Service Shutdown on Console Close
cuf
Post Sat Jan 30, 2016 7:35 am
In version 1.5 of Serviio, when the console was closed the Serviio service automatically shutdown as well.
I don't know if this was by design or a bug, but I liked it.
I'd like to request a return of this functionality or an option that reinstates it.
I don't like unused services running, every program wants to do that. When I want Serviio on, I turn it on. When I want it off, taking the extra step of running "Stop Serviio Service" seems like make work.
The long version:
In v1.5 I customized the way Serviio worked. ServiioService was set to manual (instead of automatic) and did not start with windows.
When I wanted to turn Serviio on, I launched a batch file that started the service as well as ServiioConsole with the console minimized to the system tray.
When I was finished with Serviio, I closed the console and Serviio automatically killed the service as well.
To me, that is the ideal way for any and all programs to function. Not leaving hidden bits running using up memory and CPU cycles.
Post Sat Jan 30, 2016 6:03 pm
Re: Service Shutdown on Console Close
Serviio is designed as a service, so it is available at all times. What you are requesting wasn't part of a previous version, you just created a script to do it. Closing the console did not stop the Serviio service.
There's no reason you can't still use a script to do the same now. The difference is there is no longer a Serviio console app, therefore there's nothing to run in the System tray. The console is now web based, so there's nothing to show in the tray. Just write your scripts to start or stop Serviio, and if desired you could start the console in a browser at the same time. However, I know of no way to minimize a browser to the system tray.
cuf
Post Sat Jan 30, 2016 8:50 pm
You seem confused about two things.
In the previous version the service DID stop when you closed the console. Maybe it was an unreported bug, but it was how it functioned. NOT something I did to it.
My scripted only started the service before launching the console so it didn't have to be started with Windows.
Also, I don't know what you're talking about the console being 'web based'. When I launch the v1.6 console it is a console and in no way web based... in fact I see no way to open it in a browser. Are you sure you're talking about the Windows version?
Post Sat Jan 30, 2016 10:58 pm
cuf wrote:In the previous version the service DID stop when you closed the console.
That is not true. More details here: viewtopic.php?f=5&t=21486#p106663
Post Sun Jan 31, 2016 12:13 am
cuf wrote:You seem confused about two things.
As Zip, said, the console and the service were completely separate in past versions and the latest 1.6. Perhaps you thought the service stopped when the icon was no longer displayed in the system tray. This is incorrect, as the tray icon was only related to the console, not the service.
The "console" you see with 1.6 is a custom web browser included with the Serviio install. It may not look like a normal browser, but it is. As Zip says, you can access it from any computer on your network, not just the computer with Serviio. The URL is serviiocomputername:23423/console
All due respect, but I'm not the confused one. ;)
cuf
Post Sun Jan 31, 2016 9:07 am
Okay, I accept what you are saying, but to be clear:
In v1.5 I kept the ServiioService on Manual and it did not start with Windows.
To run Serviio (at all), I ran a batch file that launched the Service and then the Console. Period. I'm aware the console wasn't necessary for the service to run, but this way I would know Serviio was running only when the tray icon was there. It gave me a visual indication and ready access to 'Force Refresh' right there in the tray.
The thing is, before I even created the batch file I had found that for some reason if the console was closed, the service stopped.
That wasn't my doing, that wasn't my script, that was how Serviio acted. MAYBE it was because I kept the service on manual rather than automatic, but Serviio killed the service's process by itself. Bug or unintended action, that IS how it was. Argue all you want, but it's what it was doing for me and I liked it.
Post Sun Jan 31, 2016 10:11 pm
I won't dispute your experience, as that would be dumb of me. :D
Perhaps it was because you had it configured as a manual service, but I have no idea why. I've used Serviio for years, and constantly opened and closed the console without affecting the service, so it's a mystery to me. :?:
Post Sun Jan 31, 2016 10:44 pm
There was a 'Exit Serviio' item in the system tray menu (which would exit both, the console and the server), so perhaps he means that.
cuf
Post Mon Feb 01, 2016 7:19 am
zip wrote:There was a 'Exit Serviio' item in the system tray menu (which would exit both, the console and the server), so perhaps he means that.
Sounds right to me.
Post Mon Feb 01, 2016 1:24 pm
Ah, the answer! I had forgotten that was there, as I never used it. I was assuming (bad word!) that he was just closing the console with the normal Windows X button in the window. Now it all makes sense. :lol:
Return to Feature requests
