Subtitle files and Hisense TV
kanoun
Post Sat Jan 09, 2016 6:31 pm
Hello everyone,
I use Serviio to stream from my PC to my smart Tv (Hisense K321 55) Everything works perfectly fine but i tried to add subtitle files to some movies, i did all the settings correctly but after adding the subtitle file the movie won't play at all
If i remove the subtitle file the movie works just fine
Is there anyway that i can solve this issue, i tried everything that i know but nothing worked out
Note that the files i use are working fine on my PC
Thank you in advance :)
Sharbel
kanoun
Post Mon Feb 01, 2016 8:31 am
Re: Subtitle files and Hisense TV
Anyone has a solution to the subtitle problem :?: :cry:
Post Mon Feb 01, 2016 8:55 am
What profile are you using for the TV?
What are your settings on your Delivery, Subtitles tab on Serviio console?
kanoun
Post Mon Feb 01, 2016 10:19 am
I was using UTF-8 in the subtitle delivery but the movie would never play on TV unless i disable the subtitle
kanoun
Post Mon Feb 01, 2016 10:20 am
Now i only have the subtitle enable tab checked, that's the only way the video file is playing on TV
Post Mon Feb 01, 2016 1:51 pm
Probably the TV doesn't support soft subs, so you'll have to enable Hardsubs in the console. That will invoke transcoding.. which looks like the TV has problems with.
kanoun
Post Mon Feb 01, 2016 9:24 pm
How do i enable the hardsubs?
Post Tue Feb 02, 2016 6:34 pm
in the console, it's called burned-in subtitles
kanoun
Post Fri Feb 19, 2016 8:02 pm
I can't get it to work, is there any tutorial?
Post Sat Feb 20, 2016 7:51 pm
Users browsing this forum: Baidu [Spider], Google [Bot] and 42 guests
