Youtube doesn't work
I have a problem with setting up YT plugin corectly.
Firstly I installed Serviio 1.6
Then dowloaded Firefox plugin
Then I put YT.groovy file in plugin folder
Next I tried used Serviio icon on YT playlist> It became red and said YT plugin not installed:
Log file shows:
- Code:
2016-03-19 17:49:09,932 INFO [MediaServer] ------------------------------------------------------------------------
2016-03-19 17:49:09,933 INFO [MediaServer] Serviio DLNA media streaming server v 1.6 (rev. 9a1458ed77db)
2016-03-19 17:49:09,933 INFO [MediaServer] Petr Nejedly 2009-2015
2016-03-19 17:49:09,933 INFO [MediaServer] http://www.serviio.org
2016-03-19 17:49:09,933 INFO [MediaServer] Java 1.8.0_40-Oracle Corporation x86
2016-03-19 17:49:09,933 INFO [MediaServer] OS Windows 8 6.2
2016-03-19 17:49:09,933 INFO [MediaServer] File encoding: windows-1250
2016-03-19 17:49:09,933 INFO [MediaServer] Headless mode enabled: true
2016-03-19 17:49:09,933 INFO [MediaServer] User: KAROL-KOMPUTER$
2016-03-19 17:49:09,934 INFO [MediaServer] User home dir: C:\WINDOWS\system32\config\systemprofile
2016-03-19 17:49:09,934 INFO [MediaServer] Temp dir: C:\WINDOWS\TEMP\
2016-03-19 17:49:09,934 INFO [MediaServer] ------------------------------------------------------------------------
2016-03-19 17:49:10,029 INFO [WebServer] Socket buffer set to 65535 bytes
2016-03-19 17:49:10,029 INFO [RestletServer] Starting Restlet server (/console) exposed on port 23423
2016-03-19 17:49:10,032 INFO [RestletServer] Starting Restlet server (/rest) exposed on port 23423
2016-03-19 17:49:10,150 INFO [RestletServer] Starting Restlet server (/cds) exposed on port 23424
2016-03-19 17:49:10,150 INFO [RestletServer] Starting Restlet server (/mediabrowser) exposed on port 23424
2016-03-19 17:49:10,163 INFO [DBSchemaUpdateExecutor] Checking if DB schema needs to be updated
2016-03-19 17:49:10,170 INFO [DatabaseManager] Using DERBY database language
2016-03-19 17:49:21,531 INFO [DBSchemaUpdateExecutor] Updating DB schema
2016-03-19 17:49:29,041 INFO [DBSchemaUpdateExecutor] Dropping search index
2016-03-19 17:49:29,043 INFO [SearchManager] Starting up search engine
2016-03-19 17:49:29,269 INFO [DBSchemaUpdateExecutor] Cleaning temporary cache
2016-03-19 17:49:29,329 INFO [Device] Created UPnP Device with UUID: d14fca63-b55b-3a04-ac7c-b3bc11378a31, bound address: 192.168.1.206
2016-03-19 17:49:29,401 INFO [DBSchemaUpdateExecutor] Cleaning persistent cache
2016-03-19 17:49:29,411 WARN [IndexedDiskCache] Region [online_technical_metadata] Reseting cache
2016-03-19 17:49:29,487 INFO [MediaServer] ------------------------------------------------------------------------
2016-03-19 17:49:29,487 INFO [MediaServer] License: PRO (EVALUATION, id: 11111111-1111-1111-1111-111111111113)
2016-03-19 17:49:29,623 INFO [ProfilesDefinitionParser] Parsing Profiles definition
2016-03-19 17:49:29,671 INFO [ProfilesDefinitionParser] Added profile 'Generic DLNA profile' (id=1)
2016-03-19 17:49:29,676 INFO [ProfilesDefinitionParser] Added profile 'Samsung TV (B-series)' (id=2)
2016-03-19 17:49:29,678 INFO [ProfilesDefinitionParser] Added profile 'Xbox 360' (id=3)
2016-03-19 17:49:29,678 INFO [ProfilesDefinitionParser] Added profile 'Playstation 3' (id=4)
2016-03-19 17:49:29,679 INFO [ProfilesDefinitionParser] Added profile 'Playstation 4' (id=ps4)
2016-03-19 17:49:29,679 INFO [ProfilesDefinitionParser] Added profile 'Samsung TV (A-series)' (id=5)
2016-03-19 17:49:29,681 INFO [ProfilesDefinitionParser] Added profile 'DirecTV HD-DVR' (id=6)
2016-03-19 17:49:29,682 INFO [ProfilesDefinitionParser] Added profile 'Samsung TV / player (H-series)' (id=sam_h)
2016-03-19 17:49:29,682 INFO [ProfilesDefinitionParser] Added profile 'Samsung TV / player (J-series)' (id=sam_j)
2016-03-19 17:49:29,682 INFO [ProfilesDefinitionParser] Added profile 'Samsung TV / player (E/F-series)' (id=sam_ef)
2016-03-19 17:49:29,683 INFO [ProfilesDefinitionParser] Added profile 'Samsung TV / player (C/D-series)' (id=7)
2016-03-19 17:49:29,683 INFO [ProfilesDefinitionParser] Added profile 'LG TV / player' (id=8)
2016-03-19 17:49:29,684 INFO [ProfilesDefinitionParser] Added profile 'Sony Bravia TV (2012)' (id=sony2012)
2016-03-19 17:49:29,685 INFO [ProfilesDefinitionParser] Added profile 'Sony Bravia TV (2013/14)' (id=sony2013)
2016-03-19 17:49:29,685 INFO [ProfilesDefinitionParser] Added profile 'Sony BDP-Sx100 (2013)' (id=bdp2013)
2016-03-19 17:49:29,685 INFO [ProfilesDefinitionParser] Added profile 'Sony BDP-Sx90 (2012)' (id=bdp2012)
2016-03-19 17:49:29,686 INFO [ProfilesDefinitionParser] Added profile 'Sony BDP-Sx70/SMP-N100 (2010)' (id=bdp2010)
2016-03-19 17:49:29,686 INFO [ProfilesDefinitionParser] Added profile 'Sony BDP-Sx70/SMP-N100 (2010) - US' (id=bdp2010us)
2016-03-19 17:49:29,686 INFO [ProfilesDefinitionParser] Added profile 'Sony BDP-Sx80/SMP-N200 (2011)' (id=bdp2011)
2016-03-19 17:49:29,686 INFO [ProfilesDefinitionParser] Added profile 'Toshiba REGZA' (id=13)
2016-03-19 17:49:29,687 INFO [ProfilesDefinitionParser] Added profile 'Toshiba REGZA 2012-' (id=tosh2012)
2016-03-19 17:49:29,687 INFO [ProfilesDefinitionParser] Added profile 'WDTV Live' (id=14)
2016-03-19 17:49:29,688 INFO [ProfilesDefinitionParser] Added profile 'LaCie LaCinema Media Player' (id=15)
2016-03-19 17:49:29,688 INFO [ProfilesDefinitionParser] Added profile 'Manta WIFI Centre' (id=16)
2016-03-19 17:49:29,688 INFO [ProfilesDefinitionParser] Added profile 'Pure Flow' (id=17)
2016-03-19 17:49:29,688 INFO [ProfilesDefinitionParser] Added profile 'Sharp Aquos' (id=18)
2016-03-19 17:49:29,688 INFO [ProfilesDefinitionParser] Added profile 'Sony Bravia TV (2011)' (id=sony2011)
2016-03-19 17:49:29,688 INFO [ProfilesDefinitionParser] Added profile 'Sony Bravia TV (2010)' (id=sony2010)
2016-03-19 17:49:29,689 INFO [ProfilesDefinitionParser] Added profile 'Philips (2010-)' (id=plps2010)
2016-03-19 17:49:29,689 INFO [ProfilesDefinitionParser] Added profile 'Philips (2009)' (id=20)
2016-03-19 17:49:29,689 INFO [ProfilesDefinitionParser] Added profile 'Sony Bravia TV (2009)' (id=sony2009)
2016-03-19 17:49:29,689 INFO [ProfilesDefinitionParser] Added profile 'Denon AVR' (id=22)
2016-03-19 17:49:29,690 INFO [ProfilesDefinitionParser] Added profile 'Panasonic Viera (2013)' (id=viera2013)
2016-03-19 17:49:29,690 INFO [ProfilesDefinitionParser] Added profile 'Panasonic Viera G/GT/DT/UT/VT (2011/2012)' (id=viera2011a)
2016-03-19 17:49:29,690 INFO [ProfilesDefinitionParser] Added profile 'Panasonic Viera E/S/ST/VT (2011)' (id=viera2011)
2016-03-19 17:49:29,690 INFO [ProfilesDefinitionParser] Added profile 'Panasonic Viera (2010)' (id=viera2010)
2016-03-19 17:49:29,690 INFO [ProfilesDefinitionParser] Added profile 'Sony Bravia TV (2012) - US' (id=sony2012us)
2016-03-19 17:49:29,690 INFO [ProfilesDefinitionParser] Added profile 'Sony Bravia TV (2011) - US' (id=sony2011us)
2016-03-19 17:49:29,691 INFO [ProfilesDefinitionParser] Added profile 'Sony AVReceiver STR' (id=SonySTR)
2016-03-19 17:49:29,691 INFO [ProfilesDefinitionParser] Added profile 'Sony Audio CMT' (id=SonyCMT)
2016-03-19 17:49:29,691 INFO [ProfilesDefinitionParser] Added profile 'Vizio TV' (id=viziotv)
2016-03-19 17:49:29,691 INFO [ProfilesDefinitionParser] Added profile 'Windows 8/RT' (id=win8metro)
2016-03-19 17:49:29,692 INFO [ProfilesDefinitionParser] Added profile 'Panasonic BD player' (id=panasonicBDT220)
2016-03-19 17:49:29,692 INFO [ProfilesDefinitionParser] Added profile 'Philips NP Streamium' (id=philips_streamium)
2016-03-19 17:49:29,692 INFO [ProfilesDefinitionParser] Added profile 'Chaneru' (id=roku)
2016-03-19 17:49:29,692 INFO [ProfilesDefinitionParser] Added profile 'Roku Media Player' (id=RokuMPApp)
2016-03-19 17:49:29,693 INFO [ProfilesDefinitionParser] Added profile 'Yamaha BD-A1020/BD-A1010' (id=YamBD)
2016-03-19 17:49:29,693 INFO [ProfilesDefinitionParser] Added profile 'Telenet Yelo TV' (id=TNDC)
2016-03-19 17:49:29,693 INFO [ProfilesDefinitionParser] Added profile 'Xbox One' (id=xbox_one)
2016-03-19 17:49:29,693 INFO [ProfilesDefinitionParser] Added profile 'Raumfeld' (id=raumfeld)
2016-03-19 17:49:29,706 INFO [ProfilesDefinitionParser] Parsing Profiles definition
2016-03-19 17:49:29,707 INFO [ProfilesDefinitionParser] Added profile 'Flash player' (id=flv_player)
2016-03-19 17:49:29,707 INFO [ProfilesDefinitionParser] Added profile 'iOS' (id=ios)
2016-03-19 17:49:29,707 INFO [ProfilesDefinitionParser] Added profile 'HTML5' (id=html5)
2016-03-19 17:49:29,708 INFO [ProfilesDefinitionParser] Added profile 'ServiiGo (Standard)' (id=serviigo_standard)
2016-03-19 17:49:29,708 INFO [ProfilesDefinitionParser] Added profile 'ServiiGo (Legacy Devices)' (id=serviigo)
2016-03-19 17:49:29,708 INFO [ProfilesDefinitionParser] Added profile 'ServiiGo (HLS)' (id=serviigo_hls)
2016-03-19 17:49:29,708 INFO [ProfilesDefinitionParser] Added profile 'ServiiGo (Google TV)' (id=serviigo_gtv)
2016-03-19 17:49:29,708 INFO [ProfilesDefinitionParser] Added profile 'Google Cast' (id=googlecast)
2016-03-19 17:49:29,709 INFO [ProfilesDefinitionParser] Added profile 'Chromecast' (id=chromecast)
2016-03-19 17:49:29,709 INFO [ProfilesDefinitionParser] Added profile 'Windows Phone 8' (id=wp8)
2016-03-19 17:49:29,719 INFO [PluginCompilerThread] Looking for plugins at C:\Program Files\Serviio\bin\..\plugins
2016-03-19 17:49:29,719 INFO [PluginCompilerThread] Started looking for plugins
2016-03-19 17:49:29,720 INFO [UpdateChecker] Checking if a new version is available
2016-03-19 17:49:29,987 INFO [FFMPEGWrapper] Found FFmpeg: ffmpeg version 2.4.git Copyright (c) 2000-2014 the FFmpeg developers
2016-03-19 17:49:30,086 INFO [AbstractAVTranscodingDeliveryEngine] Cleaning transcode engine and its data
2016-03-19 17:49:30,110 INFO [WebServer] WebServer starting on port 8895
2016-03-19 17:49:30,132 INFO [Device] Updated bound IP address of Device with UUID: d14fca63-b55b-3a04-ac7c-b3bc11378a31, bound address: 192.168.1.206
2016-03-19 17:49:30,135 INFO [EventSubscriptionExpirationChecker] Starting EventSubscriptionExpirationChecker
2016-03-19 17:49:30,135 INFO [EventDispatcher] Starting EventDispatcher
2016-03-19 17:49:30,135 INFO [DiscoveryAdvertisementNotifier] Starting DiscoveryAdvertisementNotifier
2016-03-19 17:49:30,137 INFO [RendererExpirationChecker] Starting RendererExpirationChecker
2016-03-19 17:49:30,146 INFO [RendererSearchSender] Searching for Renderer devices
2016-03-19 17:49:30,146 INFO [DiscoverySSDPMessageListener] Starting DiscoverySSDPMessageListener using interface eth0 (Intel(R) 82579V Gigabit Network Connection) and address 192.168.1.206, timeout = 0
2016-03-19 17:49:30,217 INFO [RendererManager] Stored a new renderer: uuid='9df6cab3-4da8-4944-8f8f-21eed4a82b6b', name = 'Unrecognized device', ipAddress='192.168.1.1', profile = '1', accessGroupId = '1'
2016-03-19 17:49:30,907 INFO [RendererManager] Stored a new renderer: uuid='16932acf-a674-480b-9eb8-da36716cd904', name = 'Sony BDP-Sx70/SMP-N100 (2010)', ipAddress='192.168.1.202', profile = 'bdp2010', accessGroupId = '1'
2016-03-19 17:49:35,436 INFO [RendererManager] Stored a new renderer: uuid='bbc16c92-7022-4f02-80ad-dc46213225cb', name = 'Unrecognized device', ipAddress='192.168.1.13', profile = '1', accessGroupId = '1'
2016-03-19 17:49:55,925 INFO [FileDeltaWatcher] Using 'sun.nio.fs.WindowsWatchService' for delta scan
2016-03-19 17:49:56,164 INFO [FeedUpdaterWorker] Started looking for information about online resources
2016-03-19 17:49:56,164 INFO [RepositoriesStatusCoordinator$RepositoriesStatusThread] Started checking repositories status
2016-03-19 17:49:56,194 INFO [LocalLibraryManager] Starting automatic library scan
2016-03-19 17:49:56,196 INFO [LibraryDeltaScanner] Starting the library delta scan
2016-03-19 17:49:56,196 INFO [PlaylistMaintainerWorker] Started looking for playlist changes
2016-03-19 17:52:09,883 WARN [PluginCompilerThread] Plugin Youtube.groovy failed to compile: startup failed:
C:\Program Files\Serviio\plugins\Youtube.groovy: 33: unexpected token: ** @ line 33, column 23.
final api_key = *** API KEY HERE ***
I know it's something wrong with API Key but I have no idea how to solve it.
Windows 10 user, Sony Blueray as a DLNA client.
