Web UI in PHP
Post Sun Feb 13, 2011 12:49 pm
Re: Web UI in PHP
individual
Post Fri Feb 18, 2011 8:13 pm
Re: Web UI in PHP
After a long journey I was finally able to start Serviio on my Synology DS211+ running DSM3.0, but I can't add media folders to the library.
This is the screen that i get (all pages are on black background - is something wrong? I can see in one post here that the pages should be on white background, but that doesn't happen here):
I also added
and
/volume1/video:
under PHP Settings tab in Control Panel - Web Services in DSM 3.0
I keep media files in the default shared folders (video, music and photo) created by Synology DSM because they are also used by Synology Media Server.
Any suggestions?
Thank you!
NAS: DS712+, 2x Seagate ST2000DL003
DLNA Server: Synology, Serviio, Twonky, Plex
DLNA Player: Raspberry Pi Raspbmc
DLNA Tablet: Yatse
Post Fri Feb 18, 2011 8:29 pm
Re: Web UI in PHP
individual wrote:After a long journey I was finally able to start Serviio on my Synology DS211+ running DSM3.0, but I can't add media folders to the library.
I also added
and
/volume1/video:
Any suggestions?
Thank you!
you shouldnt need a custom PHP basedir just uncheck that box and click OK
individual
Post Fri Feb 18, 2011 9:16 pm
Re: Web UI in PHP
Cerberus wrote: you shouldnt need a custom PHP basedir just uncheck that box and click OK
I did that but I receive the folowing error:
I forgot to say, I installed serviio-0.5 web interface... if that could be the cause.
DLNA Tablet: Yatse
Post Fri Feb 18, 2011 9:29 pm
Re: Web UI in PHP
erm what error ??
individual
Post Fri Feb 18, 2011 9:32 pm
Re: Web UI in PHP
Cerberus wrote:erm what error ??
there is a screen capture on the post. can't you see it?
here is the link: http://www.becos.ro/Up/Files/Images/Ser ... yPage1.jpg
DLNA Tablet: Yatse
Post Fri Feb 18, 2011 9:42 pm
Re: Web UI in PHP
Address does not exist and i would never click a .RO domain anyways to likely to me a virus. Please either attach the image to ur post or use a reputable image host site like photobucket..
individual
Post Fri Feb 18, 2011 9:55 pm
Re: Web UI in PHP
the address does exist. and the images with the related screen captures are linked to the above posts. they show perfectly fine in Internet Explorer.
maybe someone else could make a more appropriate comment.
DLNA Tablet: Yatse
pizzaguy541
Post Sat Feb 19, 2011 10:21 am
Re: Web UI in PHP
Cerberus, here is the image that individual was trying to display.
Post Sat Feb 19, 2011 2:05 pm
Re: Web UI in PHP
Thanks pizzaguy541
ok from that error i can see there is a permissions error but how to solve that.
change open_basedir = in your php.ini or add your path to the current open_basedir. Restart the apache webserver /usr/syno/etc/rc.d/S97apache-user.sh restart.
path you want to add is php:/volume1/web/
individual
Post Sat Feb 19, 2011 2:34 pm
Re: Web UI in PHP
thanks Cerberus, but that doesn't change anything. same behavior either way.
DLNA Tablet: Yatse
Post Sat Feb 19, 2011 2:40 pm
Re: Web UI in PHP
Then u will need to get on the synology forum and see if they can help as this isnt a serviio issue but a synolgy one.
patters
Post Tue Feb 22, 2011 12:32 am
Re: Web UI in PHP
It's no biggie - you can just put in the folder paths manually using Add Path...
I updated my guide with a screenshot since a few people have hit this problem. You will need to make sure that the serviio user has read access to these folders though (use the User Control Panel in DSM).
CaptainRewind
Post Sun Mar 13, 2011 8:06 pm
Re: Web UI in PHP
I got this up and running in Ubuntu. The only problem is that in the UI, I see black text on a black background. I was thinking maybe this could be solved with client-side greasemonkey scripting, but could probably be solved at the server level too.
Any suggestions?
CaptainRewind
Post Sun Mar 13, 2011 8:24 pm
Re: Web UI in PHP
I've fixed this temporarily with a tiny Greasemonkey script, code below (be sure to replace your Serviio WebUI host and port).
// ==UserScript==
// @name           serviio
// @namespace      serviio
// @description    serviio
// @include        http://<YOUR_HOST>:<YOUR_PORT>/*
// ==/UserScript==
GM_addStyle("body { color: black; background-color: white; } img { border: 0; }");
CaptainRewind
Post Sun Mar 13, 2011 8:27 pm
Re: Web UI in PHP
Now that the UI problem is resolved, I noticed that it doesn't let me make any changes to Serviio settings. It displays the correct information, though. This is using the REST API's, right? If so then permissions are probably not an issue.
I am using Ubuntu 10.04, Serviio 0.5.1, and the Web UI v05.b.
phn2
Post Mon Mar 14, 2011 10:15 am
Re: Web UI in PHP
Any chance of this UI beeing integrated into Serviio for noobs like myself? Trying hard to make headless system, with limited Linux skills... :?:
Edit: or someone making a guide for noobs. Im using turnkeylinux fileserver, based on Ubuntu 10.04...
Post Mon Mar 14, 2011 10:30 am
Re: Web UI in PHP
phn2 wrote:Any chance of this UI beeing integrated into Serviio for noobs like myself? Trying hard to make headless system, with limited Linux skills... :?:
This is a third party tool so very unlikely to be added to serviio build and serviio already provide a headless option in the remote console fucntions.
As for a howto this is also very unlikely as the chap who made the tool has gone AWOL and does not seem to be working on it anymore and from what captainrewind said above it looks like it no longer works with latest version of serviio (0.5.1)..
AcidumIrae
Post Mon Mar 14, 2011 6:24 pm
Re: Web UI in PHP
I have updated the root post of this topic with the new version information - it is now compatible with the serviio v0.5.1
    bgcolor fixed - tested on firefox
    status js fixed - tested with chromium
PS: You have to ping me via PM or E-mail as I'm not activly using serviio anymore, so I'm not around here :)
// WBR, Tolik aka AcidumIrae
Post Mon Mar 14, 2011 8:08 pm
Re: Web UI in PHP
AcidumIrae wrote:I have updated the root post of this topic with the new version information - it is now compatible with the serviio v0.5.1
pm me ya email bro and will keep ya updated on changes if you want :)
