Re: SeasonVar.ru (Web Resource)
ka81 wrote:sorry for being nubs, but - how to use/install plugin on OSx ?
As all other plugins, look for necessary topic in main forum. As I remember there is video in youtube as well. Good luck.
WARN [FeedUpdaterWorker] An error occured while parsing the online resource http://seasonvar.ru/serial-12470-CHernyj_spisok-3-season.html, waiting for expiry time to try again: Unexpected error while invoking plugin (SeasonVar): Lexing failed on line: 1, column: 8, while reading 'i', no possible valid JSON value or punctuation could be recognized.
org.serviio.library.online.metadata.OnlineResourceParseException: Unexpected error while invoking plugin (SeasonVar): Lexing failed on line: 1, column: 8, while reading 'i', no possible valid JSON value or punctuation could be recognized.
at org.serviio.library.online.WebResourceParser.parse(WebResourceParser.java:78)
at org.serviio.library.online.OnlineLibraryManager.findResource(OnlineLibraryManager.java:186)
at org.serviio.library.online.OnlineLibraryManager.findResourceInCacheOrParse(OnlineLibraryManager.java:203)
at org.serviio.library.online.metadata.FeedUpdaterWorker.getOnlineItems(FeedUpdaterWorker.java:191)
at org.serviio.library.online.metadata.FeedUpdaterWorker.run(FeedUpdaterWorker.java:108)
Caused by: groovy.json.JsonException: Lexing failed on line: 1, column: 8, while reading 'i', no possible valid JSON value or punctuation could be recognized.
at groovy.json.JsonLexer.nextToken(JsonLexer.java:83)
at groovy.json.JsonSlurper.parseObject(JsonSlurper.java:219)
at groovy.json.JsonSlurper.parse(JsonSlurper.java:75)
at groovy.json.JsonSlurper.parseText(JsonSlurper.java:59)
at groovy.json.JsonSlurper$parseText.call(Unknown Source)
at SeasonVar.getSourceFromPlayer(SeasonVar.groovy:123)
at SeasonVar.extractItems(SeasonVar.groovy:66)
at org.serviio.library.online.WebResourceUrlExtractor$1.executePluginMethod(WebResourceUrlExtractor.java:32)
at org.serviio.library.online.WebResourceUrlExtractor$1.executePluginMethod(WebResourceUrlExtractor.java:29)
at org.serviio.library.online.PluginExecutionProcessor$1.call(PluginExecutionProcessor.java:50)
at java.util.concurrent.FutureTask.run(FutureTask.java:266)
at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1142)
at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:617)
... 1 more2016-03-23 19:25:48,855 WARN [FeedUpdaterWorker] An error occured while parsing the online resource http://seasonvar.ru/serial-13057-CHernye_parusa-3-season.html?translation=Amedia, will try again soon: Unexpected error while invoking plugin (SeasonVar): Cannot invoke method replaceAll() on null object
org.serviio.library.online.metadata.OnlineResourceParseException: Unexpected error while invoking plugin (SeasonVar): Cannot invoke method replaceAll() on null object
Caused by: java.lang.NullPointerException: Cannot invoke method replaceAll() on null object
at org.codehaus.groovy.runtime.NullObject.invokeMethod(NullObject.java:77)
at org.codehaus.groovy.runtime.callsite.PogoMetaClassSite.call(PogoMetaClassSite.java:45)
at org.codehaus.groovy.runtime.callsite.CallSiteArray.defaultCall(CallSiteArray.java:42)
at org.codehaus.groovy.runtime.callsite.NullCallSite.call(NullCallSite.java:32)
at org.codehaus.groovy.runtime.callsite.PogoMetaClassSite.call(PogoMetaClassSite.java:54)
at org.codehaus.groovy.runtime.callsite.AbstractCallSite.call(AbstractCallSite.java:120)
at SeasonVar.fetchItems(SeasonVar.groovy:152)
at SeasonVar.this$4$fetchItems(SeasonVar.groovy)
at SeasonVar$this$4$fetchItems.callCurrent(Unknown Source)
at SeasonVar.extractItems(SeasonVar.groovy:89)
... 1 more
2016-04-16 12:57:46,450 WARN [FeedUpdaterWorker] An error occured while parsing the online resource http://seasonvar.ru/serial-12394-Skorpion_serial_2014_ndash_.html?translation=BaibaKo, waiting for expiry time to try again: Unexpected error while invoking plugin (SeasonVar): index is out of range 0..-1 (index = 0)
org.serviio.library.online.metadata.OnlineResourceParseException: Unexpected error while invoking plugin (SeasonVar): index is out of range 0..-1 (index = 0)
Caused by: java.lang.IndexOutOfBoundsException: index is out of range 0..-1 (index = 0)
at org.codehaus.groovy.runtime.DefaultGroovyMethods.getAt(DefaultGroovyMethods.java:6202)
at org.codehaus.groovy.runtime.dgm$310.invoke(Unknown Source)
at org.codehaus.groovy.runtime.callsite.PojoMetaMethodSite$PojoMetaMethodSiteNoUnwrapNoCoerce.invoke(PojoMetaMethodSite.java:271)
at org.codehaus.groovy.runtime.callsite.PojoMetaMethodSite.call(PojoMetaMethodSite.java:53)
at org.codehaus.groovy.runtime.callsite.AbstractCallSite.call(AbstractCallSite.java:116)
at SeasonVar.getPlaylistURL(SeasonVar.groovy:117)
at SeasonVar.extractItems(SeasonVar.groovy:68)
... 1 morevictor500k wrote:Добрый день,
Хочу уточнить - плагин версии 16 перестал работать частично.
Некоторые ссылки продолжают работать, а некоторые нет.
Например, pабочая ссылка: http://seasonvar.ru/serial-12470-CHerny ... eason.html.
Не рабочая ссылка: http://seasonvar.ru/serial-12394-Skorpi ... dash_.html со следующей ошибкой:
- Code:
... 1 more
ivanoff999 wrote:Добрый вечер, со вчерашнего дня перестал работать плагин ver. 16, помогите!
The plugin doesn't works, see attached serviio.log, please help!
2016-04-14 09:29:32,911 WARN [FeedUpdaterWorker] An error occured while parsing the online resource http://seasonvar.ru/serial-6246-Tajny_s ... eason.html, waiting for expiry time to try again: Unexpected error while invoking plugin (SeasonVar): index is out of range 0..-1 (index = 0)
... 1 more
urkas wrote:Спасибо большое за плагин, только столкнулся с одной проблемой:
- Code:
... 1 more
