceId:ContentDirectory and subscription b92fa3c7-03d3-40b5-84ef-1372d5fed6e7
2015-12-18 17:39:53,904 DEBUG [ServiioHttpService] Incoming request from /192.168.0.145:56511: SUBSCRIBE /serviceEventing/ConnectionManager HTTP/1.1, headers = [SID: uuid:932914ea-5de7-493e-b4a6-9ecb9e9c2dc8,TIMEOUT: Second-300,DLNADeviceName.lge.com: Living%20room%2065UF850V,User-Agent: Linux/3.10.23-p.21.biscayne.lm15u.3 UPnP/1.0 LGE WebOS TV LGE_DLNA_SDK/1.6.0/04.00.40 DLNADOC/1.50,Host: 192.168.0.6:8895]]
2015-12-18 17:39:53,904 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.0.145
2015-12-18 17:39:53,905 DEBUG [ServiceEventSubscriptionRequestHandler] ServiceEvent renewal request received for service ConnectionManager and subscription uuid:932914ea-5de7-493e-b4a6-9ecb9e9c2dc8
2015-12-18 17:39:53,905 DEBUG [ServiceEventSubscriptionRequestHandler] Event subscription renewed for service urn:upnp-org:serviceId:ConnectionManager and subscription 932914ea-5de7-493e-b4a6-9ecb9e9c2dc8
2015-12-18 17:39:54,496 DEBUG [ServiioHttpService] Incoming request from /192.168.0.145:56348: POST /serviceControl HTTP/1.1, headers = [SOAPAction: "urn:schemas-upnp-org:service:ContentDirectory:1#Browse",DLNADeviceName.lge.com: Living%20room%2065UF850V,User-Agent: Linux/3.10.23-p.21.biscayne.lm15u.3 UPnP/1.0 LGE WebOS TV LGE_DLNA_SDK/1.6.0/04.00.40 DLNADOC/1.50,Host: 192.168.0.6:8895,Content-Length: 682,Content-Type: text/xml; charset="utf-8"]]
2015-12-18 17:39:54,497 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.0.145
2015-12-18 17:39:54,497 DEBUG [ServiceControlRequestHandler] ServiceControl request received for action '"urn:schemas-upnp-org:service:ContentDirectory:1#Browse"' from 192.168.0.145
2015-12-18 17:39:54,502 DEBUG [ContentDirectory] Browse() called for renderer LG TV (profile 8) with parameters: objectID = A_ALB, browseFlag = BrowseDirectChildren, filter = res@resolution,res@nrAudioChannels,res@sampleFrequency,res@bitrate,dc:creator,res@dlna:cleartextSize,dc:date,upnp:genre,res,res@duration,res@size,upnp:albumArtURI,upnp:originalTrackNumber,upnp:album,upnp:artist,upnp:author, startIndex = 2580, count = 30, sortCriteria =
2015-12-18 17:39:54,502 DEBUG [MusicAlbumDAOImpl] Retrieving list of all music albums (from=2580, count=30)
2015-12-18 17:39:54,522 DEBUG [CoverImageDAOImpl] Reading a CoverImage for music album (id = 5580)
2015-12-18 17:39:54,522 DEBUG [MusicTrackDAOImpl] Retrieving number of music tracks for album 5580 [Any]
2015-12-18 17:39:54,522 DEBUG [PersonDAOImpl] Retrieving list of persons with role ALBUM_ARTIST for MusicAlbum 5580
Post Fri Dec 18, 2015 10:17 pm
Re: UHD/4K support
I must now defer to Zip, or one of the other more knowledgeable people about what it all means... :oops:
franjhos
Post Fri Jan 29, 2016 2:43 pm
Re: UHD/4K support
Hola amigos he Actualizado a la ultima versión de serviio, pero no hay ningún perfil nuevo para la panasonic ax800, tengo problemas para que reconozca archivos con códec hevc, habrá pronto compatibilidad?
Return to Feature requests
