1.6 Has suddenly stopped updating Audio files
gbscobel
Post Sat Feb 27, 2016 2:06 pm
Upgraded to 1.6 early this week, seemed to build my database just fine, took a long time to update artwork but that finally finished, I have a large database of over 60,000 mp3's. Since that artwork update finished, I have added several new mp3 files into my music folder but the database will not update with the new files and won't seem to update changed information, even if I run a Force refresh. In 1.5, when I added a new file or changed a file in my music folder, the change would be nearly instant, should it be taking this much longer in 1.6 to scan my database for changes? If I add new files to my video folder, including mp3 files, it seems to work okay and update quickly (there are not a lot of files in my video folder). I really just got the artwork to fully update yesterday evening, is it possible serviio is still trying to index my large database of music, after which it will update more quickly or is it possible something else is going on?
Post Sat Feb 27, 2016 8:06 pm
Re: 1.6 Has suddenly stopped updating Audio files
you need to check your log file to see what it's doing and if there are any errors adding the new files.
gbscobel
Post Sat Feb 27, 2016 10:06 pm
It actually looks like it is adding them but I have Keep library automatically refreshed and it seems to take forever to do the refresh, what is the interval it uses between refreshes and is there any way to increase it? By the way, where are the log files stored?
Post Sun Feb 28, 2016 12:05 am
files are added immediately when detected.. there is no time-based refresh anymore.
http://wiki.serviio.org/doku.php?id=lib ... _mechanism
Logs are here: http://wiki.serviio.org/doku.php?id=detail_logging
