SdeWeb
Post Sat Jan 30, 2016 10:01 am
Re: PACKAGE: Serviio 1.6 - Synology NAS, with HW transcoding
I got a Synology DS211 since 4 year only for Serviio.
Since i've upgrade to Serviio 1.6, using the "ssh" method, the CPU load still above 90%, even if no content was played.
Transcoding option is Off in Serviio console.
When i check Ressources Monitor, the process named "ffmpeg" use always more than 65%, many time 99% of CPU.
The only thing that was not upgraded is Java, my version is : 1.8.0_65-0035.
There's a solution, or shuld i downgrade my Serviio version to 1.5 ?
Regards.
Seb.
anachron
Post Sat Jan 30, 2016 11:26 am
Hello SdeWeb,
I think you are running into the same issue as me (see viewtopic.php?f=5&t=21480 ). The issue doesn't seems to be related to the NAS package but to Serviio 1.6. It is more noticeable on NAS due to low CPU power i guess.
SdeWeb
Post Sat Jan 30, 2016 12:05 pm
Thanx for u'r help.
Finally after some hour of running, the CPU load decrease to a good value. (under 25%) even during playing a movie.
I think that the overload was issue by a library refresh, i think that the refresh use ffmpeg to work.
I hope that this state will stay ok.
Thanx 4 all.
Regards.
_roon_
Post Tue Feb 02, 2016 12:26 pm
_roon_ wrote:
patters wrote:Odd. Well you could stop Serviio. Then connect as root via SSH:
cp -R /var/packages/Serviio/target/library /volume1/@tmp/
Uninstall Serviio 1.5.2. Install Serviio 1.6 but don't start it. Then:
rm -rf /var/packages/Serviio/target/library
mv /volume1/@tmp/library/ /var/packages/Serviio/target/
Start Serviio. Your library, licence key, and online sources will be preserved.
If you're running DSM 6.0 beta 2 you need to connect to SSH as admin (root no longer allowed). Once connected run "sudo -i" and use the admin password again to switch to root.
Thanks! Will try that and post the result here.
OK, this works. Got it running on version 1.6 now.
THanks! Keep up the good work!
clyve
Post Fri Feb 05, 2016 12:55 am
Tried to install serviio on my 215j, but got the following error:
http://puu.sh/mW9Td/5cb7e7e7cd.png
Got java 8 installed, but the service is not running (Leállított)
http://puu.sh/mWaME/6d10f33938.png
Many Thanks!
Viktor
clyve
Post Fri Feb 05, 2016 11:17 am
DSM version is 5.2-5644 update 3
http://puu.sh/mWD6h/92d540a082.png
clyve wrote:Tried to install serviio on my 215j, but got the following error:
Many Thanks!
Viktor
patters
Post Fri Feb 05, 2016 12:21 pm
Look at the log for the Java package. It's not properly installed unless you can see the HotSpot version there. It should show:
java version "1.8.0_71"
Java(TM) SE Embedded Runtime Environment (build 1.8.0_71-b15, headless)
Java HotSpot(TM) Embedded Client VM (build 25.71-b15, mixed mode)
System installed locales:
C
cs_CZ.utf8
da_DK.utf8
de_DE.utf8
en_US.utf8
es_ES.utf8
fr_FR.utf8
hu_HU.utf8
it_IT.utf8
ja_JP.utf8
ko_KR.utf8
nb_NO.utf8
nl_NL.utf8
pl_PL.utf8
POSIX
pt_BR.utf8
pt_PT.utf8
ru_RU.utf8
sv_SE.utf8
tr_TR.utf8
zh_CN.utf8
zh_TW.utf8
JAVA_HOME=/volume1/@appstore/java8/ejdk1.8.0_71/linux_i586/jre
TZ=Europe/Dublin
If you don't see this then you've done something wrong. I'd suggest using Firefox to download the file from Oracle.
clyve
Post Fri Feb 05, 2016 4:56 pm
Thanks for your answer!
I downloaded wrong java versions ( ....arm32 and arm64 bit ).
Finally found the proper one, and installing was supersmooth, now configuring serviio.
http://puu.sh/mWSE8/63e427c80e.png
Thanks again!
patters wrote:Look at the log for the Java package. It's not properly installed unless you can see the HotSpot version there. It should show:
C
cs_CZ.utf8
da_DK.utf8
de_DE.utf8
en_US.utf8
es_ES.utf8
fr_FR.utf8
hu_HU.utf8
it_IT.utf8
ja_JP.utf8
ko_KR.utf8
nb_NO.utf8
nl_NL.utf8
pl_PL.utf8
POSIX
pt_BR.utf8
pt_PT.utf8
ru_RU.utf8
sv_SE.utf8
tr_TR.utf8
zh_CN.utf8
zh_TW.utf8
TZ=Europe/Dublin
clyve
Post Sat Feb 06, 2016 7:17 am
Serviio is still the best! Im using it for long time now on my pc, and now that I have the syno 215j NAS, its working just as good as it does on the pc!
Thanks for this wonderful app! :)
kretzu77
Post Sun Feb 07, 2016 9:21 am
Hi there,
I tried everything and I still have port 23423 issue
My current version is 1.5.2-0028
but still I can't update Serviio
My java is 1.8.0_72
Can you help me somehow please?
TY
patters
Post Sun Feb 07, 2016 10:56 am
Seems to be an issue I didn't get during testing. Have a look here for the solution:
viewtopic.php?f=14&t=3311&start=220#p106588
subora
Post Fri Feb 19, 2016 5:18 pm
DS413 with error:
Java HotSpot™ Embedded Client VM warning: G1 GC is disabled in this release.
copfy
Post Sat Mar 05, 2016 6:18 pm
DS214play, DSM 5.2, Sony Bravia TV
Works perfectly! Much better, more format and device support than the integrated Video Station, without any lagging.
Thank you so much!
FYKI, the DSM 6 (64 bit version!) is on the way, currently in beta 2... I hope Servio still working on it.
Zsolt
patters
Post Mon Mar 07, 2016 4:40 pm
subora wrote:DS413 with error:
That happens on all versions - Java Embedded lacks the G1 garbage collector. It's only a warning though, it will drop back to using one of the alternate garbage collectors (they free up and consolidate RAM when the application has been running a while).
patters
Post Mon Mar 07, 2016 4:41 pm
copfy wrote:DS214play, DSM 5.2, Sony Bravia TV
My system runs DSM 6.0 RC and Serviio is fine.
Mikkael
Post Fri Mar 11, 2016 8:13 pm
Synlogy DS214se, DSM 5.2.5644-U5
Serviio 1.6:
1) very, very, very slow, open any folder 6-10 seconds (on 1.4.2.1 and 1.5.2 - 1-2 seconds). I tried to uninstall, remove database and install again - same thing.
Serviio 1.5.2(027, 028):
1) sometime half-scanned files, for example
on NAS: Monsters University (2013).avi 1:43:47
in Seviio: Monsters University (2013).avi 57:35
after renaming to Monsters University (2013)1.avi
on NAS: Monsters University (2013)1.avi 1:43:47
in Seviio: Monsters University (2013)1.avi 1:43:47
2) sometime half-scanned folders, for example:
on NAS folder:
05x01 The Red Glass Bead.avi
05x02 Devil's Cherry.avi
05x03 Not One Red Cent.avi
05x04 Blood Feud.avi
05x05 Red Dawn.avi
05x06 Cherry Picked.avi
in Serviio, same folder:
3) Console on PC very often can't connect to Serviio on NAS.
Serviio 1.4.1.2 worked fine for 2 years and did not have any of these bugs.
I tried to downgrade to Serviio 1.4.1.2, but with no luck. I found serviio1.4.1.2-merged-0026.spk on your server, but serviio1.4-native-armv7l.tgz is missing. Can you return this file to your server or maybe upload it to dropbox/skydrive?
patters
Post Sat May 21, 2016 12:50 pm
Re: PACKAGE: Serviio 1.6.1 - Synology NAS, with HW transcodi
I have updated the Synology package to Serviio 1.6.1.
frankwbb
Post Sat May 21, 2016 1:27 pm
I updated it from version 1.6 to 1.6.1. After the download I get the following message (see attachment).
I take this from this threat but it don't solve the problem:
viewtopic.php?f=14&t=3311&start=220#p106595
Best regards
frankwbb
M3kk
Post Sun May 22, 2016 8:32 am
Hello, there is a problem with 1.6.1?
I updated (at least i wanted) from 1.6 to 1.6.1. First i get some java related error, but after i resolved that i cant install serviio anymore. I get the port error:
I tried to clean all Serviio Related things from my NAS, several restarts, also i verified if the port 23423 is used by another process, but it doesent.
Can you check it? Or can you recommend me what anything else i should try?
patters
Post Sun May 22, 2016 1:11 pm
This does not happen on my system. Did you do something non-standard when 1.6 first came out, and there were issues upgrading from 1.5.2? I remember someone on here published some instructions to edit the firewall definitions registration inside the package and I urged people not to do this as they would end up with an orphaned firewall definition.
Try restarting the NAS, sometimes that can glitchy fix port conflict messages.
