Samsung UE43J5500 + Serviio 1.6 = No content on TV
rkarpinski
Post Thu Jan 28, 2016 4:38 pm
My Serviio 1.6 server is installed on Zyxel NSA325 which means Linux :-)
I've installed Serviio succesfully. Other devices have no problem with this but TV does.
Maybe some permissions on linux? Please help. If you need something from me, please tell!
Error from logfile:
2016-01-28 16:56:07,826 ERROR [ServiceControlRequestHandler] Cannot process control request: Service urn:schemas-upnp-org:service:ContentDirectory:3 is not registered
org.serviio.upnp.protocol.soap.ServiceInvocationException: Service urn:schemas-upnp-org:service:ContentDirectory:3 is not registered
at org.serviio.upnp.protocol.soap.ServiceInvoker.invokeOperation(ServiceInvoker.java:272)
at org.serviio.upnp.protocol.soap.ServiceInvoker.invokeService(ServiceInvoker.java:93)
at org.serviio.upnp.webserver.ServiceControlRequestHandler.handleRequest(ServiceControlRequestHandler.java:66)
at org.apache.http.protocol.HttpService.doService(HttpService.java:423)
at org.serviio.upnp.webserver.ServiioHttpService.doService(ServiioHttpService.java:78)
at org.apache.http.protocol.HttpService.handleRequest(HttpService.java:341)
at org.serviio.upnp.webserver.WebServer$WorkerThread.run(WebServer.java:204)
Regards.
rkarpinski
Post Sat Jan 30, 2016 4:56 pm
Re: Samsung UE43J5500 + Serviio 1.6 = No content on TV
Really, no one?
Post Sat Jan 30, 2016 5:49 pm
I'm not familiar with NAS installations, so I was hesitant to reply. First, check the profile assigned to the TV in the Serviio console. version 1.6 includes a new J Series profile.
As far as the Java log entries, I have no knowledge about them. I've often seen what appears to be errors, but are actually normal entries.
Finally, exactly what is the problem? Does the TV not see Serviio at all? Are no videos listed? Are they listed but won't play?
The snippet of the log file you provided really tells us nothing. We need to see a complete log, preferably with debug enabled.
Post Sat Jan 30, 2016 11:05 pm
It looks like the TV uses UPnP protocol higher than 1.0 (never seen that).
Normally J series works, not sure why this one doesn't.
rkarpinski
Post Mon Feb 01, 2016 10:59 am
atc98092 wrote:I'm not familiar with NAS installations, so I was hesitant to reply. First, check the profile assigned to the TV in the Serviio console. version 1.6 includes a new J Series profile.
TV see Serviio in sources list but no videos/folder listed :-)
When I'll be at home I will enable debuging.
Post Mon Feb 01, 2016 1:18 pm
Usually when no videos are displayed in the various categories (Titles, Movies, Series, etc.), Serviio does not believe they are playable. Look in the folders view and see if anything is listed, as this view will usually show everything, playable of not. The debug log will be a great help.
rkarpinski
Post Mon Feb 01, 2016 9:02 pm
I don't know how but today it works :)
But there is another problem. Subtitles with polish diacritic signs like ą,ę,ź,ś,ć etc..
Subtitles works but shows only lines without this signs.
Maybe I have to set something special in my Serviio?
PS. If I buy PRO version there is some other support line like mail or online chat?
Post Mon Feb 01, 2016 9:10 pm
Do you use burned-in subtitles or embedded ones? If yes, either convert the subtitles (if external) to UTF-8 or set the file's character encoding in the console.
http://serviio.org/index.php?option=com ... icle&id=33
No, only the forum.
Users browsing this forum: Google [Bot] and 4 guests
