F series disconnects from Serviio in version 1.6.1
gorbeast
Post Sat Apr 02, 2016 7:36 pm
It works perfectly with 1.5.2 but "cannot connect to the device" message appears on both my Samsung F series blu ray players when trying to connect with serviio for watching videos or listening to music from PC. Photos library works, strangely enough. Profiles are correct. Reverted back to 1.5.2.
MarkGreaves
Post Sun Apr 10, 2016 7:34 pm
Re: F series disconnects from Serviio in version 1.6.1
I have exactly same problem. Where do I find older version 1.5.2 to download please so I can revert back to it until this problem with 1.6.1 is fixed? Thanks.
gorbeast
Post Fri Apr 29, 2016 5:44 am
Solved by uninstalling 1.5.2, installing a fresh install of 1.6.1 and rebuilding the library. :)
MarkGreaves
Post Thu Sep 15, 2016 7:26 am
Just upgraded to v1.7 but problem with Samsung Bluray (F series) still there.
Did a clean install - uninstalled v1.5.2 first, installed v1.7 and rebuilt library etc..
Samsung client sees video files OK but when played says "Not available" and then disconnects.
Currently reverting back to v1.5.2 but has any body got any suggestions as to what to try next please? Thanks
Post Thu Sep 15, 2016 7:52 am
You could ry to enable detailed log, play the file and then post the log here.
MarkGreaves
Post Mon Sep 19, 2016 1:27 pm
Thanks very much for the offer of help. Typically after I wiped everything clean and did another fresh install of v1.7 it now all works fine! :oops:
Didn't do anything different from last time so no idea why it now works when it didn't before, however I am glad that it does. :D
