Serice not starting
ytrewq
Post Sun Mar 13, 2016 1:21 am
Serice not starting
I have Serviio on a Windows 7 media NAS/Server. It is powered on by BIOS and off by Task Scheduler every day. When it restarts after a shutdown Serviio service is not starting automatically, even though it is set to do so and I have to remote in and do it manually every day. Any ideas? Thanks
Post Sun Mar 13, 2016 11:16 am
Re: Serice not starting
Does a detailed log shed any light on why it is not starting?
The log should show Serviio attempting to start and then perhaps give a clue as to what went wrong. If there is nothing in the log showing it attempting to start, I'd suggest you havent got the auto start set correctly (run services.msc and check that the Serviio Service is set to StartUp Type: Automatic).
Are you doing a full shutdown, not hibernate or sleep?
ytrewq
Post Mon Mar 14, 2016 6:42 am
Thanks for the reply. As you can see from my post it is set to run automatically, but just isn't doing it. It is scheduled to do a full shutdown. Here is a copy of the log:
<!DOCTYPE log4j:configuration SYSTEM "log4j.dtd">
<!-- Log4j Configuration -->
<log4j:configuration xmlns:log4j="http://jakarta.apache.org/log4j/" debug="false">
<appender name="FILE" class="org.apache.log4j.RollingFileAppender">
<param name="Threshold" value="DEBUG"/>
<param name="Append" value="true" />
<param name="File" value="${serviio.home}/log/serviio.log" />
<param name="MaxFileSize" value="500KB" />
<param name="MaxBackupIndex" value="5" />
<param name="Encoding" value="UTF-8" />
<layout class="org.apache.log4j.PatternLayout">
<param name="ConversionPattern" value="%d{ISO8601} %-5p [%c{1}] %m%n"/>
</layout>
</appender>
<category name="org.serviio">
<priority value="INFO"/>
</category>
<category name="com.sun.syndication">
<priority value="ERROR"/>
</category>
<category name="org.jaudiotagger">
</category>
<category name="org.restlet">
<priority value="OFF"/>
</category>
<category name="LogService"> <!-- Restlet access log -->
</category>
<category name="org.apache.jcs">
<priority value="WARN"/>
</category>
<root>
<appender-ref ref="FILE"/>
</root>
</log4j:configuration>
I can't see anything obvious that identifies the problem.
Post Mon Mar 14, 2016 11:39 am
Wrong file. The log file is in "C:\Program Files\Serviio\log\serviio.log".
The file in your post ("C:\Program Files\Serviio\config\log4j.xml") controls the level of detail in the log file. You can set:
</category>
to
<priority value="DEBUG"/>
</category>
and then save the file and restart your PC/Serviio Service. This sets Serviio to debug mode and gives the most information.
After your task scheduler does its thing and Serviio fails to start, look at the bottom of the log and see if it sheds any light on what is happening.
Once you have the info you need, reset the 'log4j.xml" file back to the way it was, and restart.
ytrewq
Post Wed Mar 16, 2016 9:45 am
Hmmm. Something up with this forum site. From the time I clicked login it took around 1 minute to actually log in. Posting this reply took the same amount of time before I got here. I expect SUBMIT will be the same based on this.
Is there a way I can get email notification when there is a response as I have no idea if anyone has replied?
I'll take another look at the log and get back, that's if I can log in....
ytrewq
Post Thu Mar 17, 2016 9:12 am
Here's a different log based on debug:
</layout>
</appender>
<priority value="debug"/>
</category>
</category>
</category>
</category>
</category>
</category>
<root>
</root>
Is this log any better? I can't see anything that helps me so unless anyone can come up with a solution I'll have to uninstall Serviio and try something else.
Post Thu Mar 17, 2016 9:20 am
No , you need to post the C:\Program Files\Serviio\log\serviio.log file (after restarting your PC).
