serviio.jks password / configuration
doemer
Post Thu Mar 31, 2016 8:29 am
Hi
I just installed 1.6.1 on my CentOS machine and enjoy the newly added HTTPS capabilities. Since today I use a WAF Service to make the mediabrowser available from the internet and keep it "secure" with HTTPS and as much filters and threat protections as usefull/possible. This configurations works pretty well and I am always aware of who is using or trying to use the service from outside.
Now that HTTPS has finally arrived I would like to add my StartSSL certificate to get rid of the untrusted certificate warning in my browser when opening the console (I would not consider to use the mediabrowser via https from internal network for CPU reasons) Its only cosmetic but it would be nice if you could provide the password of the default serviio.jks or give a hint where in the config anyone could provide an own keystore with a password that could be defined as well.
Thx a lot for this great piece of software. I always struggle a little with wrong thumbnails on my movies but it didn't bother as much to make an extra thread for it.
Best regards,
Doemer
Post Thu Mar 31, 2016 8:43 am
Re: serviio.jks password / configuration
if you unzip serviio.jar in the lib folder, there is a file serviio.properties. There are 2 properties related to the keystore (keystore password, certificate pasword). Change those, zip it back up and restart Serviio.
doemer
Post Thu Mar 31, 2016 9:02 am
perfect.
thx a lot
o2co0l
Post Sun Mar 26, 2017 11:43 pm
Que faut t'il faire dans la partie keystore ?
Je possède un certificat sécurisé mais je sais pas comment faire pas à pas pour que serviio l'utilise en connexion sécurisé.
Pouvez vous m'orienter pour paramétrer le serviio.properties ??
cordialement
