How to find the physical location of a file on Disk
fishmanj98
Post Mon Feb 22, 2016 1:40 pm
I am running the free Serviio 1.51. I am running it on a Windows 7 desktop
I have a tons of media files (mostly video and photos). There are times when I want to be able to get the actual file location (folder name) the file(s) are stored in. Is there a way to get this info via Serviio
thanks
jrf
Post Mon Feb 22, 2016 7:10 pm
Re: How to find the physical location of a file on Disk
If you find the file in the Folders category it's where it is on the disk
fishmanj98
Post Fri Mar 18, 2016 12:29 pm
zip wrote:If you find the file in the Folders category it's where it is on the disk
Yes, I know I can look at the folders.
Here's the challenge
I have videos and photos on six physical disks with folder structures like this
>Disk Name 1
\Video
\DVD
\MKV 720p
\MKV 1080p
\Music
\Lossless
\Mp3
\High Resolution Audio
>Disk Name 2
\Video
\DVD
\MKV 720p
\MKV 1080p
\Music
\Lossless
\Mp3
>Disk Name 6
\Video
\DVD
\MKV 720p
\MKV 1080p
\Music
\Lossless
\Mp3
Since each physical disk has the same folder structure, is there a way to see which physical disk a video is on. For example all I see in Folders is multiple named folders "DVD", "MKV 720p" and "MKV 1080p" . So though I can see the folder names, I can't tell which physical disk each folder is on.
Hope I am clear
thanks
jeff
Post Fri Mar 18, 2016 12:45 pm
No, unless you enable detailed logging, play the file and check the log.
fishmanj98
Post Sat Mar 19, 2016 12:31 pm
zip wrote:No, unless you enable detailed logging, play the file and check the log.
thanks Zip. I will do that
Is there a way to physically delete a file from any Serviio user interface. I would guess not but can't blame a guy for trying :-)
Post Sat Mar 19, 2016 8:11 pm
No there is not.
Users browsing this forum: Baidu [Spider] and 70 guests
