PixStar Photo frame doesn't find Serviio
PeterBell
Post Sun Feb 07, 2016 8:31 am
Newbie alert!
I have, for some years, been using minidlna to serve photos (jpegs) to my PixStar photo frames.
I decided to have a play with serviio, but find that the photo frames simply do not offer the serviio server as a potential source of photos.
I have played with a couple of different profiles, but with no success - in any case, I'm not sure whether this is a profile problem.
Other devices (eg. Sony TV) do see the serviio server, and will display the photos.
The obvious difference is that the TV is on a wired connection while the photo frames are wi-fi only.
I do note that the Pixstar devices do not appear in the public listings of dlna-compliant devices, but they do work with minidlna.
Serviio is running in a docker container (as is minidlna) on a slackware server.
I attach a debug log - the device in question is 172.22.1.230
(92.69 KiB) Downloaded 523 times
PeterBell
Post Tue Feb 09, 2016 4:50 am
Re: PixStar Photo frame doesn't find Serviio
I have done a little more exploring, and have re-run the debug log with the device profile for the photoframe set back to generic.
I have greped the logfile for interactions with the photoframe and the same for a Sony Bravia - however, there are so many dissimilarities between the two that I don't know where to begin.
Is anyone able to identify what is going wrong with the interchange with the PixStar photo frame? If not, I guess that I would need to use a packet sniffer to compare minidlna and serviio exchanges with the photoframe.
One thought crosses my mind - would there be any problem haveing two dlna services (minidlna and serviio) running as two separate dockers on the same host server?
I attach the newer syslog, together with the grep for the photoframe messages and the grep for the TV messages.
Bravia.log
TV grep
(35.63 KiB) Downloaded 509 times
Pixstar.log
photoframe grep
(29.75 KiB) Downloaded 552 times
Full log
(121.54 KiB) Downloaded 504 times
Post Tue Feb 09, 2016 10:08 am
PeterBell wrote:One thought crosses my mind - would there be any problem having two dlna services (minidlna and serviio) running as two separate dockers on the same host server?
No.
What is your subnet size - your server is 172.22.0.100 whereas your device is on 172.22.1.230. The server and devices must be on the same subnet - so normally I would say this may be your issue, however it appears that all of your renderers are in the 172.22.1.0/24 range so on that basis nothing should work (or you have a have a larger subnet?) .
Be surprised if it makes a difference but perhaps try moving your server to 172.22.1.100 and see what happens.
PeterBell
Post Tue Feb 09, 2016 12:23 pm
I can assure you that I'm running a perfectly valid Class B subnet, within the address range reserved for private Class B nets - 172.22.0.0/12. If that weren't the case, I would have lots more problems than just this.
And, as I say, the photoframes work fine with minidlna running on the same server. I'm sure that there is some problem in the dlna discovery handshaking between PixStar on Serviio - I'm just not familiar enough (at all?) with the dlna protocols to pinpoint what is going on.
Post Tue Feb 09, 2016 12:58 pm
Yep, thought you may have been running a larger than normal (for a home network) subnet. As you say, nothing technically invalid about it, just a little unusual compared to most networks.
It may be worthwhile still checking what I suggested, if it's easily done. Admittedly, it's a long shot.
