Problem with enabling an onlince source stream
Thrasher
Post Sat Feb 06, 2016 3:22 pm
Hello all,
I've added an online source as live stream within serviio. Checking the stream via serviio was successful, but despite having the serviio server running it still won't enable a stream to watch on any one my client devices for this online source. I can watch the online source directly via VLC, below you find the output of the "C:\Program Files\Serviio\lib>ffmpeg -i" command:
configuration: --enable-static --disable-shared --disable-ffplay --disable-ffserver --enable-memalign-hack --enable-libmp3lame --enable-libass --enable-librtmp --enable-fontconfig --enable-libfreetype --enable-zlib --enable-libx264 --enable-libspeex --extra-libs='-lrtmp -lpolarssl -lws2_32 -lwinmm -lexpat -lfreetype -lfribidi -lz' --arch=x86 --enable-runtime-cpudetect --enable-pthreads --target-os=mingw32 --cross-prefix=i686-w64-mingw32- --enable-gpl --pkg-config=pkg-config
libavutil 54. 14.100 / 54. 14.100
libavcodec 56. 12.101 / 56. 12.101
libavformat 56. 14.100 / 56. 14.100
libavdevice 56. 3.100 / 56. 3.100
libavfilter 5. 2.103 / 5. 2.103
libswscale 3. 1.101 / 3. 1.101
libswresample 1. 1.100 / 1. 1.100
libpostproc 53. 3.100 / 53. 3.100
[h264 @ 01F53600] non-existing PPS 0 referenced
Last message repeated 1 times
[h264 @ 01F53600] decode_slice_header error
[h264 @ 01F53600] no frame!
Input #0, mpegts, from 'http://efef:erafAJIJ1313-a-__EEUH312@efef.dyndns.org:8099':
Duration: N/A, start: 76874.785744, bitrate: 130 kb/s
Program 1
Stream #0:0[0x44](???): Audio: aac (LC) ([15][0][0][0] / 0x000F), 44100 Hz, stereo, fltp, 130 kb/s
Stream #0:1[0x45]: Video: h264 (High) ([27][0][0][0] / 0x001B), yuv420p, 1280x720 [SAR 1:1 DAR 16:9], 50 fps, 50 tbr, 90k tbn, 100 tbc
Any help would be highly appreciated! I got this to work in the past already but just had to format my PC today and now I can't think of a solution :/.
Thrasher
Post Sat Feb 06, 2016 3:49 pm
Re: Problem with enabling an onlince source stream
I've just got the problem solved myself. I've exchanged the ffmpeg.exe with the most recent one from http://ffmpeg.zeranoe.com/builds/ and now it works.
ciccio
Post Sun Feb 28, 2016 11:57 am
Thrasher wrote:I've just got the problem solved myself. I've exchanged the ffmpeg.exe with the most recent one from http://ffmpeg.zeranoe.com/builds/ and now it works.
I've a similar issue running Serviio on a Fedora 23 x86_64 machine: Web resources are not detected by any of my DLNA renderers.
The check stream URL on Serviio console is ok; here is the output of a ffmpeg -i command:
ffmpeg version 2.8.6 Copyright (c) 2000-2016 the FFmpeg developers
built with gcc 5.1.1 (GCC) 20150618 (Red Hat 5.1.1-4)
configuration: --prefix=/usr --bindir=/usr/bin --datadir=/usr/share/ffmpeg --incdir=/usr/include/ffmpeg --libdir=/usr/lib64 --mandir=/usr/share/man --arch=x86_64 --optflags='-O2 -g -pipe -Wall -Werror=format-security -Wp,-D_FORTIFY_SOURCE=2 -fexceptions -fstack-protector-strong --param=ssp-buffer-size=4 -grecord-gcc-switches -specs=/usr/lib/rpm/redhat/redhat-hardened-cc1 -m64 -mtune=generic' --enable-bzlib --disable-crystalhd --enable-frei0r --enable-gnutls --enable-ladspa --enable-libass --enable-libcdio --enable-libdc1394 --disable-indev=jack --enable-libfreetype --enable-libgsm --enable-libmp3lame --enable-openal --enable-libopencv --enable-libopenjpeg --enable-libopus --enable-libpulse --enable-libschroedinger --enable-libsoxr --enable-libspeex --enable-libtheora --enable-libvorbis --enable-libv4l2 --enable-libvpx --enable-libx264 --enable-libx265 --enable-libxvid --enable-x11grab --enable-avfilter --enable-avresample --enable-postproc --enable-pthreads --disable-static --enable-shared --enable-gpl --disable-debug --disable-stripping --shlibdir=/usr/lib64 --enable-runtime-cpudetect
libavutil 54. 31.100 / 54. 31.100
libavcodec 56. 60.100 / 56. 60.100
libavformat 56. 40.101 / 56. 40.101
libavdevice 56. 4.100 / 56. 4.100
libavfilter 5. 40.101 / 5. 40.101
libavresample 2. 1. 0 / 2. 1. 0
libswresample 1. 2.101 / 1. 2.101
Input #0, flv, from 'http://s02.zerocdn.to/dl/b399201c0581285a275ecd0f826d1d21/56d2f33d/ff3b9a375047907f0abd56c100dd9b93d0.flv?client=FLASH':
metadatacreator : Yet Another Metadata Injector for FLV - Version 1.9
hasKeyframes : true
hasVideo : true
hasAudio : true
hasMetadata : true
canSeekToEnd : true
datasize : 190698915
videosize : 139046305
audiosize : 50978190
lasttimestamp : 2477
lastkeyframetimestamp: 2477
lastkeyframelocation: 190710560
Duration: 00:41:16.96, start: 0.043000, bitrate: 615 kb/s
Stream #0:0: Video: h264 (High), yuv420p, 900x504 [SAR 504:505 DAR 180:101], 446 kb/s, 25 fps, 25 tbr, 1k tbn, 50 tbc
Stream #0:1: Audio: aac (LC), 44100 Hz, stereo, fltp, 160 kb/s
Any hints?
Thank you in advance for your time
Post Sun Feb 28, 2016 8:09 pm
You might need to add transcoding of flv (online) to your profile. Which one are you using?
ciccio
Post Mon Feb 29, 2016 7:29 pm
zip wrote:You might need to add transcoding of flv (online) to your profile. Which one are you using?
I'm using "Generic DLNA Device"; my devices are:
- XTreamer Sidewinder 2
- Kodi on a Zenpad tablet
Post Tue Mar 01, 2016 12:19 pm
That looks fine, transcoding is there for the profile. Are you saying these are not there even when you browse on the TV? Do they exist in MediaBrowser?
ciccio
Post Tue Mar 01, 2016 6:06 pm
zip wrote:That looks fine, transcoding is there for the profile. Are you saying these are not there even when you browse on the TV? Do they exist in MediaBrowser?
Your understanding is correct: online streams show up and play nicely in MediaBrowser but they are not even listed when I access serviio from a DLNA client.
As an additional info, the same online stream once saved on the serviio server disc are listed and played on my clients..
I hope this can help to clarify the issue.
ciccio
Post Thu Mar 10, 2016 9:17 pm
Hi Zip,
really no clue to solve this?
Regards
Users browsing this forum: No registered users and 70 guests
