Secunia PSI alert for v1.6
Tim9898
Post Wed Feb 24, 2016 4:52 pm
I recently upgraded to Servio 1.6. Not having any problems, but my latest Secunia PSI scan reports a minor security issue with the file,
C:\Program Files\Serviio\console\node.dll
From Secunia about the issue: https://secunia.com/advisories/68950
From nodejs.org about the issue: https://nodejs.org/en/
Any suggestions how to deal with this?
Thank you
Post Wed Feb 24, 2016 5:44 pm
Re: Secunia PSI alert for v1.6
The wbe console uses a wrapper that makes the web page an executable. It's based on NodeJS AFAIK, but Serviio itself doesn''t use any nodeJS functionality. You can
- live with it
- install without the console and go to http://localhost:23423/console instead
- try to delete the dll file, but not sure if it'll still work
Tim9898
Post Thu Feb 25, 2016 5:32 pm
Thank you,
I tried "- install without the console and go to http://localhost:23423/console instead"
That got rid of the Secunia warning.
Launching the console from the start menu still works.
(System is Win 10 x64)
