Serviio 1.6 and DSM 6.0
CyPorK
Post Tue Mar 29, 2016 9:32 pm
last week I upgraded my DSM to 6.0. After that I see "ERROR [MediaServer] FFMPEG not found. Serviio will not work properly" error in LOG and unformtunatelly serviio doesn't work.
Have you any advise how to solve the problem?
Serviio: 1.6 rev 9a1458ed77db
NAS: DS1512+
DSM: 6.0-7321
java: 1.8.0_77-0038
CyPorK
Post Wed Mar 30, 2016 11:25 pm
Re: Serviio 1.6 and DSM 6.0
Problem solved.
1. I had wrong privilages on /var/packages/Serviio/target/bin
Solved by executing
chmod 747 /var/packages/Serviio/target/bin
2. After that, I got second error "‘/var/packages/Serviio/target/bin/ffmpeg: error while loading shared libraries: libz.so.1: cannot open shared object file: No such file or directory’". Error described by Barrin in comments on http://pcloadletter.co.uk/2012/01/25/se ... t-page-10/
Solved by executing instructions from patters
cd /volume1/@tmp
mkdir test
cd test
wget http://packages.pcloadletter.co.uk/down ... x64.tar.xz
tar xvJf serviio1.5-native-x64.tar.xz
mv /volume1/@tmp/test/* /var/packages/Serviio/target/lib/
mv /var/packages/Serviio/target/lib/fc-cache /var/packages/Serviio/target/bin/
mv /var/packages/Serviio/target/lib/ffmpeg /var/packages/Serviio/target/bin/
patters
Post Tue Apr 26, 2016 7:48 pm
Looks like my installer script isn't properly catching this particular CPU as being 64bit. Please can you run:
uname -a
and post the result?
