Help on Linux Mint
carmelinomillion
Post Sat Apr 02, 2016 5:14 pm
Help on Linux Mint
Hi everybody..
I'm trying to install Serviio on Linux Mint (version 17.3) but even if serviio start and the console is ok I can't see shared folder content from TV.
I am sure TV client is working.... 'cause with Serviio installed on Windows 10 on that computer it works great.
Java 8 is installed (this is the output of java -version command:
-java version "1.8.0_77"
Java(TM) SE Runtime Environment (build 1.8.0_77-b03)
Java HotSpot(TM) 64-Bit Server VM (build 25.77-b03, mixed mode)
Ffmpeg compiled following instructions set at (http://wiki.serviio.org/doku.php?id=build_ffmpeg_linux)
This is the output of ffmpeg command:
ffmpeg version 1.1.git Copyright (c) 2000-2013 the FFmpeg developers
built on Apr 2 2016 16:29:00 with gcc 4.8 (Ubuntu 4.8.4-2ubuntu1~14.04.1)
configuration: --enable-gpl --enable-libfaac --enable-libmp3lame --enable-libopencore-amrnb --enable-libopencore-amrwb --enable-libtheora --enable-libvorbis --enable-libx264 --enable-nonfree --enable-postproc --enable-version3 --enable-x11grab --enable-librtmp --enable-libxvid --enable-libass
Servvio installed following this document : http://wiki.serviio.org/doku.php?id=how ... buntu14-04
From TV side I can see serviio folder but no content..no icon..no video files.
Just for testing I copied some video on user's home subfolder (it was to avoid access rights problem)....still same problem..I can see folder name but no file inside.
I'm new to linux so I guess I miss something but I have no idea about...any hints please?
Thanks you very much..
Carmelino
jk50
Post Sat Apr 02, 2016 8:24 pm
Re: Help on Linux Mint
Somehow, you got some very old source code for ffmpeg. You compiled version 1.1 of ffmpeg.
I believe Serviio needs at least version 2.4.
Post Sun Apr 03, 2016 10:40 am
Check the log file. You should see if any files are actually added.
jk50
Post Sun Apr 03, 2016 9:52 pm
While the wiki does point to a very old version of ffmpeg, I just tried it and version 1.1 works fine.
You can ignore my earlier outburst, it's probably not the source of your problem.
Users browsing this forum: Baidu [Spider], Google [Bot] and 44 guests
