1.6.1 - remote console
gavsdavs
Post Mon Apr 04, 2016 5:46 pm
I've just upgraded to 1.6.1 from 1.5.0
I run a linux serviio SERVER (this seems to be up and running, is logging and doing media-servery stuff)
I also run a serviio remote client (windows install, console installation)
I moved the "serviioconsole.exe.vmoptions" file from the old installation back to the new one - it says{
{code}
-Dserviio.remoteHost=<server.ip.add.ress>
{code}
I start up the console, it says "Cannot connect to the server, it doesn't seem to be running..."
The remote config thing i was using in 1.5.0 seems to have stopped working - what do I do ?
Post Mon Apr 04, 2016 5:50 pm
Re: 1.6.1 - remote console
The remote console setup is obsolete. You just go to the console web address.
http://serviio.org/component/content/article?id=21#q2
gavsdavs
Post Mon Apr 04, 2016 5:59 pm
Ok - that works - thanks
So I don't/can't actually use the windows console client any more ?
Post Mon Apr 04, 2016 8:28 pm
No, and there is no need for that. It's only a wrapper for the web page anyway.
Users browsing this forum: Baidu [Spider], Google [Bot] and 42 guests
