synology 1.6 not indexing files
sandervanzijl
Post Wed Mar 30, 2016 6:30 pm
After installing version 1.6 on my synology ds114 serviio seems to be broken.
symptoms are: the shared folders are not being indexed. only 1 or two files are found (sometimes)
when using the console, a lot of the time settings are not saving (the icon just keeps rotating)
during the update i got an error message, so i uninstalled everything and then reinstalled from scratch the java package and the synology package.
I have no idea what could be wrong. I do not have a high CPU load, which is sometimes mentioned in the forum.
Although I understand telnet and ssh linux and stuff like thta I do not know a lot of details.
So when asking me to do stuff, please explain how to do it. (f.e. sometimes people are asked to post a log, if that is relevant, please tell me how to get that log)
If possible I think it is better to return to the previous version, but I do not know how to do that.
I did find the log for servio in the packagecenter. that is showing errors. how can i post that log here?
sandervanzijl
Post Thu Mar 31, 2016 7:31 pm
Re: synology 1.6 not indexing files
this is the error that i get in the log files:
Exception in thread "Thread-224" java.lang.ArrayIndexOutOfBoundsException: 0
at sun.nio.cs.UTF_8$Decoder.decode(UTF_8.java:441)
at java.lang.StringCoding$StringDecoder.decode(StringCoding.java:153)
at java.lang.StringCoding.decode(StringCoding.java:193)
at java.lang.String.<init>(String.java:426)
at java.util.jar.Attributes.read(Attributes.java:418)
at java.util.jar.Manifest.read(Manifest.java:199)
at java.util.jar.Manifest.<init>(Manifest.java:69)
at java.util.jar.JarFile.getManifestFromReference(JarFile.java:199)
at java.util.jar.JarFile.getManifest(JarFile.java:180)
at sun.misc.URLClassPath$JarLoader$2.getManifest(URLClassPath.java:944)
at java.net.URLClassLoader.defineClass(URLClassLoader.java:450)
at java.net.URLClassLoader.access$100(URLClassLoader.java:73)
at java.net.URLClassLoader$1.run(URLClassLoader.java:368)
at java.net.URLClassLoader$1.run(URLClassLoader.java:362)
at java.net.URLClassLoader.findClass(URLClassLoader.java:361)
at java.lang.ClassLoader.loadClass(ClassLoader.java:424)
at sun.misc.Launcher$AppClassLoader.loadClass(Launcher.java:331)
at java.lang.ClassLoader.loadClass(ClassLoader.java:357)
at org.apache.log4j.spi.LoggingEvent.<init>(LoggingEvent.java:165)
at org.apache.log4j.Category.forcedLog(Category.java:391)
at org.apache.log4j.Category.log(Category.java:856)
at org.slf4j.impl.Log4jLoggerAdapter.error(Log4jLoggerAdapter.java:575)
at org.serviio.upnp.protocol.soap.ServiceInvoker.invokeOperation(ServiceInvoker.java:264)
at org.serviio.upnp.protocol.soap.ServiceInvoker.invokeService(ServiceInvoker.java:93)
at org.serviio.upnp.webserver.ServiceControlRequestHandler.handleRequest(ServiceControlRequestHandler.java:66)
at org.apache.http.protocol.HttpService.doService(HttpService.java:423)
at org.serviio.upnp.webserver.ServiioHttpService.doService(ServiioHttpService.java:78)
at org.apache.http.protocol.HttpService.handleRequest(HttpService.java:341)
at org.serviio.upnp.webserver.WebServer$WorkerThread.run(WebServer.java:204)
Todorov
Post Sat Apr 02, 2016 5:46 am
I have the exact same problem and I get the same error in the log. Running DSM6 on DS114.
I noticed that if metadata is turned off Serviio manages to index most of the video files, however it breaks after metadata is switched back on and fails to retrieve metadata.
Todorov
Post Sat Apr 02, 2016 7:49 pm
UPDATE: Went back to version 1.5.2. Still doesn't work properly, so I'm guessing the problem is related to DSM 6. With disabled metadata Serviio it indexes video files, but it crashes when indexing audio files. Also crashes when metadata is enabled
Any ideas?
Post Sat Apr 02, 2016 10:06 pm
Looks like a Java problem to me
sandervanzijl
Post Sun Apr 03, 2016 11:17 am
I have reinstalled the Java 8 package, but that does not solve the problem.
So it should be a coding problem in the java package or a wrong call to java in the software package.
sandervanzijl
Post Sun Apr 03, 2016 11:19 am
Todorov wrote:UPDATE: Went back to version 1.5.2. Still doesn't work properly, so I'm guessing the problem is related to DSM 6. With disabled metadata Serviio it indexes video files, but it crashes when indexing audio files. Also crashes when metadata is enabled
Any ideas?
you could install the logitech server for audio files.
If serviio does not get the meta-data, is it still able to place the files in the correct categories?
Post Sun Apr 03, 2016 6:49 pm
Seems like a problem with the java package on Synology. Here they have the same problem: https://forum.synology.com/enu/viewtopic.php?t=108843
Here as well - and they use the same Java package as the Serviio build: https://github.com/openhab/openhab-syno-spk/issues/19
Looks like we will need a new Java build by patters ;-)
sandervanzijl
Post Mon Apr 04, 2016 2:01 pm
the second problem was solved by installing the java version that dsm provides.
so I will try that this weekend.
I am not at home this week.
Todorov
Post Wed Apr 06, 2016 9:26 am
So I removed Patters' Java and installed the one from the package center. Serviio 1.6 was still crashing at some point but it did manage to index all the files after a few restarts. However, it was crashing when I tried to play files on my Samsung E-series player. So I went back to Serviio 1.5 28 and now everything is working fine, the same as before DSM 6.
Also, I will never update anything on my NAS ever again as long as it is working fine :))))))
sandervanzijl
Post Thu Apr 07, 2016 7:23 am
Todorov wrote:So I removed Patters' Java and installed the one from the package center. Serviio 1.6 was still crashing at some point but it did manage to index all the files after a few restarts. However, it was crashing when I tried to play files on my Samsung E-series player. So I went back to Serviio 1.5 28 and now everything is working fine, the same as before DSM 6.
can you explain how you were able to return to version 1.5?
do you need to downgrade the dsm version?
where did you get the installation files?
Todorov
Post Fri Apr 08, 2016 9:58 am
No need to downgrade DSM. I uninstalled 1.6, downloaded 1.5 from http://packages.pcloadletter.co.uk/downloads/old/ and installed it manually.
sandervanzijl
Post Sat Apr 09, 2016 3:28 pm
Todorov wrote:No need to downgrade DSM. I uninstalled 1.6, downloaded 1.5 from http://packages.pcloadletter.co.uk/downloads/old/ and installed it manually.
which java package did you use?
I tried to instal 1.5.2 with the java 8 package, but I get the same errors.
I seems there is an incompatibility with dsm 6
patters
Post Tue Apr 26, 2016 11:16 pm
Apologies I had not been able to test this as I had given my my old DS111 NAS (with ARM CPU) to my parents, and it was inaccessible remotely as they had changed broadband company. I have recently updated it to DSM 6.0 with Serviio 1.6 and I did not run into this issue, though I used Java Embedded 8u77 which was more recent. Serviio has been running without crashing on it since Easter. Have you tried with the latest Java Embedded 8u91?
nevets14
Post Thu Apr 28, 2016 12:39 am
Ill give it shot later today. I'll have to upgrade my DSM back to 6.0.
sandervanzijl
Post Sun May 01, 2016 5:45 pm
patters:
thanks for the support.
I have deleted everything I installed previously, rebooted, installed jave, rebooted, installed synology, rebooted.
Unfortunately I stell get the same (or similar) error in the serviio logs.
I have attached the log to this post.
can I do anything else to help solve this problem?
serviio log
(44.47 KiB) Downloaded 1054 times
sandervanzijl
Post Tue May 10, 2016 8:41 am
I am not 100% sure yet, but it seems I have found where serviio goes wrong.
I have disabled all the local indexing of metadata. so it is not searching for local files anymore, just collecting data from the internet.
this seems to work.
at least I have not found problems yet, and off course i will keep trying :-)
Users browsing this forum: Baidu [Spider] and 7 guests
