TV can't see server, despite having ports open
• Page 1 of 1
When I disable my firewall my tv can see serviio fine. I opened TCP port 8895, UDP port 1900, and port 23423 for both protocols. Are there any other ports I should open?
Re: TV can't see server, despite having ports open
zerophase wrote:When I disable my firewall my tv can see serviio fine. I opened TCP port 8895, UDP port 1900, and port 2343 for both protocols. Are there any other ports I should open?
Not sure if you made a typo there, but the primary port is 23424, and the console port is 23423. The TV needs 23424 to work. The console port is only needed to reach the console from another computer on your network.
Actually, TV only needs 1900 UDP and 8895 TCP. 23424 is for the CDS API / MediaBrowser - not DLNA.
Petr
Help translate Serviio
zip wrote:Actually, TV only needs 1900 UDP and 8895 TCP. 23424 is for the CDS API / MediaBrowser - not DLNA.
Whoops. Thanks for the correction, Zip!
Yeah, it was a typo. I'm going to try opening 23424, and see if it does anything.
These are the rules I have setup for Serviio:
On the status page it's showing a green play arrow for the TV. But, Serviio isn't showing up on the options. Just my router.
• Page 1 of 1
