Odd media browser problem
scottyboy235
Post Sun Jan 31, 2016 11:21 am
Anyone else experienced the following odd problem with the v1.6 Pro version of Serviio?
Basically I can view and play any URL resource provided the serviio media browser is accessed via Internet Explorer or Chrome
If I try to play the same links using the media browser accessed via the serviio console I get an error message: -
'Flash version 10.1 or greater is required. You have no flash plugin installed '
Serviio is running on Win7 64 bit.
Is this a bug in the program?
Post Sun Jan 31, 2016 6:51 pm
Re: Odd media browser problem
Yes, it'll be fixed in 1.6.1 (ie the link from the console will open in your default browser rather than in the web page wrapper the console runs in).
You can use MB as usual by going to it from your web browser now.
scottyboy235
Post Sun Jan 31, 2016 8:35 pm
Fair enough.
Thanks for the response
