1.6.0 - serviioconsole.exe is not a valid win32 application
slyguy42o
Post Wed Mar 23, 2016 4:52 pm
Windows Version
After upgrading from 1.5.2 to 1.6.0 on two machines, both are reporting - "serviioconsole.exe is not a valid win32 application"
Was there a requirements change between 1.5.2 and 1.6.0?
Post Thu Mar 24, 2016 8:55 am
Re: 1.6.0 - serviioconsole.exe is not a valid win32 applicat
No change afaik. Not seen this before.
Serviioconsole.exe is simply a "micro-browser" that then opens the console browser page.... can you access the console directly from your default browser using http://localhost:23423/console?
I note you are a beta tester - does this occur with the beta version (if so please respond via that forum)?
Post Thu Mar 24, 2016 1:39 pm
You are probably on Vista or XP, no? Windows 7 is minimum for the console wrapper. You can still go to http://localhost:23423/console
slyguy42o
Post Thu Mar 24, 2016 8:33 pm
zip wrote:You are probably on Vista or XP, no? Windows 7 is minimum for the console wrapper. You can still go to http://localhost:23423/console
Yes I am using an older OS. Everything else including the web console works as expected though.
Post Sun Mar 27, 2016 7:56 pm
Yes, it's just the console executable wrapper, which is basically a Chrome core - which as far as I know is not supported on the older OSes.
