Livebox play
jpl
Post Sun Feb 07, 2016 12:20 pm
Livebox play
What should be the profile for the Orange Livebox play
Friendly name : décodeur TV d'Orange
Protocols :
http-get:*:text/xml:DLNA.ORG_PN=DIDL_S
http-get:*:image/jpeg:DLNA.ORG_PN=JPEG_SM_ICO
http-get:*:image/jpeg:DLNA.ORG_PN=JPEG_LRG_ICO
http-get:*:image/jpeg:DLNA.ORG_PN=JPEG_TN
http-get:*:image/jpeg:DLNA.ORG_PN=JPEG_MED
http-get:*:image/png:DLNA.ORG_PN=PNG_SM_ICO
http-get:*:image/png:DLNA.ORG_PN=PNG_LRG_ICO
http-get:*:image/png:DLNA.ORG_PN=PNG_TN
http-get:*:audio/L16;channels=1;rate=44100:DLNA.ORG_PN=LPCM
http-get:*:audio/L16;channels=2;rate=44100:DLNA.ORG_PN=LPCM
http-get:*:audio/L16;channels=1;rate=48000:DLNA.ORG_PN=LPCM
http-get:*:audio/L16;channels=2;rate=48000:DLNA.ORG_PN=LPCM
http-get:*:audio/mpeg:DLNA.ORG_PN=MP3
http-get:*:audio/mpeg:DLNA.ORG_PN=MP3X
http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=MPEG_TS_SD_EU
http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=MPEG_TS_SD_EU_T
http-get:*:video/mpeg:DLNA.ORG_PN=MPEG_TS_SD_EU_ISO
http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=MPEG_TS_SD_NA
http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=MPEG_TS_SD_NA_T
http-get:*:video/mpeg:DLNA.ORG_PN=MPEG_TS_SD_NA_ISO
http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=MPEG_TS_SD_KO
http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=MPEG_TS_SD_KO_T
http-get:*:video/mpeg:DLNA.ORG_PN=MPEG_TS_SD_KO_ISO
http-get:*:video/mpeg:DLNA.ORG_PN=MPEG_PS_NTSC
http-get:*:video/mpeg:DLNA.ORG_PN=MPEG_PS_PAL
http-get:*:image/jpeg:*
http-get:*:image/gif:*
http-get:*:image/png:*
http-get:*:audio/wav:*
http-get:*:audio/x-wav:*
http-get:*:audio/wave:*
http-get:*:audio/mpg:*
http-get:*:audio/x-mpg:*
http-get:*:audio/mpeg:*
http-get:*:audio/x-mpeg:*
http-get:*:audio/mp3:*
http-get:*:audio/x-mp3:*
http-get:*:audio/mpeg3:*
http-get:*:audio/x-mpeg3:*
http-get:*:audio/x-mpegaudio:*
http-get:*:audio/ac3:*
http-get:*:audio/x-ac3:*
http-get:*:audio/vnd.dolby.dd-raw:*
http-get:*:audio/mp4:*
http-get:*:audio/x-mp4:*
http-get:*:audio/mpeg4:*
http-get:*:audio/x-mpeg4:*
http-get:*:audio/m4a:*
http-get:*:audio/x-m4a:*
http-get:*:audio/3gpp:*
http-get:*:audio/aac:*
http-get:*:audio/wma:*
http-get:*:audio/x-ms-wma:*
http-get:*:audio/asf:*
http-get:*:video/asf:*
http-get:*:video/x-ms-asf-plugin:*
http-get:*:video/x-ms-asf:*
http-get:*:video/wmv:*
http-get:*:video/x-ms-wmv:*
http-get:*:video/x-ms-wm:*
http-get:*:video/x-ms-wmx:*
http-get:*:video/x-divx:*
http-get:*:video/x-matroska:*
http-get:*:video/x-msvideo:*
http-get:*:video/avi:*
http-get:*:video/msvideo:*
http-get:*:video/vnd.avi:*
http-get:*:audio/avi:*
http-get:*:audio/x-matroska:*
http-get:*:video/mp2t:*
http-get:*:video/vnd.dlna.mpeg-tts:*
http-get:*:video/mp1s:*
http-get:*:video/mp2p:*
http-get:*:video/mpeg:*
http-get:*:video/mpeg2:*
http-get:*:video/mpv:*
http-get:*:video/mp4:*
http-get:*:video/x-mp4:*
http-get:*:video/mov:*
http-get:*:video/quicktime:*
http-get:*:video/x-quicktime:*
http-get:*:text/m3u:*
http-get:*:audio/x-mpegurl:*
http-get:*:audio/x-scpls:*
http-get:*:application/vnd.ms-wpl:*
Jean-Pierre
stv
Post Sat Mar 19, 2016 9:55 pm
Re: Livebox play
up
SONY KDL-46D3500 | PS3 |TVBOXPLAY | LIVEBOXPLAY | WINDOWS 7 x64 I serviio 1.6 pro
Post Sat Mar 19, 2016 10:01 pm
Re: Livebox play
Try the Generic DLNA profile and come back with any file types (MediaInfo details) that do not play?
stv
Post Wed Mar 23, 2016 8:16 pm
Re: Livebox play
Thanks Denyall for answer, this is one video and audio chopped.
Général
Identifiant unique                       : 251075269280653272447895557482372304457 (0xBCE3568340E725639D4AEB3B8B5A8E49)
Nom complet                              : D:\- Vidéos -\- Enfants -\Spectre.2015.FRENCH.720p.BluRay.x264-AMNESIA.Premium.zone-telechargement.com.mkv
Version du format                        : Version 4 / Version 2
Taille du fichier                        : 5,39 Gio
Durée                                    : 2h 28mn
Débit global moyen                       : 5 205 Kbps
Date d'encodage                          : UTC 2016-01-17 19:06:54
Application utilisée                     : mkvmerge v7.8.0 ('River Man') 64bit built on Mar 27 2015 16:31:37
Bibliothèque utilisée                    : libebml v1.3.1 + libmatroska v1.4.2
Vidéo
Profil du format                         : High@L4.1
Paramètres du format, CABAC              : Oui
Paramètres du format, RefFrames          : 12 images
Identifiant du codec                     : V_MPEG4/ISO/AVC
Durée                                    : 2h 28mn
Débit                                    : 4 755 Kbps
Largeur                                  : 1 280 pixels
Hauteur                                  : 536 pixels
Format à l'écran                         : 2,40:1
Type d'images/s                          : Constant
Images par seconde                       : 23,976 (24000/1001) Im/s
Espace de couleurs                       : YUV
Sous-échantillonnage de la chrominance   : 4:2:0
Profondeur des couleurs                  : 8 bits
Type de balayage                         : Progressif
Bits/(Pixel*Image)                       : 0.289
Taille du flux                           : 4,92 Gio (91%)
Bibliothèque utilisée                    : x264 core 142 r2431+42 c69a006 tMod [8-bit@all X86_64]
Paramètres d'encodage                    : cabac=1 / ref=12 / deblock=1:-3:-3 / analyse=0x3:0x133 / me=umh / subme=11 / psy=1 / fade_compensate=0.00 / psy_rd=1.05:1.00 / mixed_ref=1 / me_range=32 / chroma_me=1 / trellis=2 / 8x8dct=1 / cqm=0 / deadzone=21,11 / fast_pskip=0 / chroma_qp_offset=-4 / threads=12 / lookahead_threads=2 / sliced_threads=0 / nr=0 / decimate=0 / interlaced=0 / bluray_compat=0 / constrained_intra=0 / fgo=0 / bframes=8 / b_pyramid=2 / b_adapt=2 / b_bias=0 / direct=3 / weightb=1 / open_gop=0 / weightp=2 / keyint=240 / keyint_min=23 / scenecut=40 / intra_refresh=0 / rc_lookahead=60 / rc=crf / mbtree=0 / crf=18.5000 / qcomp=0.60 / qpmin=0:0:0 / qpmax=69:69:69 / qpstep=4 / vbv_maxrate=40000 / vbv_bufsize=30000 / crf_max=0.0 / nal_hrd=none / filler=0 / ip_ratio=1.40 / pb_ratio=1.30 / aq=1:1.00 / aq-sensitivity=10.00 / aq-factor=1.00:1.00:1.00 / aq2=0 / aq3=0
Langue                                   : Anglais
Default                                  : Oui
Forced                                   : Non
Extension du mode                        : CM (complete main)
Paramètres du format, Endianness         : Big
Identifiant du codec                     : A_AC3
Durée                                    : 2h 28mn
Type de débit                            : Constant
Débit                                    : 448 Kbps
Canaux                                   : 6 canaux
Position des cannaux                     : Front: L C R, Side: L R, LFE
Echantillonnage                          : 48,0 KHz
Images par seconde                       : 31,250 Im/s (1536 spf)
Mode de compression                      : Avec perte
Taille du flux                           : 475 Mio (9%)
Titre                                    : FRENCH
Langue                                   : Français
Default                                  : Oui
Forced                                   : Non
Texte
Format                                   : UTF-8
Identifiant du codec                     : S_TEXT/UTF8
Identifiant du codec/Info                : UTF-8 Plain Text
Durée                                    : 2h 27mn
Débit                                    : 1 bps
Count of elements                        : 53
Taille du flux                           : 1,22 Kio (0%)
Titre                                    : FRENCH FORCED
Langue                                   : Français
Default                                  : Oui
Forced                                   : Non
:shock:
En. version if you prefer :roll:
Unique ID                                : 251075269280653272447895557482372304457 (0xBCE3568340E725639D4AEB3B8B5A8E49)
Complete name                            : D:\- Vidéos -\- Enfants -\Spectre.2015.FRENCH.720p.BluRay.x264-AMNESIA.Premium.zone-telechargement.com.mkv
Format version                           : Version 4 / Version 2
File size                                : 5.39 GiB
Duration                                 : 2h 28mn
Overall bit rate                         : 5 205 Kbps
Encoded date                             : UTC 2016-01-17 19:06:54
Writing application                      : mkvmerge v7.8.0 ('River Man') 64bit built on Mar 27 2015 16:31:37
Writing library                          : libebml v1.3.1 + libmatroska v1.4.2
Format settings, ReFrames                : 12 frames
Duration                                 : 2h 28mn
Bit rate                                 : 4 755 Kbps
Height                                   : 536 pixels
Display aspect ratio                     : 2.40:1
Frame rate                               : 23.976 (24000/1001) fps
Bits/(Pixel*Frame)                       : 0.289
Stream size                              : 4.92 GiB (91%)
Writing library                          : x264 core 142 r2431+42 c69a006 tMod [8-bit@all X86_64]
Encoding settings                        : cabac=1 / ref=12 / deblock=1:-3:-3 / analyse=0x3:0x133 / me=umh / subme=11 / psy=1 / fade_compensate=0.00 / psy_rd=1.05:1.00 / mixed_ref=1 / me_range=32 / chroma_me=1 / trellis=2 / 8x8dct=1 / cqm=0 / deadzone=21,11 / fast_pskip=0 / chroma_qp_offset=-4 / threads=12 / lookahead_threads=2 / sliced_threads=0 / nr=0 / decimate=0 / interlaced=0 / bluray_compat=0 / constrained_intra=0 / fgo=0 / bframes=8 / b_pyramid=2 / b_adapt=2 / b_bias=0 / direct=3 / weightb=1 / open_gop=0 / weightp=2 / keyint=240 / keyint_min=23 / scenecut=40 / intra_refresh=0 / rc_lookahead=60 / rc=crf / mbtree=0 / crf=18.5000 / qcomp=0.60 / qpmin=0:0:0 / qpmax=69:69:69 / qpstep=4 / vbv_maxrate=40000 / vbv_bufsize=30000 / crf_max=0.0 / nal_hrd=none / filler=0 / ip_ratio=1.40 / pb_ratio=1.30 / aq=1:1.00 / aq-sensitivity=10.00 / aq-factor=1.00:1.00:1.00 / aq2=0 / aq3=0
Duration                                 : 2h 28mn
Bit rate                                 : 448 Kbps
Frame rate                               : 31.250 fps (1536 spf)
Stream size                              : 475 MiB (9%)
Title                                    : FRENCH
Language                                 : French
Text
Format                                   : UTF-8
Codec ID                                 : S_TEXT/UTF8
Codec ID/Info                            : UTF-8 Plain Text
Duration                                 : 2h 27mn
Bit rate                                 : 1 bps
Stream size                              : 1.22 KiB (0%)
Title                                    : FRENCH FORCED
Language                                 : French
Post Wed Mar 23, 2016 10:27 pm
Re: Livebox play
What are your subtitle settings in Serviio Console (Delivery, Subtitles)?
Are you running wired or wifi?
Stuttering is often the hardest thing to work through.
stv
Post Thu Mar 24, 2016 7:26 pm
Re: Livebox play
I'm running wired via PLC (500 Mo/s)
DELIVERY :
transcoding is enable
Number of CPU is optimal
Produce best video quality is check
audio channel is keep original
SUBTITLES :
Subtitles is not enable
STACKING :
Is enable
If it's not enough I could give you screen shots.
Just to know, this video is running fine with vlc on the pc serviio server (codecs needed on it) and with wifi on Sony Xperia M2 and samsung galaxy tab 3 (servigo+mx player codecs neddeed on it).
Do I need to force transcoding for this generic DLNA ? (if yes, just tell me how to do)
Thanks for intersting my problem.
Post Thu Mar 24, 2016 10:18 pm
Re: Livebox play
The generic DLNA profile doesn't transcode any files. This file is being presented to your Livebox natively.
The problem is that (I believe) this file should be able to be played natively. There is something about this particular file that the Livebox doesn't like. So we could:
  1. Have Serviio transcode this type of file and it would likely fix the issue. The problem is that in doing so you will likely end up transcoding a whole lot of MKV files that don't need to be transcoded (and this can then lead to issues with fast forwarding, rewinding, etc). If you want to test this try setting the profile to the "Panasonic BD player" profile - this will transcode all MKVfiles (and a whole lot of other stuff you dont need, so this is only a test).
  2. Manually re-encode or remux this file using something like XMedia Recode
Which path you take depends on whether this problem is across multiple files, or just this one. If it's only one, its probably something in the encoding of this file and I'd re-encode it. If it's multiple, then we need to develop a profile specific for your Livebox.
stv
Post Fri Mar 25, 2016 12:02 pm
Re: Livebox play
This file is not the oly one that doesn't work, but I deleted others, I try to find them again and tell you.
Test of transcoding by profile "panasonic bd player" result :
Screen is not well sized (smaller)
Work one minute only then loose audio and video begin struttering.
For re ending or remux, just let me know if I "convert" or not, if yes in what (avi, mkv, ...) ? I'll try and tell you back.
Post Wed Apr 06, 2016 1:17 pm
Re: Livebox play
Sorry about the delay.
To try remuxing use ffmpeg that came with your Serviio version - from the command line prompt run (assuming you're on Windows):
"C:\Program Files\Serviio\lib\ffmpeg.exe" -i "filename.mkv" -c copy -map 0 "newfilename.mkv"
and try to play the newfile. For re-encoding download a tool like XMedia Recode. It's reasonably intuitive, but if not, there is a forum on the web that can assist.
