Can no longer connect devices to Serviio server
Jay
atc98092 wrote:Can your devices connect to anything else, such as Netflix or YouTube? That would help eliminate a networking issue with the device.
If everything else works, then you need to look at the computer running Serviio. Almost sounds like something updated your firewall (assuming you have one running on your computer). Personally, I turn the firewall off on my Serviio computer, as it's inside my network and simplifies other computers accessing the folder shares (I use it as a network server as well). I am also assuming your Serviio computer can connect outside to the Internet as well.
Are any/all devices wired or wireless?
atc98092 wrote:OK, let's try something else. First, if you're using Windows Serviio installed its own Java, so it doesn't matter what Java is on your computer already. If you are running Linux, then Java might be an issue.
Is your Serviio computer running a static IP address? If not, your computer might have changed its IP address but Serviio is still attempting to use the old one. In the Serviio console on the status panel, there is a box that allows choosing the IP address, and an auto section. I forget the precise wording and can't look since I'm not at home. Also, your log will indicate the IP address that Serviio is using. It will be at the beginning of the log during startup.
Make sure you are set to auto for the IP selection, then reboot the Serviio computer and make sure it is using the correct IP address. Consider assigning a static IP to it, as that ensures consistency.
Foosh wrote:I want to add my two cents to the discussion here. I too lost connectivity between my computer and Sony BVD Home Theater system after I "upgraded" to Servio 1.6. The one difference I have that is not discussed is I upgraded Servio in order to remote connect my Android (Samsung) phone. The phone connects to Servio just fine and streams video, but my home theater system no longer will. Prior to this my theater system was working fine. I tried all the suggestions and still no connectivity. I have not removed Servio from my phone to see if that changes anything.
Users browsing this forum: Baidu [Spider] and 29 guests
