BlueRay files not recognized
VizoMan
Post Wed Feb 10, 2016 2:52 pm
New to Serviio. Dvd files read normally in the list of movies and play. But when a blue ray file is read, multiple stream.tts files are listed under the names of the movie, each appears to be the file in the blue ray folder "stream" and with the extension m2ts. Am I missing something where it doesn't recognize the m2ts file, but then why display it as a stream.tts file? When you attempt to play on of them, it says audio not supported and does not play.
Complete name                            : D:\Temp\Movies\Last Witch Hunter\MainMovie\THE_LAST_WITCH_HUNTER\BDMV\STREAM\00501.m2ts
Format                                   : BDAV
Format/Info                              : Blu-ray Video
File size                                : 213 MiB
Duration                                 : 1mn 9s
Overall bit rate                         : 25.7 Mbps
Maximum Overall bit rate                 : 48.0 Mbps
Menu ID                                  : 1 (0x1)
Codec ID                                 : 27
Duration                                 : 1mn 9s
Maximum bit rate                         : 40.0 Mbps
Height                                   : 1 080 pixels
Frame rate                               : 23.976 (24000/1001) fps
Audio #1
Menu ID                                  : 1 (0x1)
Format                                   : DTS
Format/Info                              : Digital Theater Systems
Format profile                           : MA / Core
Mode                                     : 16
Muxing mode                              : Stream extension
Codec ID                                 : 134
Duration                                 : 1mn 9s
Bit rate mode                            : Variable / Constant
Bit rate                                 : Unknown / 1 509 Kbps
Frame rate                               : 93.750 fps (512 spf)
Bit depth                                : 24 bits
Compression mode                         : Lossless / Lossy
Audio #2
Menu ID                                  : 1 (0x1)
Format                                   : DTS
Mode                                     : 16
Codec ID                                 : 130
Duration                                 : 1mn 9s
Bit rate                                 : 755 Kbps
Bit depth                                : 24 bits
Stream size                              : 6.29 MiB (3%)
Audio #3
Menu ID                                  : 1 (0x1)
Format                                   : DTS
Mode                                     : 16
Codec ID                                 : 130
Duration                                 : 1mn 9s
Bit rate                                 : 755 Kbps
Bit depth                                : 24 bits
Text #1
Menu ID                                  : 1 (0x1)
Format                                   : PGS
Codec ID                                 : 144
Delay relative to video                  : 166ms
Text #2
Menu ID                                  : 1 (0x1)
Format                                   : PGS
Codec ID                                 : 144
Post Wed Feb 10, 2016 7:56 pm
Re: BlueRay files not recognized
What version of Serviio? What are you playing them on?
The latest Serviio version can join multiple files into a single playable movie. I have numerous M2TS Blu-Ray rips that play fine, as long as the player can either play the HD audio or select the lossy track. Often my TV cannot play one because of the audio track.
Also, how have you ripped the Blu-Ray? If all you did was copy the file from the disc, you can't play it because it is still encrypted. You have to use something to remove the encryption before you can stream them via DLNA.
Post Wed Feb 10, 2016 8:43 pm
1.6 only works with DVD structure, not BluRay (yet).
VizoMan
Post Thu Feb 11, 2016 6:08 pm
Thanks for the replies. I have converted the BlueRay files to MP4 and working normally. I had to download the latest version of FFMPEG because it was crashing on one of the MP4 files. Had to change one of the file names because it was bringing up a different movie title. But now everything appears to be working normally. Thanks.
