Seek good quality thumbs/pictures generated by serviiio?
wazer
Post Mon Mar 28, 2016 2:13 am
This how it looks in webbrowser tv,phones,tablets and what not, its everyting, i tried disabling generate thumbs etc nothing helped.
How can i make those pictures look better??
Post Mon Mar 28, 2016 7:02 pm
Re: Seek good quality thumbs/pictures generated by serviiio?
Not currently. There is a ticket pending to enable the users to define the resolution.
wazer
Post Tue Feb 28, 2017 3:19 am
zip wrote:Not currently. There is a ticket pending to enable the users to define the resolution.
Reviving this thread, does not seem to bee included as of 28-02-2017 on Version 1.8
Post Tue Feb 28, 2017 11:34 am
there is a serviio.hdThumbnailResoulution system variable now.
You can set it to something higher than 320, like
-Dserviio.hdThumbnailResoulution=640
http://www.serviio.org/index.php?option ... e&id=21#q3
You'll also have to refresh the video metadata in the console and Force refresh so that the thumbnails are re-generated.
wazer
Post Thu Mar 02, 2017 4:03 am
zip wrote:there is a serviio.hdThumbnailResoulution system variable now.
So my file should look like this?
-Dserviio.hdThumbnailResoulution=1920 -Xmx512m
-Xmx512m
was already added.
I force refresh and and meta, still not working.
Think there needs to be an proper guide?
people in this are using another cmd and it seems to be working for them?
viewtopic.php?f=5&t=22535
Im totally confused now.
is it
-Xmx512m
-Dserviio.hdThumbnailResoulution=1280
-DhdThumbnailResoulution=1280
without any spaces?
or
-Xmx512m -Dserviio.hdThumbnailResoulution=1280 -DhdThumbnailResoulution=1280
Because this wont make the server start with either one of them when editing ServiioService.exe.vmoptions
640 ress is too low for me.
Post Fri Mar 03, 2017 10:13 am
It should be
-Xmx512m
wazer
Post Sat Mar 04, 2017 6:22 pm
zip wrote:It should be
-Xmx512m
Thanks and if i just want all my generated pictures to be 1920x1080?
