Linux programme and Console wont start
rawlinm
Post Fri Feb 19, 2016 11:20 pm
I get the following error starting serviio.sh;
2016-02-19 23:14:37,982 ERROR [MediaServer] An unexpected error occured. Ending the application. Message: java.net.BindException: Address already in use
java.lang.RuntimeException: java.net.BindException: Address already in use
at org.serviio.restlet.RestletServer.runServer(RestletServer.java:86)
at org.serviio.MediaServer.main(MediaServer.java:116)
Caused by: java.net.BindException: Address already in use
also there wasnt a console in the latest download, only a script trying to open a web-browser session that didn't work?
Post Fri Feb 19, 2016 11:51 pm
Re: Linux programme and Console wont start
you have something already running on port 23423 or 23424 i assume.
The console is now web based, so that is correct.
rawlinm
Post Sat Feb 20, 2016 3:25 pm
I only have serviio on that port;
root@officeserver serviio-1.6]# lsof -i:23423
COMMAND PID USER FD TYPE DEVICE SIZE/OFF NODE NAME
java 3706 root 53u IPv4 26310 0t0 TCP *:23423 (LISTEN)
if I try to use the web based control panel I see both;
[root@officeserver serviio-1.6]# /etc/serviio-1.6/bin/serviio-console.sh
(process:4638): GLib-CRITICAL **: g_slice_set_config: assertion 'sys_page_size == 0' failed
[root@officeserver serviio-1.6]# lsof -i:23423
firefox 3020 mark 51u IPv4 36012 0t0 TCP localhost.mydomain.com:38897->localhost.mydomain.com:23423 (ESTABLISHED)
but the console hangs and wont open in the browser.
phn2
Post Sun Feb 21, 2016 5:27 pm
same here; no connection...
actually the server work, just canno access it to setup folder etc. Neither linux nor windoze machines work. "connection refused".
Post Sun Feb 21, 2016 7:53 pm
post some detailed serviio logs
phn2
Post Mon Feb 22, 2016 9:44 am
2016-02-22 09:39:44,554 INFO [MediaServer] ------------------------------------------------------------------------
2016-02-22 09:39:44,559 INFO [MediaServer] Serviio DLNA media streaming server v 1.6 (rev. 9a1458ed77db)
2016-02-22 09:39:44,559 INFO [MediaServer] Petr Nejedly 2009-2015
2016-02-22 09:39:44,559 INFO [MediaServer] http://www.serviio.org
2016-02-22 09:39:44,560 INFO [MediaServer] Java 1.8.0_45-Oracle Corporation i386
2016-02-22 09:39:44,560 INFO [MediaServer] OS Linux 2.6.32-73-generic
2016-02-22 09:39:44,560 INFO [MediaServer] File encoding: US-ASCII
2016-02-22 09:39:44,562 INFO [MediaServer] Headless mode enabled: true
2016-02-22 09:39:44,562 INFO [MediaServer] User: root
2016-02-22 09:39:44,563 INFO [MediaServer] User home dir: /root
2016-02-22 09:39:44,563 INFO [MediaServer] Temp dir: /tmp
2016-02-22 09:39:44,563 INFO [MediaServer] ------------------------------------------------------------------------
2016-02-22 09:39:45,082 INFO [WebServer] Socket buffer set to 65535 bytes
2016-02-22 09:39:45,083 INFO [RestletServer] Starting Restlet server (/console) exposed on port 23423
2016-02-22 09:39:45,098 INFO [RestletServer] Starting Restlet server (/rest) exposed on port 23423
2016-02-22 09:39:45,357 INFO [RestletServer] Starting Restlet server (/cds) exposed on port 23424
2016-02-22 09:39:45,358 INFO [RestletServer] Starting Restlet server (/mediabrowser) exposed on port 23424
2016-02-22 09:39:45,412 INFO [DBSchemaUpdateExecutor] Checking if DB schema needs to be updated
2016-02-22 09:39:45,445 INFO [DatabaseManager] Using DERBY database language
2016-02-22 09:39:49,727 INFO [MediaServer] ------------------------------------------------------------------------
2016-02-22 09:39:49,728 INFO [MediaServer] License: PRO (NORMAL, id: b984ea4a-7a2d-4096-a5f6-d281243e5869)
2016-02-22 09:39:49,728 INFO [MediaServer] ------------------------------------------------------------------------
2016-02-22 09:39:50,258 INFO [Device] Created UPnP Device with UUID: b417b37c-4030-3c89-bb6e-b5e8798e235b, bound address: 192.168.2.10
2016-02-22 09:39:51,858 INFO [ProfilesDefinitionParser] Parsing Profiles definition
2016-02-22 09:39:52,185 INFO [ProfilesDefinitionParser] Added profile 'Generic DLNA profile' (id=1)
2016-02-22 09:39:52,216 INFO [ProfilesDefinitionParser] Added profile 'Samsung TV (B-series)' (id=2)
2016-02-22 09:39:52,226 INFO [ProfilesDefinitionParser] Added profile 'Xbox 360' (id=3)
2016-02-22 09:39:52,229 INFO [ProfilesDefinitionParser] Added profile 'Playstation 3' (id=4)
2016-02-22 09:39:52,233 INFO [ProfilesDefinitionParser] Added profile 'Playstation 4' (id=ps4)
2016-02-22 09:39:52,235 INFO [ProfilesDefinitionParser] Added profile 'Samsung TV (A-series)' (id=5)
2016-02-22 09:39:52,275 INFO [ProfilesDefinitionParser] Added profile 'DirecTV HD-DVR' (id=6)
2016-02-22 09:39:52,283 INFO [ProfilesDefinitionParser] Added profile 'Samsung TV / player (H-series)' (id=sam_h)
2016-02-22 09:39:52,287 INFO [ProfilesDefinitionParser] Added profile 'Samsung TV / player (J-series)' (id=sam_j)
2016-02-22 09:39:52,291 INFO [ProfilesDefinitionParser] Added profile 'Samsung TV / player (E/F-series)' (id=sam_ef)
2016-02-22 09:39:52,293 INFO [ProfilesDefinitionParser] Added profile 'Samsung TV / player (C/D-series)' (id=7)
2016-02-22 09:39:52,295 INFO [ProfilesDefinitionParser] Added profile 'LG TV / player' (id=8)
2016-02-22 09:39:52,318 INFO [ProfilesDefinitionParser] Added profile 'Sony Bravia TV (2012)' (id=sony2012)
2016-02-22 09:39:52,322 INFO [ProfilesDefinitionParser] Added profile 'Sony Bravia TV (2013/14)' (id=sony2013)
2016-02-22 09:39:52,325 INFO [ProfilesDefinitionParser] Added profile 'Sony BDP-Sx100 (2013)' (id=bdp2013)
2016-02-22 09:39:52,327 INFO [ProfilesDefinitionParser] Added profile 'Sony BDP-Sx90 (2012)' (id=bdp2012)
2016-02-22 09:39:52,333 INFO [ProfilesDefinitionParser] Added profile 'Sony BDP-Sx70/SMP-N100 (2010)' (id=bdp2010)
2016-02-22 09:39:52,335 INFO [ProfilesDefinitionParser] Added profile 'Sony BDP-Sx70/SMP-N100 (2010) - US' (id=bdp2010us)
2016-02-22 09:39:52,337 INFO [ProfilesDefinitionParser] Added profile 'Sony BDP-Sx80/SMP-N200 (2011)' (id=bdp2011)
2016-02-22 09:39:52,339 INFO [ProfilesDefinitionParser] Added profile 'Toshiba REGZA' (id=13)
2016-02-22 09:39:52,342 INFO [ProfilesDefinitionParser] Added profile 'Toshiba REGZA 2012-' (id=tosh2012)
2016-02-22 09:39:52,389 INFO [ProfilesDefinitionParser] Added profile 'WDTV Live' (id=14)
2016-02-22 09:39:52,391 INFO [ProfilesDefinitionParser] Added profile 'LaCie LaCinema Media Player' (id=15)
2016-02-22 09:39:52,394 INFO [ProfilesDefinitionParser] Added profile 'Manta WIFI Centre' (id=16)
2016-02-22 09:39:52,397 INFO [ProfilesDefinitionParser] Added profile 'Pure Flow' (id=17)
2016-02-22 09:39:52,399 INFO [ProfilesDefinitionParser] Added profile 'Sharp Aquos' (id=18)
2016-02-22 09:39:52,400 INFO [ProfilesDefinitionParser] Added profile 'Sony Bravia TV (2011)' (id=sony2011)
2016-02-22 09:39:52,403 INFO [ProfilesDefinitionParser] Added profile 'Sony Bravia TV (2010)' (id=sony2010)
2016-02-22 09:39:52,404 INFO [ProfilesDefinitionParser] Added profile 'Philips (2010-)' (id=plps2010)
2016-02-22 09:39:52,406 INFO [ProfilesDefinitionParser] Added profile 'Philips (2009)' (id=20)
2016-02-22 09:39:52,408 INFO [ProfilesDefinitionParser] Added profile 'Sony Bravia TV (2009)' (id=sony2009)
2016-02-22 09:39:52,416 INFO [ProfilesDefinitionParser] Added profile 'Denon AVR' (id=22)
2016-02-22 09:39:52,419 INFO [ProfilesDefinitionParser] Added profile 'Panasonic Viera (2013)' (id=viera2013)
2016-02-22 09:39:52,421 INFO [ProfilesDefinitionParser] Added profile 'Panasonic Viera G/GT/DT/UT/VT (2011/2012)' (id=viera2011a)
2016-02-22 09:39:52,422 INFO [ProfilesDefinitionParser] Added profile 'Panasonic Viera E/S/ST/VT (2011)' (id=viera2011)
2016-02-22 09:39:52,424 INFO [ProfilesDefinitionParser] Added profile 'Panasonic Viera (2010)' (id=viera2010)
2016-02-22 09:39:52,425 INFO [ProfilesDefinitionParser] Added profile 'Sony Bravia TV (2012) - US' (id=sony2012us)
2016-02-22 09:39:52,434 INFO [ProfilesDefinitionParser] Added profile 'Sony Bravia TV (2011) - US' (id=sony2011us)
2016-02-22 09:39:52,437 INFO [ProfilesDefinitionParser] Added profile 'Sony AVReceiver STR' (id=SonySTR)
2016-02-22 09:39:52,438 INFO [ProfilesDefinitionParser] Added profile 'Sony Audio CMT' (id=SonyCMT)
2016-02-22 09:39:52,445 INFO [ProfilesDefinitionParser] Added profile 'Vizio TV' (id=viziotv)
2016-02-22 09:39:52,448 INFO [ProfilesDefinitionParser] Added profile 'Windows 8/RT' (id=win8metro)
2016-02-22 09:39:52,450 INFO [ProfilesDefinitionParser] Added profile 'Panasonic BD player' (id=panasonicBDT220)
2016-02-22 09:39:52,451 INFO [ProfilesDefinitionParser] Added profile 'Philips NP Streamium' (id=philips_streamium)
2016-02-22 09:39:52,453 INFO [ProfilesDefinitionParser] Added profile 'Chaneru' (id=roku)
2016-02-22 09:39:52,465 INFO [ProfilesDefinitionParser] Added profile 'Roku Media Player' (id=RokuMPApp)
2016-02-22 09:39:52,466 INFO [ProfilesDefinitionParser] Added profile 'Yamaha BD-A1020/BD-A1010' (id=YamBD)
2016-02-22 09:39:52,468 INFO [ProfilesDefinitionParser] Added profile 'Telenet Yelo TV' (id=TNDC)
2016-02-22 09:39:52,478 INFO [ProfilesDefinitionParser] Added profile 'Xbox One' (id=xbox_one)
2016-02-22 09:39:52,502 INFO [ProfilesDefinitionParser] Added profile 'Raumfeld' (id=raumfeld)
2016-02-22 09:39:52,689 INFO [ProfilesDefinitionParser] Parsing Profiles definition
2016-02-22 09:39:52,692 INFO [ProfilesDefinitionParser] Added profile 'Flash player' (id=flv_player)
2016-02-22 09:39:52,695 INFO [ProfilesDefinitionParser] Added profile 'iOS' (id=ios)
2016-02-22 09:39:52,696 INFO [ProfilesDefinitionParser] Added profile 'HTML5' (id=html5)
2016-02-22 09:39:52,698 INFO [ProfilesDefinitionParser] Added profile 'ServiiGo (Standard)' (id=serviigo_standard)
2016-02-22 09:39:52,700 INFO [ProfilesDefinitionParser] Added profile 'ServiiGo (Legacy Devices)' (id=serviigo)
2016-02-22 09:39:52,702 INFO [ProfilesDefinitionParser] Added profile 'ServiiGo (HLS)' (id=serviigo_hls)
2016-02-22 09:39:52,704 INFO [ProfilesDefinitionParser] Added profile 'ServiiGo (Google TV)' (id=serviigo_gtv)
2016-02-22 09:39:52,707 INFO [ProfilesDefinitionParser] Added profile 'Google Cast' (id=googlecast)
2016-02-22 09:39:52,709 INFO [ProfilesDefinitionParser] Added profile 'Chromecast' (id=chromecast)
2016-02-22 09:39:52,712 INFO [ProfilesDefinitionParser] Added profile 'Windows Phone 8' (id=wp8)
2016-02-22 09:39:52,928 INFO [PluginCompilerThread] Looking for plugins at /home/pc5dczcbl5yt-1.6/plugins
2016-02-22 09:39:52,933 INFO [PluginCompilerThread] Started looking for plugins
2016-02-22 09:39:52,947 INFO [UpdateChecker] Checking if a new version is available
2016-02-22 09:39:53,291 INFO [FFMPEGWrapper] Found FFmpeg: ffmpeg version 0.10.12-7:0.10.12-1~lucid1 Copyright (c) 2000-2014 the FFmpeg developers
2016-02-22 09:39:53,291 WARN [FFMPEGWrapper] FFmpeg is not compiled with librtmp support, RTMP streaming will not work.
2016-02-22 09:39:53,292 WARN [FFMPEGWrapper] FFmpeg is not compiled with libass support, rendering subtitles (hardsubs) will not work.
2016-02-22 09:39:53,597 ERROR [ProcessExecutor] Fatal error in process starting: Cannot run program "dcraw": error=2, No such file or directory
java.io.IOException: Cannot run program "dcraw": error=2, No such file or directory
at java.lang.ProcessBuilder.start(ProcessBuilder.java:1048)
at org.serviio.external.ProcessExecutor.run(ProcessExecutor.java:136)
Caused by: java.io.IOException: error=2, No such file or directory
at java.lang.UNIXProcess.forkAndExec(Native Method)
at java.lang.UNIXProcess.<init>(UNIXProcess.java:248)
at java.lang.ProcessImpl.start(ProcessImpl.java:134)
at java.lang.ProcessBuilder.start(ProcessBuilder.java:1029)
... 1 more
2016-02-22 09:39:53,606 WARN [MediaServer] DCRAW not found. Support for raw image files will be missing.
2016-02-22 09:39:53,690 INFO [AbstractAVTranscodingDeliveryEngine] Cleaning transcode engine and its data
2016-02-22 09:39:53,848 INFO [Device] Updated bound IP address of Device with UUID: b417b37c-4030-3c89-bb6e-b5e8798e235b, bound address: 192.168.2.10
2016-02-22 09:39:53,853 INFO [WebServer] WebServer starting on port 8895
2016-02-22 09:39:53,878 INFO [EventSubscriptionExpirationChecker] Starting EventSubscriptionExpirationChecker
2016-02-22 09:39:53,880 INFO [EventDispatcher] Starting EventDispatcher
2016-02-22 09:39:53,881 INFO [DiscoveryAdvertisementNotifier] Starting DiscoveryAdvertisementNotifier
2016-02-22 09:39:53,907 INFO [DiscoverySSDPMessageListener] Starting DiscoverySSDPMessageListener using interface eth0 (eth0) and address 192.168.2.10, timeout = 0
2016-02-22 09:39:53,911 INFO [RendererExpirationChecker] Starting RendererExpirationChecker
2016-02-22 09:39:53,912 INFO [RendererSearchSender] Searching for Renderer devices
2016-02-22 09:40:20,029 INFO [FeedUpdaterWorker] Started looking for information about online resources
2016-02-22 09:40:20,153 INFO [FileDeltaWatcher] Using 'sun.nio.fs.LinuxWatchService' for delta scan
2016-02-22 09:40:20,193 INFO [RepositoriesStatusCoordinator$RepositoriesStatusThread] Started checking repositories status
2016-02-22 09:40:20,266 INFO [LocalLibraryManager] Starting automatic library scan
2016-02-22 09:40:21,003 INFO [SearchManager] Starting up search engine
2016-02-22 09:40:22,833 INFO [LibraryDeltaScanner] Added repository '/media/MUSIK' to delta scanner (NATIVE)
2016-02-22 09:40:23,899 INFO [LibraryDeltaScanner] Added repository '/media/FOTO' to delta scanner (NATIVE)
2016-02-22 09:40:23,957 INFO [LibraryDeltaScanner] Added repository '/media/Video' to delta scanner (NATIVE)
2016-02-22 09:40:23,957 INFO [LibraryDeltaScanner] Starting the library delta scan
2016-02-22 09:40:23,983 INFO [PlaylistMaintainerWorker] Started looking for playlist changes
2016-02-22 09:40:24,440 INFO [ContentDirectoryDefinitionParser] Parsing ContentDirectory definition
2016-02-22 09:40:44,810 WARN [MetadataExtractionCoordinator] Skipping processing metadata for an unsupported file (/media/MUSIK/Green Day/1,039-Smoothed Out Slappy Hours/08 - Road to Acceptance.flac.tmp.flac). Message: Unknown audio file type.
2016-02-22 09:40:47,319 WARN [MetadataExtractionCoordinator] Skipping processing metadata for an unsupported file (/media/MUSIK/TheWeeknd/Thursday/__MACOSX/._08 Rolling Stone.mp3). Message: org.jaudiotagger.audio.exceptions.InvalidAudioFrameException: No audio header found within ._08 Rolling Stone.mp3
2016-02-22 09:40:47,452 WARN [MetadataExtractionCoordinator] Skipping processing metadata for an unsupported file (/media/MUSIK/TheWeeknd/Thursday/__MACOSX/._07 Gone.mp3). Message: org.jaudiotagger.audio.exceptions.InvalidAudioFrameException: No audio header found within ._07 Gone.mp3
2016-02-22 09:40:47,463 WARN [MetadataExtractionCoordinator] Skipping processing metadata for an unsupported file (/media/MUSIK/TheWeeknd/Thursday/__MACOSX/._05 The Birds Part 1.mp3). Message: org.jaudiotagger.audio.exceptions.InvalidAudioFrameException: No audio header found within ._05 The Birds Part 1.mp3
2016-02-22 09:40:47,467 WARN [MetadataExtractionCoordinator] Skipping processing metadata for an unsupported file (/media/MUSIK/TheWeeknd/Thursday/__MACOSX/._06 The Birds Part 2.mp3). Message: org.jaudiotagger.audio.exceptions.InvalidAudioFrameException: No audio header found within ._06 The Birds Part 2.mp3
2016-02-22 09:40:47,470 WARN [MetadataExtractionCoordinator] Skipping processing metadata for an unsupported file (/media/MUSIK/TheWeeknd/Thursday/__MACOSX/._09 Heaven Or Las Vegas.mp3). Message: org.jaudiotagger.audio.exceptions.InvalidAudioFrameException: No audio header found within ._09 Heaven Or Las Vegas.mp3
2016-02-22 09:40:47,506 WARN [MetadataExtractionCoordinator] Skipping processing metadata for an unsupported file (/media/MUSIK/TheWeeknd/Thursday/__MACOSX/._02 Life Of The Party.mp3). Message: org.jaudiotagger.audio.exceptions.InvalidAudioFrameException: No audio header found within ._02 Life Of The Party.mp3
2016-02-22 09:40:47,510 WARN [MetadataExtractionCoordinator] Skipping processing metadata for an unsupported file (/media/MUSIK/TheWeeknd/Thursday/__MACOSX/._03 Thursday.mp3). Message: org.jaudiotagger.audio.exceptions.InvalidAudioFrameException: No audio header found within ._03 Thursday.mp3
2016-02-22 09:40:47,513 WARN [MetadataExtractionCoordinator] Skipping processing metadata for an unsupported file (/media/MUSIK/TheWeeknd/Thursday/__MACOSX/._04 The Zone.mp3). Message: org.jaudiotagger.audio.exceptions.InvalidAudioFrameException: No audio header found within ._04 The Zone.mp3
phn2
2016-02-22 09:39:52,928 INFO [PluginCompilerThread] Looking for plugins at /home/serviio-1.6/plugins
... 1 more
phn2
Post Mon Feb 22, 2016 9:47 am
I've copied my my config file from 1.5.2 to 1.6 and the server works fine serving files. Just cant access the console....
And I can access webmin on 12321 on the servermachine....
Post Mon Feb 22, 2016 7:09 pm
All looking good. Make sure that port 23423 is opn in the server's firewall.
phn2
Post Sun Apr 24, 2016 2:43 pm
As of 1.6.1 console now works as intended...
Users browsing this forum: No registered users and 59 guests
