Help- Client freezes at certain videos at specific points.
ami289
Post Mon Feb 29, 2016 6:26 pm
Hey guys,
I'm having a weird issue for a while now, for several Serviio versions.
As I'm not a native English speaker, I'll do my best to be clear enough,
but if more explanation, or rephrasing is required / needed - just ask.
I have ceratin video files, which at specific points, causes my client to freeze.
It happens with about 5 videos.
Some get stuck after several minutes (3-4), and some after more extend period of time (more than an hour),
But each video always get stuck at the same point.
I only play MKVs, and have total of about 30-40 videos files that, besides the ones in question, plays fine.
When playing the same video files on my PC, using VLC Player, they play just fine,
And if I'm manually skip the freezing-point, the rest of the video plays fine.
I only have 1 client, so other than knowing that the client is freezing, and pc runs videos fine, I have no other frame of refference.
I did notice one strange thing though.
In one of the videos that the freeze occurs, there is a 'sync gap' (not really sure how to call it),
That is, if for instance I know that the part that is about to make my client freeze is about the occur, I forward the video 1 minute using my client's remote.
The timeline shows as it has only skipped one minute, but knowing the movie, I can clearly see that it had skipped more around 4 minutes.
It only happens around the time that the video freezes,
The rest of the timeline / forwarding works just fine.
It is like something around that point in the video file is 'confusing' Serviio / my client, which, eventually, causes the client to completely freeze.
I haven't investigated yet if this also occurs with the other videos, so I can't say for sure its a specific issue with only one of the videos, or it is something they all have in common.
I've tried looking at those videos specs, and compare them to any of the other 30 videos that works fine, but they're all seem pretty much the same.
I've tried peeking at the Serviio logs, but couldn't find anything with the timestamp of the freeze (I have my logs level set to DEBUG).
Those videos causing my client to completely freeze, and the only way around it is to restart the client.
Any suggestions on how I can debug this?
Post Mon Feb 29, 2016 8:41 pm
Re: Help- Client freezes at certain videos at specific point
Please post MediaInfo details (see signature) for a couple of files that freeze, and one that doesn't. Also, what device are you playing them on (and what profile).
Post Tue Mar 01, 2016 1:41 pm
Also, what client is it that is freezing playback? I had a Sony Blu Ray player that did that, while everything else could play with no problems.
ami289
Post Tue Mar 01, 2016 6:41 pm
Appreciate the replies guys.
My cables company is also my ISP,
So the device is a mixed device that serves as both my internet router, and cable receiver.
As part of its TV digital interface, it has the capabilities of DLNA client.
Here are some MediaInfo logs for working and freezing videos.
The following is for a freezing video.
It freezes after about an hour and 15 minutes-
Unique ID                                : 227800756123905686885156235082547594597 (0xAB60D46AF9972D289F4B85CDB3280565)
Complete name                            : G:\Harry.Potter.Complete.Story.Collection.BluRay.x264-ArenaBG\2005.And.The.Goblet.Of.Fire.2005.1080p.BluRay.DTS.x264-hV\Harry.Potter.And.The.Goblet.Of.Fire.2005.1080p.BluRay.DTS.x264-hV.mkv
Format version                           : Version 1
File size                                : 12.3 GiB
Duration                                 : 2h 37mn
Overall bit rate                         : 11.2 Mbps
Encoded date                             : UTC 2007-12-16 16:04:34
Writing application                      : mkvmerge v2.1.0 ('Another Place To Fall') built on Aug 19 2007 13:40:07
Writing library                          : libebml v0.7.7 + libmatroska v0.8.1
Format profile                           : High@L5.1
Format settings, ReFrames                : 8 frames
Duration                                 : 2h 37mn
Bit rate                                 : 9 715 Kbps
Height                                   : 800 pixels
Display aspect ratio                     : 2.40:1
Bits/(Pixel*Frame)                       : 0.264
Stream size                              : 10.4 GiB (85%)
Writing library                          : x264 core 57 svn-709C
Encoding settings                        : cabac=1 / ref=5 / deblock=1:0:0 / analyse=0x3:0x133 / me=umh / fpel_cmp=sad / subme=6 / me-prepass=0 / brdo=0 / mixed_ref=1 / me_range=16 / chroma_me=1 / trellis=1 / 8x8dct=1 / cqm=2 / deadzone=4,6 / chroma_qp_offset=0 / threads=3 / nr=0 / decimate=1 / mbaff=0 / bframes=3 / b_pyramid=1 / b_adapt=1 / b_bias=0 / direct=3 / wpredb=1 / bime=1 / keyint=250 / keyint_min=25 / scenecut=40(pre) / rc=2pass / bitrate=9715 / ratetol=1.0 / rceq='blurCplx^(1-qComp)' / qcomp=0.60 / qpmin=10 / qpmax=51 / qpstep=4 / cplxblur=20.0 / qblur=0.5 / ip_ratio=1.40 / pb_ratio=1.30 / zones=210814,225983,b=0.15 / aq=1:0.3:15.0
Format                                   : DTS
Format/Info                              : Digital Theater Systems
Mode                                     : 16
Codec ID                                 : A_DTS
Duration                                 : 2h 37mn
Bit rate                                 : 1 510 Kbps
Bit depth                                : 24 bits
Stream size                              : 1.66 GiB (13%)
Text
Format                                   : UTF-8
Codec ID                                 : S_TEXT/UTF8
Codec ID/Info                            : UTF-8 Plain Text
The following is for a working video, with similair specs to the above-
Unique ID                                : 247953218042371394388725169582245659168 (0xBA8A0D80990F341EA547AD39D07BC220)
Complete name                            : G:\Harry.Potter.Complete.Story.Collection.BluRay.x264-ArenaBG\2004.And.The.Prisoner.Of.Azkaban.2004.1080p.BluRay.DTS.x264-hV\Harry.Potter.And.The.Prisoner.Of.Azkaban.2004.1080p.BluRay.DTS.x264-hV.mkv
Duration                                 : 2h 21mn
Overall bit rate                         : 12.4 Mbps
Encoded date                             : UTC 2007-12-12 22:42:27
Duration                                 : 2h 21mn
Bit rate                                 : 10.9 Mbps
Height                                   : 800 pixels
Bits/(Pixel*Frame)                       : 0.297
Stream size                              : 10.6 GiB (86%)
Encoding settings                        : cabac=1 / ref=5 / deblock=1:0:0 / analyse=0x3:0x133 / me=umh / fpel_cmp=sad / subme=6 / me-prepass=0 / brdo=0 / mixed_ref=1 / me_range=16 / chroma_me=1 / trellis=1 / 8x8dct=1 / cqm=2 / deadzone=4,6 / chroma_qp_offset=0 / threads=3 / nr=0 / decimate=1 / mbaff=0 / bframes=3 / b_pyramid=1 / b_adapt=1 / b_bias=0 / direct=3 / wpredb=1 / bime=1 / keyint=250 / keyint_min=25 / scenecut=40(pre) / rc=2pass / bitrate=10934 / ratetol=1.0 / rceq='blurCplx^(1-qComp)' / qcomp=0.60 / qpmin=10 / qpmax=51 / qpstep=4 / cplxblur=20.0 / qblur=0.5 / ip_ratio=1.40 / pb_ratio=1.30 / aq=1:0.3:15.0
Format                                   : DTS
Mode                                     : 16
Codec ID                                 : A_DTS
Duration                                 : 2h 21mn
Bit depth                                : 24 bits
Stream size                              : 1.49 GiB (12%)
Text
Format                                   : UTF-8
The following is a freezing video, with different specs from the above 2.
It freezes about after 3 minutes of playback-
Unique ID                                : 181764137742773258118558768286094009249 (0x88BE7FE3C8A014A8AA7171990EBB23A1)
Complete name                            : K:\Movies\Victor.Frankenstein.2015.1080p.BluRay.x264-GECKOS\Victor.Frankenstein.2015.1080p.BluRay.x264-GECKOS.mkv
Format version                           : Version 4 / Version 2
File size                                : 7.94 GiB
Duration                                 : 1h 49mn
Overall bit rate                         : 10.3 Mbps
Encoded date                             : UTC 2016-02-25 20:52:28
Writing application                      : mkvmerge v8.3.0 ('Over the Horizon') 64bit
Writing library                          : libebml v1.3.1 + libmatroska v1.4.2
DURATION                                 : 01:49:49.878000000
NUMBER_OF_FRAMES                         : 617801
NUMBER_OF_BYTES                          : 1243015612
_STATISTICS_WRITING_APP                  : mkvmerge v8.3.0 ('Over the Horizon') 64bit
_STATISTICS_WRITING_DATE_UTC             : 2016-02-25 20:52:28
_STATISTICS_TAGS                         : BPS DURATION NUMBER_OF_FRAMES NUMBER_OF_BYTES
Format settings, ReFrames                : 5 frames
Duration                                 : 1h 49mn
Bit rate                                 : 8 846 Kbps
Height                                   : 808 pixels
Bits/(Pixel*Frame)                       : 0.238
Stream size                              : 6.62 GiB (83%)
Writing library                          : x264 core 148 r2665 a01e339
Encoding settings                        : cabac=1 / ref=5 / deblock=1:0:0 / analyse=0x3:0x133 / me=umh / subme=7 / psy=1 / psy_rd=1.00:0.00 / mixed_ref=1 / me_range=16 / chroma_me=1 / trellis=1 / 8x8dct=1 / cqm=0 / deadzone=21,11 / fast_pskip=0 / chroma_qp_offset=-2 / threads=18 / lookahead_threads=3 / sliced_threads=0 / nr=0 / decimate=1 / interlaced=0 / bluray_compat=0 / constrained_intra=0 / bframes=3 / b_pyramid=2 / b_adapt=1 / b_bias=0 / direct=1 / weightb=1 / open_gop=0 / weightp=2 / keyint=250 / keyint_min=23 / scenecut=40 / intra_refresh=0 / rc_lookahead=40 / rc=2pass / mbtree=1 / bitrate=8846 / ratetol=1.0 / qcomp=0.60 / qpmin=0 / qpmax=69 / qpstep=4 / cplxblur=20.0 / qblur=0.5 / ip_ratio=1.40 / aq=1:1.00
DURATION                                 : 01:49:49.844000000
NUMBER_OF_FRAMES                         : 157998
NUMBER_OF_BYTES                          : 7280303492
Format                                   : DTS
Format profile                           : ES
Mode                                     : 16
Codec ID                                 : A_DTS
Duration                                 : 1h 49mn
Bit rate                                 : 1 509 Kbps
Bit depth                                : 24 bits
Stream size                              : 1.16 GiB (15%)
Menu
00:00:00.000                             : en:00:00:00.000
00:04:07.372                             : en:00:04:07.372
00:08:06.903                             : en:00:08:06.903
00:11:14.674                             : en:00:11:14.674
00:15:20.378                             : en:00:15:20.378
00:18:58.554                             : en:00:18:58.554
00:22:27.263                             : en:00:22:27.263
00:26:06.857                             : en:00:26:06.857
00:28:59.237                             : en:00:28:59.237
00:32:02.379                             : en:00:32:02.379
00:36:01.451                             : en:00:36:01.451
00:41:11.427                             : en:00:41:11.427
00:46:17.692                             : en:00:46:17.692
00:51:48.480                             : en:00:51:48.480
00:56:42.691                             : en:00:56:42.691
00:59:55.509                             : en:00:59:55.509
01:02:37.587                             : en:01:02:37.587
01:06:57.180                             : en:01:06:57.180
01:11:25.198                             : en:01:11:25.198
01:15:14.051                             : en:01:15:14.051
01:18:10.352                             : en:01:18:10.352
01:21:06.278                             : en:01:21:06.278
01:25:20.490                             : en:01:25:20.490
01:28:17.542                             : en:01:28:17.542
01:33:35.276                             : en:01:33:35.276
01:37:51.783                             : en:01:37:51.783
01:41:32.920                             : en:01:41:32.920
01:43:34.375                             : en:01:43:34.375
And here is another working with similair specs to the above-
Unique ID                                : 253002542877978733092739485885752840482 (0xBE56846FF7901908919C39ECB2C69122)
Complete name                            : K:\Movies\Terminator.Genisys.2015.1080p.BluRay.x264-SPARKS\Terminator.Genisys.2015.1080p.BluRay.x264-SPARKS.mkv
File size                                : 8.74 GiB
Duration                                 : 2h 5mn
Overall bit rate                         : 9 957 Kbps
Encoded date                             : UTC 2015-09-25 06:07:43
DURATION                                 : 02:05:43.008000000
NUMBER_OF_FRAMES                         : 235719
NUMBER_OF_BYTES                          : 603440640
_STATISTICS_WRITING_DATE_UTC             : 2015-09-25 06:07:43
Duration                                 : 2h 5mn
Bit rate                                 : 9 318 Kbps
Height                                   : 808 pixels
Bits/(Pixel*Frame)                       : 0.251
Stream size                              : 8.01 GiB (92%)
Writing library                          : x264 core 148 r2597 e86f3a1
Encoding settings                        : cabac=1 / ref=5 / deblock=1:0:0 / analyse=0x3:0x133 / me=umh / subme=7 / psy=1 / psy_rd=1.00:0.00 / mixed_ref=1 / me_range=16 / chroma_me=1 / trellis=1 / 8x8dct=1 / cqm=0 / deadzone=21,11 / fast_pskip=0 / chroma_qp_offset=-2 / threads=25 / lookahead_threads=4 / sliced_threads=0 / nr=0 / decimate=1 / interlaced=0 / bluray_compat=0 / constrained_intra=0 / bframes=3 / b_pyramid=2 / b_adapt=1 / b_bias=0 / direct=1 / weightb=1 / open_gop=0 / weightp=2 / keyint=250 / keyint_min=23 / scenecut=40 / intra_refresh=0 / rc_lookahead=40 / rc=2pass / mbtree=1 / bitrate=9318 / ratetol=1.0 / qcomp=0.60 / qpmin=0 / qpmax=69 / qpstep=4 / cplxblur=20.0 / qblur=0.5 / ip_ratio=1.40 / aq=1:1.00
DURATION                                 : 02:05:43.006000000
NUMBER_OF_FRAMES                         : 180851
NUMBER_OF_BYTES                          : 8783127059
Duration                                 : 2h 5mn
Bit rate                                 : 640 Kbps
Stream size                              : 575 MiB (6%)
Menu
00:07:40.335                             : en:00:07:40.335
00:14:20.735                             : en:00:14:20.735
00:20:31.564                             : en:00:20:31.564
00:27:48.417                             : en:00:27:48.417
00:34:54.801                             : en:00:34:54.801
00:41:02.627                             : en:00:41:02.627
00:46:28.786                             : en:00:46:28.786
00:53:05.516                             : en:00:53:05.516
01:01:00.240                             : en:01:01:00.240
01:08:22.557                             : en:01:08:22.557
01:14:43.813                             : en:01:14:43.813
01:21:31.261                             : en:01:21:31.261
01:31:01.706                             : en:01:31:01.706
01:38:42.750                             : en:01:38:42.750
01:45:41.085                             : en:01:45:41.085
01:52:48.971                             : en:01:52:48.971
01:58:00.115                             : en:01:58:00.115
I don't believe it is related to the video's codec / encoding,
Because, as you can see from the above logs, Videos with similar encoding behaves differently.
And as I've mentioned, I don't have any other DLNA to check it on, as a refference.
Any suggestions on debugging it guys?
Post Tue Mar 01, 2016 8:46 pm
What profile is being used by Serviio for that device?
Check that you have sufficient space on the drive where your temporary transcoded folder is (as listed on the Delivery, Transcoding) tab in Serviio console.
ami289
Post Tue Mar 01, 2016 9:42 pm
Oh, sorry,
forgot to mention it....
I use Serviio's default profile,
And currently I don't use transcoding at all.
Although, in the past I have used transcoding,
And in the Harry Potter movie that is freezing (the one in the first MediaInfo log I've posted) the movie would get stuck around the same point (about 10 seconds earlier than the point it would get stuck in, without transcoding),
I haven't checked transcoding with the other movies but, as it didn't made much of a difference as with the Harry Potter movie, I guess the result would be the same.
I have around 50GB free.
Post Wed Mar 02, 2016 7:11 am
Scratching my head.....
Thinking out loud: the fact that its not being transcoded suggests that its either in the encoding of the file (there are so many parameters that it could be...) or perhaps at the point of freezing the bit rate jumps to the point your device or network cannot handle. I don't think the issue is with Serviio (have you tried another DLNA server, eg. Windows Media Server, or even playing the file via USB if your device has that capability?).
Perhaps try remuxing the video - this often fixes any issues with the container. Use the command:
    ffmpeg -i "sourcefile.mkv" -c copy -map 0 "temp.mkv"
and see the resultant file plays any better.
For the bit rate test, enable transcoding and set the profile for the device to DirecTV HD-DVR. This profile transcodes all MKV files, and limits the bit rate in the resultant transcoded file.
ps. make sure all check boxes on the Delivery, Subtitles tab are not checked. Let me know if they were checked as that may change things.
ami289
Post Thu Mar 03, 2016 7:44 pm
DenyAll wrote:Scratching my head.....
Hi mate.
I'm trying to avoid transcoding,
But as I've said in my last comment, although I've only tried that with the Harry Potter movie, transcoding didn't seem to make much of a difference.
The video seemed to freeze more or less around the same point.
I don't believe it is a bit rate issue, since I have about 3 MKVs with high bitrate, around 35mbps, and they do play,
They stutter becuase the bitrate is too high to handle (I've read someplace the dlna can handle max bitrate of around 20mbps, or something like that), but they do play without freezing.
Anyways,
I've just downloaded TVersity media server,
And, although I haven't done a 'full-test' (meaning watching the freezing videos from start to finish, to see that the freezing point has just been 'offset' to some other place in the video), but forwarding to the parts the causes the freeze while using Serviiio, seems to play fine while using TVersity.
Any ideas?
Post Fri Mar 04, 2016 12:45 am
Just an FYI. Not sure if there is a true bitrate limit via DLNA, but I have seen over 40 Mbps with my Sony Blu-Ray player streaming from my Serviio box. I've seen this high of bitrate with with two or three of my Blu-Ray rips. I haven't tested DLNA with hardly any 4K videos yet, and I don't have a 4K playback device that shows the active bitrate like my Sony players do. The one I have tried shows an overall bitrate of 40 Mbps, but that's likely the average with much higher peaks. This video has played without stutter, so I don't think there's an issue with that.
jk50
Post Sat Mar 05, 2016 4:43 am
You can check if a momentary spike in bitrate is causing the problem with Bitrate Viewer.
http://www.videohelp.com/software/Bitrate-Viewer-2
It will give you a graph of bitrate over time, and a peak bitrate. Check for spikes around the point where your
file freezes.
Did you try DenyAll's suggestion to remux the file ?
I have fixed many glitchy files with a simple remux.
Users browsing this forum: No registered users and 49 guests
